Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
08-07-2014, 10:43 AM | #15 |
Drives: 2018 Camry XSE V6
I think of it more as graduating towards both a higher level of skill, fun, and less of a safety net.
Traction control off lets you get unstuck from mud or snow. On cuts throttle to prevent wheel spin and any chirping of tires and makes everyone think you are civilized. VSC Sport on allows a little more slip angle, but, will reign you in when it thinks that you've lost control (which can be counterproductive if you know what you are doing because it cuts in just a little too early). This mode is semi-civilized and allows for some misbehaving. Off is not actually completely off (for that you need the pedal dance or pull the ABS fuse). Nevertheless, as far as most people need, it is good enough. Once you realize that VSC Sport mode is interfering too much, then you have graduated to the fun level. Toss the car into a corner with full on opposite lock drifting. Word of caution is to not let your ego get bigger than your skill level. Wade into it unless you are in a safe environment. It can be risky thinking that you need to run before you can walk. Not that I am the Stig, but, unless it is absolutely horrible weather, part of starting my car is turning off all of the nannies. This mode is for the uncivilized lunatic, but, if you are, you already don't care. As others have mentioned, a little bit of wheel spin achieves the best accelerations, but again, part of learning and graduating is not too much wheel spin. |
08-07-2014, 11:18 AM | #16 |
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
Simple yes or no question:
Is there a difference between holding both buttons for 15 seconds and pressing only TRC for few seconds until TRC and VSC go off? |
08-07-2014, 11:31 AM | #17 | |
Drives: Toyota 86 GTS
Super simplified version from track experience;
Everything on: won't let you rotate the car, will cut power immediately when it senses wheel slip, particularly bad trying to exit a turn under power VSC Sport: car will rotate a small amount, but will still cut power very early, you can go faster but still too intrusive under power All off: does not cut power at all which means you can rotate the car freely and put down power slides as you see fit. Used responsibly you can put down lots of power out of turns and/or drift (and/or spin) Quote:
and you only need to hold it for around 3 seconds to get full off
08-07-2014, 11:52 AM | #18 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
08-07-2014, 12:15 PM | #19 |
Drives: swp brz limited
There was another thread someone had some pretty convincing info that the throttle map was changed in sport mode. I can't really tell the difference
08-07-2014, 12:18 PM | #20 |
08-07-2014, 12:26 PM | #21 | |
Lap time enthusiast
So, it's not about your ability to drive, but what kind of situations you'll be faced with on day-to-day driving. Last edited by raul; 08-07-2014 at 12:37 PM. |
08-07-2014, 12:33 PM | #22 |
Drives: Raven Black
08-07-2014, 12:35 PM | #23 | |
Granny Shifter
Drives: 2014 FR-S
This. Ironically, the idiot that swerves into your path could be the same person with all his assists disabled failing horribly at driving "because racecar". |
08-07-2014, 12:47 PM | #24 | |
08-07-2014, 12:50 PM | #25 | |
Lap time enthusiast
08-07-2014, 12:55 PM | #26 | |
08-07-2014, 12:56 PM | #27 | |
Lap time enthusiast
The Following User Says Thank You to raul For This Useful Post: | Luis_GT (08-07-2014) |
Similar Threads | ||||
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
Traction Control Question | Canehda | Issues | Warranty | Recalls / TSB | 30 | 10-22-2013 07:19 PM |
Sport mode/traction control | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-05-2013 04:54 PM |
traction control question | Sileighty_guru | BRZ First-Gen (2012+) -- General Topics | 9 | 09-26-2012 09:54 PM |
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) -- General Topics | 40 | 04-25-2012 11:20 AM |
