Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
View Poll Results: What color of Series.Blue did you opt for?
Blue 176 55.70%
White 140 44.30%
Voters: 316. You may not vote on this poll
Old 08-16-2014, 09:45 PM   #253
BRZ.SeriesBlue28
Drives: 2015 Subaru Series.Blue (WRB)
I got a chip on the way to install my clear bra. What are the odds?
I got the custom full hood installed now.
Jeremy did an awesome job.
BRZ.SeriesBlue28 is offline   Reply With Quote
Old 08-16-2014, 10:01 PM   #254
quality_sound
Drives: '15 BRZ Series.Blue
Why was the full hood custom? Xpel has a pattern that covers the entire front end already.
quality_sound is offline   Reply With Quote
Old 08-16-2014, 11:27 PM   #255
DSOmegaX
DSOmegaX's Avatar
If the edges need to be tucked they may use the template for the general shape but still do the rest custom
@dsomegax.cars
Old 08-16-2014, 11:30 PM   #256
quality_sound
The Xpel pattern covers edges. All Xpel patterns cover every edge that can be covered without risk of lifting, which is most edges. I've never seen a full hood pattern of theirs that didn't cover all four edges. I hope you weren't charged extra because I know their full hood FR-S/BRZ pattern covers all four edges.
Old 08-17-2014, 12:16 AM   #257
DSOmegaX
DSOmegaX's Avatar
Shrug mine was done completely custom using suntek rather than xpel. Same healing properties optically clearer, and costs less. Just has a 5 year warranty versus 10 for the xpel
@dsomegax.cars
Old 08-17-2014, 12:33 AM   #258
BRZ.SeriesBlue28
I know the bumper was a pre-cut two piece but the side fender was custom. The side view mirrors are custom. Something about it being a two piece instead of one.
I would have to check but I thought the hood was custom.
Spent about $1250 for the entire thing including door trims and a trunk liner over the rear bumper. (All front lights covered too).
Old 08-17-2014, 12:51 AM   #259
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Smile
Originally Posted by BRZ.SeriesBlue28 View Post
Got my rearview camera kit today so I know what I'm doing this weekend.
Hoping I can tap into the HU and use Pin 7 and 15 for the power and ground for the camera.
Pin Label Description
6 PKB Parking brake input
7 CA+ +6V supply (output to camera)
8 V+ Camera Video Signal Input (+)
15 CGND HU grounds this internally
16 V– Camera Video ground/shield
Looking forward to DIY , someone pointed out to me that for BRZ it's almost a direct plug in since all the wires were done from factory already unlike FRS.
You really can't see what's close to your tail when the car isn't moving.
(when the car is moving, all 3 rear view mirror can cover up to like 200 degree if set up right)
Old 08-17-2014, 02:36 AM   #260
BRZ.SeriesBlue28
From all the post I read, it's pretty easy except for getting the power and finding a good ground. I'm hoping I can use what is coming out of the HU for them.
Old 08-17-2014, 10:04 PM   #261
quality_sound
Ahhhh, that explains it. The Suntek is definitely less expensive but I will disagree about the rest. I replaced Suntek on two cars because of cloudiness and the film didn't heal like they said it would. My STI got Xpel Stealth and my GTI got Ultimate. IMO both Xpel products were better than Suntek but at the end of the day, as long as you're happy with it that's all that matters. ANY film is better than nothing.
Old 08-18-2014, 02:05 AM   #262
BRZ.SeriesBlue28
Installed the rear view camera today. In hindsight, I should have installed the camera further back away from the edge.
Thanks to all the post out there that did most of the work. I basically followed this post http://www.ft86club.com/forums/showthread.php?t=32452.
Thank goodness for fish tape, nylon string and straws+chop sticks because that helped speed the process when feeding the wires through the rubber tube, the side panel and up to the HU.
I did use the power and ground from the HU by splicing into pin 7 and 15 on the 16-pin camera socket.
Pin-out:
Also it helps to take the panel above the glove compartment off to get to the panel for the HU.
The Following User Says Thank You to BRZ.SeriesBlue28 For This Useful Post:
fungizmos (08-30-2014)
Old 08-18-2014, 12:56 PM   #263
BRZ.SeriesBlue28
Everything is direct plug except for the power and ground. Since the adapter they shipped me for the 16 pin socket came fully wired for all 16 pins, I just had to splice into the right pins on the adapter.
I would definitely recommend using this camera kit because you don't have to cut any of the factory wires or look for a ground.
That part was easy.
Old 08-18-2014, 03:33 PM   #264
BRZ.SeriesBlue28
Yes, it's Xpel with the 10 year warranty per the invoice.
Old 08-21-2014, 02:04 AM   #265
BRZ.SeriesBlue28
Anyone figure out how to tell what number their car was made out of 500? Just curious.
Old 08-21-2014, 02:10 AM   #266
HiXxY
Shoegazer
HiXxY's Avatar
Drives: 2015 WRB BRZ Series.Blue
There has been some talk about deciphering the vin somehow but no definite answer that i'm aware of.
HiXxY is offline   Reply With Quote
2015, brz, heuburger, series.blue
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) -- General Topics 393 07-30-2014 12:27 AM
10 series vs. 2015 fr-s initialrt Scion FR-S / Toyota 86 GT86 General Forum 33 06-28-2014 09:40 PM
2015 FR-S or discounted 2013 10 Series? bostnwhalr Scion FR-S / Toyota 86 GT86 General Forum 29 06-12-2014 09:19 PM
(10-SERIES) Any way to disable blue LED on emblems? R4PT0R-X Cosmetic Modification (Interior/Exterior/Lighting) 0 05-27-2014 09:46 PM
