Member's Car Journals Car journals by our members. |
07-02-2014, 02:11 PM | #15 |
Drives: 2017 Fiesta ST
that's an ambitious project, kudos!
The Following User Says Thank You to OnkelC For This Useful Post: | Guff (07-02-2014) |
07-02-2014, 02:36 PM | #16 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Thanks guys!
It sucks that I'm at point where I can't really do anything because of a lack of parts. Maybe I'll start doing brake lines soon as I don't really need to wait for anything to do that. But I need to buy a brake bending/flaring kit and I'll have to learn how to do that. Actuallly... Since the original cable handbrake was utterly jacked up, I removed the assembly it from rear drums. I was thinking that I could use a Hydro E-brake (like drifters use) that had a parking lock on it as a parking brake. Is this a terrible idea? I read somewhere that the hydraulic pressure might bleed off as you let it sit, but I have full manual brakes so I'm not sure if I would have that problem. Also, I would be using that in conjunction with leaving it in gear, so I like wouldn't have an issue. If I do go with that, then I would have to run the brake lines from the cylinder to the e-brake, and then the e-brake to the rear. Other than that, I might start on getting the fuel tank prepped and put back in. It needs to be sanded and painted, and I think I need a new fuel pump. And then from there I need to run fuel lines (More parts to buy...) August is looking way too damn close...
- The Ancient BRZ Sacrament by Zaku |
07-03-2014, 02:58 AM | #17 |
Drives: BRZ LZR
Update 2 is up in the OP, gentlemen. It's short, but it was a big step towards getting the motor in!
The ball joint shims come in tomorrow so there's a good chance the motor will also go in tomorrow! Fingers crossed!
- The Ancient BRZ Sacrament by Zaku Last edited by Guff; 01-12-2015 at 06:35 PM. |
07-03-2014, 02:28 PM | #18 |
Drives: 2013 Subaru BRZ
hydro handbrake with a lock on it to actually hold a car from rolling away is a terrible idea
carry a block of wood in the car and leave it in gear like a normal person
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post: | Guff (07-03-2014) |
07-03-2014, 02:51 PM | #19 | |
Drives: BRZ LZR
I guess what I'll do is retain the factory cable handbrake and eventually get around to getting all new parts for it and making it work.
07-03-2014, 03:27 PM | #20 |
all I know for sure is that you're not supposed to do it.
certainly any sort of leak would let the car roll away, and it can't be good for the seals in the calipers to have them pressurized all the way for hours on end. I think it's because it's just far less reliable in general. also, in some locales, roadworthiness laws require the emergency brake to function independently of the main brakes, for obvious safety reasons.
07-03-2014, 03:57 PM | #21 |
not that roadworthiness laws particularly matter... nobody's going to crawl under there and check, but it's still a good guideline for building a safe car.
07-03-2014, 09:19 PM | #22 | |
Drives: BRZ LZR
Update is coming tonight! I got some stuff done! Motor is hopefully going in tomorrow!
07-03-2014, 09:30 PM | #23 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Yes, the pressure can bleed off. Hydro systems are like balloons. If one seal goes for whatever reason, the whole thing deflates.
Fed Regs mandate a separate mechanical parking brake. Likely you'll need be inspected to get it licensed and back on the road.
"I gotta rock." -- Charley Brown |
07-03-2014, 09:33 PM | #24 |
Drives: BRZ LZR
Thanks! I'll start looking for e-brake parts or perhaps try fabricating something to work.
07-04-2014, 02:09 AM | #25 |
Drives: BRZ LZR
I screwed up a bunch of stuff tonight... I guess it was just an off night. Put the wrong side hub on and then had to use a separator fork to remove it, then cross threaded the caliper mount on the hub. I ended up fixing it, but it took way too much effort for what it's worth. I only got one side done before I figured I was way too out of it to work, so I retired before I could screw anything else up...
I'll update the OP with what I did get done. Tomorrow however, is going to be awesome! Motor is definitely going in, as I'll have the extra pairs of hands tomorrow!
07-04-2014, 08:28 PM | #26 |
That Guy
Drives: 2013 asphalt FRS MT
Damn, that's a "shed"?
The Following User Says Thank You to Calum For This Useful Post: | Guff (07-04-2014) |
07-06-2014, 05:44 AM | #27 |
Drives: BRZ LZR
Things are going kinda rough. Had to pull the subframe out to put the motor in because the motor wouldn't fit in the subframe while it was attached to the chassis. Now I'm finding a slew of things with clearance issues and it's pissing me off. Hopefully the motor+subframe will be in by Tuesday, but we'll see.
I feel like I'm going backwards, but I suppose it's all part of the process...
07-06-2014, 05:08 PM | #28 |
Drives: 1985 P-Type
@Guff this is my new favorite thing.
The Following User Says Thank You to bestwheelbase For This Useful Post: | Guff (07-06-2014) |
Similar Threads | ||||
ΘΘΘ Tomei Titanium Exhaust Systems ΘΘΘ Cat Backs, Front Pipes, Over Pipes and Headers | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 291 | 02-16-2017 10:37 PM |
Go Fast Bits - Photos of the pulleys that shed weight for 2013 | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 34 | 10-20-2016 12:14 PM |
Guess the Vtec kicked in... | Bad Habits | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 11-22-2013 08:12 PM |
Human VTEC Sound | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 07-10-2013 12:51 PM |
