01-10-2017, 04:48 PM | #603 |
Drives:
I'm just running the P3 Cars vent gauge... I wasn't planning on other gauges but at some point I'll get bored and do it anyway... lol
It has crossed my mind though...not because I need them but because it is something to do... the right gauge pod and gauges would look killer in my interior or any 86's interior for that matter. I do like the ATI triple gauge pod. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
The Following User Says Thank You to zeal86 For This Useful Post: | weederr33 (01-10-2017) |
01-10-2017, 04:54 PM | #604 | |
Drives: BRZ + Ducati M796
01-10-2017, 05:21 PM | #605 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
01-10-2017, 05:26 PM | #606 | |
Drives:
01-10-2017, 05:26 PM | #607 |
Drives:
I'll have to check these out as well... link?
01-10-2017, 05:29 PM | #608 | ||
Proud of BOXER
Drives: Subaru Boxer
http://www.ft86club.com/forums/showthread.php?t=46488
The Following User Says Thank You to Clipdat For This Useful Post: | zeal86 (01-10-2017) |
01-10-2017, 05:49 PM | #609 |
Weight Weenie
Drives: 15 FR-S
Check this out
[ame="https://www.youtube.com/watch?v=sxu2VUaIA-M"]How to set up digital gauges on your Head Unit using Torque Pro - YouTube[/ame] |
The Following User Says Thank You to new2subaru For This Useful Post: | notout86 (01-15-2017) |
01-10-2017, 06:24 PM | #610 | |
The Following User Says Thank You to weederr33 For This Useful Post: | zeal86 (01-10-2017) |
01-10-2017, 10:49 PM | #611 | |
http://www.ortizcustompods.com/subaru.html |
The Following User Says Thank You to Irace86 For This Useful Post: | 8R6 (01-13-2017) |
01-10-2017, 10:59 PM | #612 | |
Drives:
01-10-2017, 11:35 PM | #613 | |
01-30-2017, 10:26 PM | #614 |
Drives:
Ok... so I'm trying to put my show dates together for 2017...as far as major shows go, I plan attending several of the following:
HIN Dallas | May 13 SPOCOM Dallas | October 14 **(Probably 2 of the 3 Houston Shows)** Stancewars Houston | Nov 18 HIN Houston | December 9 Wekfest Houston | (Fall - TBA) Local Show(s) so far: West Texas Shakedown, San Angelo, TX | Fall - TBA) On the fence about these: Import Faceoff Noble, OK | March 26 Import Faceoff Ennis, TX | May 7 Import Faceoff Marion, TX | December 10 More likely as a spectator: DFW Auto Show | March 22-26 Dub Show Dallas | June 4 Formula Drift: Round 7 | August and/or September 9 Hope to meet some of y'all in person this year as well as see your 86s! __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
02-11-2017, 10:55 PM | #615 |
Drives:
I finally got around to starting my next project this afternoon... I gutted out my rear seat back, cushions, and seat belt reels, etc. in preparation for the installation of my Essex harness bar and the rear-seat delete I will fabricate. Going to use cardboard to create my stencils. I plan on using either aluminum or ABS or a combination of the two then covering the finished panels in alcantara.
I still need to get the harness bar painted Beatrush gold and my seat backs 37J before I can install them. If all goes well I will post a write-up with dimensions for my rear-seat delete. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
02-12-2017, 11:25 PM | #616 |
Drives:
The following is what I was able to complete today on my rear seat delete project...
Stenciled up using 6.75"x10. 5" card stock. I basically was trying to get to a pretty good starting point. Because of the bend I knew it would be a trial and error type of process. Ready for first trace... I used 22"x 28" poster board for my template... First template draft... Made some adjustments... Retraced my adjustments... Fitment check... Latest and greatest template... Fitment so far is looking good....I left some space on the edges for the fabric I will use later... that fabric will probably be alcantara. I'm planning on cutting a slit to slide the bracket behind the carpet. I may put sticky back felt paper or paint it to help conceal it. This bracket will add to the strength to the panels. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 02-13-2017 at 07:12 PM. |
The Following User Says Thank You to zeal86 For This Useful Post: | weederr33 (02-12-2017) |
Similar Threads | ||||
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 08:27 PM |
Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 07:09 PM |
EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 07:34 PM |
