Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-14-2018, 11:36 AM | #1 |
Drives: 15 BRZ limited
Stock brz ride height
I installed coilovers over the weekend and I forgot to measure the wheel center to fender
I've searched and only found fender to ground measurement. Can someone help me out. Thanks |
The Following User Says Thank You to BRZ.DEX For This Useful Post: | bobel (09-05-2020) |
05-14-2018, 11:52 AM | #2 |
Drives: 2013 Raven FR-S
I believe it's 14.5" from hub center to fender in the front. Not sure about the rear, but it's probably about the same.
05-14-2018, 12:21 PM | #3 |
Thanks
LOL, I did this with my Honda accord daily a month ago. Good luck to me finding the measurements, at least here we have enthusiasts!
05-14-2018, 12:28 PM | #4 |
Drives: '13 FRS - STX
OE Tire size is 24.6" diameter
Take the fender measurements you found and -12.3" for the measurement you want. |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (05-14-2018) |
05-14-2018, 03:49 PM | #5 |
Thanks fellas
05-14-2018, 04:19 PM | #6 |
Took from https://www.ft86club.com/forums/showthread.php?t=8739
Need to determine how much your car has lowered? Distance between hub center and top of fender opening Front is 14 7/16" and rear is 14 5/8" |
05-14-2018, 11:39 PM | #7 |
Drives: Subaru BRZ
As per the shop manual:
Front wheel arch to wheel center: 375mm (14.76") Rear wheel arch to wheel center: 372mm (14.65") |
The Following User Says Thank You to n0thing For This Useful Post: | gpvecchi (05-15-2018) |
05-15-2018, 02:55 PM | #8 |
That's about 1/4" higher in the front that I thought. I may have to revisit my ride height after learning this. Do you by any chance have a link to that info?
The Following User Says Thank You to smg1138 For This Useful Post: | strat61caster (05-15-2018) |
05-15-2018, 10:15 PM | #9 |
Drives: Subaru BRZ
here you go
The Following 3 Users Say Thank You to n0thing For This Useful Post: |
01-10-2021, 08:37 AM | #10 |
Drives: Widebody 86/F56 Mini Cooper S
01-10-2021, 04:08 PM | #11 |
ProCrastinationConsultant
it depends entirely on the change in specifications of your aftermarket wheels AND tires. if you did it correctly, the final circumference of the new tires/aftermarket wheels will be the same size, and therefore, all the axle centerline dimensions will still apply.
The Following User Says Thank You to soundman98 For This Useful Post: | Hamza (01-12-2021) |
Similar Threads | ||||
Stock ride height numbers? | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 07-11-2018 12:42 PM |
rocket bunny with stock ride height | xcuz31 | Off-Topic Lounge [WARNING: NO POLITICS] | 20 | 10-25-2016 04:29 PM |
Stock Ride Height? | JimmyMac | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-10-2015 11:46 AM |
BRZ vs 86 stock ride height | Moe | AFRICA | 2 | 11-21-2013 08:35 AM |
Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 168 | 01-31-2012 10:58 AM |
