Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-18-2016, 09:55 AM | #15 |
Drives: 15 BRZ LTD, 05 FXT
This thread is relevant to my interests. Carry on!
@GSpeed I really appreciate your dedication to options for this chassis, and I like that it seems the interior could be modified minimally to retain most of it with this bar in place.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
07-18-2016, 11:53 AM | #16 | |
Drives: 2014 BRZ
Anyway, its all a matter of balancing compromises between full on race cage and nothing. For the most part, you are right that the roll bar is very unlikely to see such forces as the one on the Mustang scenario which is a worst case scenario where the car flips and lands perfectly upside down with the full force remaining from having hit the tire wall. So far, you bar looks better than the Cusco and worse than the Autopower. However, the latter does require welding in the front footing plates which a lot of people are not willing to do. I went with a custom bar to meet my balance of compromises It would be nice to see how the front bars are attached. It looks it is sandwiching more than the just the floor, which I think is a key selling point and might put it closer in strength to having used the rear seat shelf.
07-18-2016, 12:39 PM | #17 |
Drives: 2015 BRZ
Right, you see where we're coming from. No one will argue this is as strong as a fully welded cage. That's common sense. This is for the people that want a little more safety to augment aftermarket seats and harnesses. If you think you'll be in an environment where flipping is a very real possibility (wheel-to-wheel, rally, etc.) you need a fully welded cage. Which is why that's what our shop development car has.
08-16-2016, 09:37 AM | #19 |
Drives: 2015 BRZ
Yes. We have a member on this sites' car in the shop to use for interior measurements. Should be getting started this week. Our guys are finishing up some other projects before they get started on this car, and we'll have some pictures put up once work begins.
08-20-2016, 05:36 AM | #20 |
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Subbed for updates.
Sent from my SAMSUNG-SM-G890A using Tapatalk
ALL THE MODS!!
08-20-2016, 06:01 AM | #21 |
Drives: 2013 Asphalt FRS
In the top picture the bar leans forward in the bottom picture it leans backwards which is it.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
08-20-2016, 06:32 AM | #22 |
OK, so I just sat in my car and basically your design is close to what I have.
Looking at your drawings and comparing it to mine I see a few issues you might want to address.... 1: you say not to use them with a factory seat but your bar does not include a harness bar. 2: I would consider moving it back for 2 reasons. 1st reason is someone will buy this bar and use a factory seat and kill themselves hitting their head on the bar.....2nd reason is its a bolt in bar that has maybe 2/3 the strength as a weld in bar. So knowing this I would move it back to be safer to the driver and still add protection. Yes it could punch thru but its a extra layer of protection. Mine with a harness bar weighed 47 lbs. In February this year my nephew was driving a jeep and got t-boned by some asshole who wasn't paying attention and ran a stop sign.... He was hit so hard he shattered his skull on the roll bar and it killed him instantly... This isn't a mod for coolness points at a stance car show. A roll bar will kill you or save your life and you only get one chance to do it right.
08-20-2016, 02:30 PM | #23 | |
Drives: GT86-ACE-JRZ-RPF1-Essex
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
08-20-2016, 02:56 PM | #24 | |
With the placement of the bar you would have to wear a helmet on the street or roll the dice in a oem seat. Maybe MRK1 can explain it better...
08-20-2016, 03:05 PM | #25 | |
The point of a half cage is to drive on the road to the track. That would make it useless if it's as unsafe as a full cage on the road. (Not that I plan to use oem seat, but I plan to drive the car on the road without helmet)
08-20-2016, 03:44 PM | #26 |
I guess we will have to wait until we see a picture with someone sitting in the car.
In all fairness its hard to speculate from 2 different drawings...
08-20-2016, 03:59 PM | #27 | |
At the moment I think I may use a reclining seat like a Bride Gias 2 and full OEM safety. Properly using the 3 point belt with a fixed back bucket on the road is looking more and more painful to setup. Dunno if Gspeed got a solution to properly mount the seat belt receiver to pass inside the bucket seat opening ?
The Following User Says Thank You to MaximeT For This Useful Post: | FRS Justin (08-20-2016) |
08-21-2016, 05:35 AM | #28 |
I guess with this design, the harness pass should follow the second graph ?
What's your position guys related to using a 6 point harness, no helmet and oem airbag on the road ? I don't care at all about it being legal. Just the safety side. It's pretty hard to find an answer so far.
Similar Threads | ||||
GSpeed Roll Cage Kit Development | GSpeed | Tracking / Autocross / HPDE / Drifting | 66 | 07-14-2016 12:59 PM |
Finally looks like there is a proper bolt-in roll bar solution! | OkieSnuffBox | Tracking / Autocross / HPDE / Drifting | 47 | 08-23-2015 07:13 PM |
FS: Battle Version BOLT IN roll bar/cage | Fortunate Few | Brakes, Suspension, Chassis | 22 | 07-22-2014 02:35 PM |
Bolt in Roll cages. | Ludacrits | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-26-2014 06:19 PM |
86/BRZ/FR-S Bolt In Roll Bar by Alex Pfeiffer-Battleversion | 03Z33 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 61 | 01-28-2013 04:57 PM |
