Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
02-27-2014, 05:24 PM | #29 | |
Personal opinion here, but to me, the contact point on an Esco jack stand is the same as a 4-point lift. It spreads the load over a 5" rubber pad, just as a lift would, and I haven't seen a pinch weld bend from a lift before. Car manufacturers design pinch welds to support the car on a 4-point lift. And if you really wanted, you could cut hockey puck pinch weld adapters and place them on the Esco jack stands since the tops are flat. I think pinch welds bend when you're lowering the weight of the car onto a small cross-section, like a 1-2" metal jack stand. It's the application of force over a small cross-section that causes the damage, but by spreading it over a much larger cross-section (i.e., 5" rubber pad), you prevent damage.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | PNW FRS (05-27-2014) |
02-27-2014, 06:34 PM | #30 |
Drives: frs
I took four pieces of 4x4 cut into perfect cubes, shaved about 1" off one side, then routed a 1/4" wide groove in the wood down the middle of one of the wider sides just about 1mm less depth than the height of the pinch weld. I put them on top of the jack stands, and the pinch weld down the groove. They bear the weight of the whole car no problem.
The Following User Says Thank You to twag4 For This Useful Post: | bcj (02-27-2014) |
05-25-2014, 07:09 PM | #31 |
I used the HF rubber tips on top of HF jacks and they promptly sliced the paint right off the jacking points. They're too soft and narrow so the pinch weld "slides" through the rubber, ripping off the paint in one go. ARGH. (Tips I used)
Weld is still mechanically intact but now I need something to cover/protect the exposed metal, any thoughts? |
05-25-2014, 10:44 PM | #32 |
Drives: LR BRZ Limited
4x4 squares work well.
05-25-2014, 10:47 PM | #33 | |
Member of the year - 2016
Drives: Scion FRS
So the metal on the pinch weld is exposed? Just get some good spray paint and go to work. It's the bottom of the car, i don't know about you but i could care less what it looks like underneath. You could also get the color of your paint in a spray can and give the area a few coats.
The Following User Says Thank You to dem00n For This Useful Post: | Augora (05-26-2014) |
05-26-2014, 12:38 AM | #34 | |
Also read "Valvoline Tectyl 506" as an option. Guess I'll go with whichever I find first in autozone. |
10-11-2015, 09:23 PM | #35 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
The Following User Says Thank You to Astroboy For This Useful Post: | Packofcrows (10-12-2015) |
10-12-2015, 03:45 AM | #36 |
Drives: 86
Cut up a pair of rubber slippers that can be bought at WALMART and place between the weld and jack stand
86 SESSIONS on Facebook! |
The Following User Says Thank You to HATED1 For This Useful Post: | DarkSunrise (10-12-2015) |
Similar Threads | ||||
Pinch weld jack point paint damage? | Ingen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 10-12-2015 08:43 AM |
Car's sitting on jack stands while waiting for new wheels. | hanabie | DIY (Do-It-Yourself) Guides | 9 | 02-08-2014 02:03 PM |
Jacks/stands around central nj? | Reflex | NY / NJ / CT / PA | 9 | 09-13-2013 11:30 AM |
ramps + jack stands | so26 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 04-23-2013 04:43 PM |
protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 09:36 PM |
