Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
01-26-2017, 08:27 AM | #1 |
Drives: 2013 Firestorm FR-S
New jack design
So we all know the pinch welds on these cars are about as strong as a box of cardboard that's been left out in a hurricane. I came across this video of a new jack design that could be a pretty great solution, assuming you're jacking the car up one corner at a time and not from a front or rear jack point.
[ame="https://www.youtube.com/watch?v=rTwHC4tnd7s"]Powerbuilt U-Jack 2 Ton Floor Jack with Jackstand Saddle Slot - YouTube[/ame]
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
01-26-2017, 09:33 AM | #2 |
Drives: '13 SWP ZC6 R
Or buy an insert for your jack. Search "floor jack saddle insert for pinch welds"
01-26-2017, 09:37 AM | #3 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Why would you ever need to jack up the car from any point other than the front and rear spots?
01-26-2017, 09:58 AM | #4 |
I use the front and rear points, but I'm sure there are people out there who don't. And there are people on here who own cars other than their Toyobaru too.
The Following User Says Thank You to Shark_Bait88 For This Useful Post: | LOLS2K (01-26-2017) |
01-26-2017, 10:00 AM | #5 |
Yeah, I've seen stuff like that before. Certainly works too, this just seems like a more thought out solution.
01-26-2017, 10:07 AM | #6 |
Drives: 2013 satin white brz limited
Well In my case my jack is not low enough to reach the front jacking point. What I normally do is drive the front of the car up on ramps. Block the front tires just to make sure it cant come back down the ramps. Jack up the rear. put the jack stands under the rear. Then go to the front and jack it up high enough to get it off the ramp on each side and remove the ramps. Have done it this way a few times. Aside from getting a lower profile jack that can reach the intended jack point thats my safest option. Maybe someone else can chime in ideas?
01-26-2017, 10:48 AM | #7 | |
01-26-2017, 11:10 AM | #8 | |
Drives: 2013 Supercharged BRZ, E85, Ohlins
So I bought four slotted 'pinch weld adapters' from amazon and mounted them permanently over the pinch welds. Reinforced forever, job done. post here: http://www.ft86club.com/forums/showt...ld#post2836130 |
01-26-2017, 11:19 AM | #9 | |
yes on ramps but you don't need much. FYI Car lowered slightly on coil-overs. I got two short 1x8 boards from the scrap bin at home depot and beveled the front edges. i drive up on those and my jack now clears the front bumper to reach the jacking point. I guess you could double up on the 1x8s if you need a bigger lift.... |
01-26-2017, 11:26 AM | #10 | |
01-26-2017, 12:01 PM | #11 |
Drives: 2014 Subaru BRZ
*New Jack* But in all seriousness, i jack my car up from the pinch welds every time. Its too low to fit the jack under to reach the jacking points. Would have bought this style if it was available when i got my jack. |
The Following User Says Thank You to VIP BRZ For This Useful Post: | Shark_Bait88 (01-26-2017) |
01-26-2017, 03:24 PM | #12 |
Drives: FRS
because the car is too low to fit a jack under front/rear lol. the front splitter and rear diffuser makes it difficult also cuz then the handle for the jack has less range of motion to pump even if you can get it under after using a low ramp. i cant raise mine from just the rear anyway. the front splitter hits the ground before i can even get any height to squeeze in a jack stand under the sides lol
The Following User Says Thank You to 8R6 For This Useful Post: | DAEMANO (01-27-2017) |
01-27-2017, 10:08 AM | #13 | |
TALLY FT86
The Following User Says Thank You to Cockatoo For This Useful Post: | 8R6 (01-27-2017) |
01-27-2017, 12:31 PM | #14 |
Time Traveller
I could see this being useful.
My Velox rear diffuser is too low to get a jack under the diff, and front end is kind of the same. So I jack each side by the pinch welds, and would also like to place the jack stand under the jacking point. This accomplishes that. Only prob is that it doesn't look very low profile-ish and it's actuator arm thing is kinda short-ish. Can't someone make a lightweight super low profile jack with a long arm THING for us? ARRRRRRRGGHHHHH!!!!! |
The Following User Says Thank You to DAEMANO For This Useful Post: | 8R6 (01-27-2017) |
Similar Threads | ||||
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 04-11-2011 09:03 PM |
