Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
10-31-2019, 03:46 PM | #29 | |
My VTEC fluid is full
Drives: EFF JAY
The reason for the OP is to use a headrest on track, where risks are far greater of snapping your neck. |
The Following User Says Thank You to iLuveKetchup For This Useful Post: | Tcoat (10-31-2019) |
10-31-2019, 03:59 PM | #30 |
10-31-2019, 04:02 PM | #31 | |
For example
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (10-31-2019), iLuveKetchup (10-31-2019) |
10-31-2019, 06:17 PM | #32 |
Ok so I had a little clearance issue when I was at the track. not quite enough room for my head with the helmet on. not an issue just marginal room. I went and turned my headrest around and now I can have the seat back 1 notch closer to the steering wheel. also tested and that setting there is no way I could see my neck getting overextended. I will go back some but then gets wedged in between the headrest and roof.
11-01-2019, 04:40 PM | #33 |
Drives: 2013 Scion FRS white
Honestly I don't know why more ppl have not complained about this. The seats in this car are great but are made for Asian dudes who are 5 feet tall, 130 pounds with shoulders of a 10 year old American child. I am 6 feet 170 pounds and have had to mash the seat wings a bit b/c my shoulders hang off. If you do that the headrest seems to push your head even further.... If you extend the headrest all the way out it is a bit better. You can even pull it out so far past the last lock and let it sit there; it will migrate back after a while of driving. Every bit helps tho. As others have mentioned, if you flip the headrest...you basically don't have a headrest anymore so that really isn't a good solution.
05-04-2023, 02:34 PM | #34 | |
Drives: 2017 GT86
The red stitching is a mismatch for the gray stitching of my upholstery, but I don't care. What I do care is that I can put my seatback another two notches forwards with this headrest and my back is grateful for it. |
The Following User Says Thank You to Luns For This Useful Post: | norcalpb (05-04-2023) |
05-04-2023, 05:35 PM | #35 | |
So much easier on my neck. |
05-15-2023, 08:56 PM | #36 |
Drives: 2017 GT86
One more data point. I've tried out the front headrest from a 2015 Lexus ES350.
This headrest is adjustable fore-aft, with 4 positions, and the posts fit our twins just fine. The silver stitching is also a good match for my seats. However, sadly the unit I got was broken, with the adjustment stuck in the most forward position. The displacement in this position is pretty much the same as our original headrest, so the unit is useless to me. If the adjustment were working, I estimate the farthest back position would be comparable to the Camry headrest. This would make this a pretty ideal replacement, offering the IMO better position, without taking away the option of the original headrest's position for anybody who might prefer it. It looks like the IS350 headrest from similar years would work too, but beware 250 headrests that are listed as interchangeable - those will fit but aren't adjustable. |
05-25-2023, 03:53 PM | #37 | |
Drives: 2017 GT86
So, I guess if you have a very laid back seating position with extra space behind your head, the ES350 headrest could help close that gap. But for those of us preferring more upright seating, it goes the wrong way. Lastly, I did notice through all this a perceptible weight difference between headrests. The Camry headrest is over a pound heavier than stock for the twins. The ES350 somehow feels lighter, but turns out to weigh even more - maybe another 3oz more, or about double what we have stock. Still, I'll gladly take the 1lb hit for the sake of my neck. |
05-26-2023, 09:14 PM | #38 |
Drives: 2013 FRS
Unfortunately the Camry headrests don't hold true for 2022+ seats, the headrest posts are spaced differently than 1st gen.
08-09-2023, 03:23 PM | #39 |
Drives: 2023 BRZ
Shoot - I read 38 posts to get to this? The headrests don't bother me but it does bother my wife. You'd think there would be interchange (post spacing and diameter) with... other Subarus?
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
11-24-2023, 02:56 PM | #40 |
Drives: 2018 BRZ w/Performance Package
Do you have a picture of what these look like installed, and was the width between the posts correct or did it require any force-fitting? Just about to order a set myself!
The Following User Says Thank You to TurboLag23 For This Useful Post: | norcalpb (11-26-2023) |
11-26-2023, 05:48 PM | #41 | |
They can also sit flush. Shockingly they are probably 3x as heavy but oh well. Keep in mind I only use these for track days when I’m wearing my helmet. |
11-27-2023, 11:14 PM | #42 |
Drives: 2014 FR-S
The Following 2 Users Say Thank You to tarzan_nojane For This Useful Post: | Dadhawk (11-28-2023), x808drifter (11-28-2023) |
Similar Threads | ||||
So... about those headrests | TuxedoCartman | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 03-28-2014 07:22 PM |
Does anyone else's headrests creep upwards as they drive? | Silver Ignition | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 03-26-2014 01:35 AM |
Aftermarket headrests | radroach | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-02-2013 11:09 AM |
Options for those damn headrests? | sikest | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 02-01-2013 01:56 PM |
No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 04:42 PM |
