07-21-2015, 08:11 PM | #2381 |
NASA SpecE30 Racer
Interesting.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | blackfireball5 (07-21-2015) |
07-21-2015, 08:50 PM | #2382 |
DADA
Drives: 2013
@blackfireball5 I have rust in that same spot, will do this mod. Thanks!
The Following User Says Thank You to mashal For This Useful Post: | blackfireball5 (07-21-2015) |
07-22-2015, 10:46 AM | #2383 |
Drives: 08 WRB WRX STi / NA Miata
Shouldn't that rust be covered under warranty?
It's based on a RWD Corolla, what do you expect?
07-22-2015, 10:51 AM | #2384 |
Drives: Scion FRS Firestorm
The Following User Says Thank You to blackfireball5 For This Useful Post: | P86RAVES (07-24-2015) |
07-23-2015, 11:48 AM | #2385 |
Drives: too many to list
was this short lived? I had the same issue with my wife's but after a few start/stops it was better. A few of the Subaru's do this after resetting the ecu/flash for the first bit, I'm only guessing its a ecu learning kinda thing
07-23-2015, 12:41 PM | #2386 |
Turbo E85
Drives: 13 wrb brz
delcious sent me a map sensor and my car now runs properly with the flash and go kit. it did not work properly using the map sensor that fullblown provided me. but the tune fullblown provided me with there map sensor worked fine.
Flex Fuel Turbo BRZ
08-06-2015, 11:15 AM | #2387 |
AC in texas
Does anyone have problem with AC blowing hot air in Texas after idling for while or stop and go traffic for too long?
I have the FBM radiator fan + shroud. The ambient temp was ususally about 97F+; however, same temp in a garage does not see problem like this. Is this something a tune can fix? |
08-06-2015, 01:27 PM | #2388 |
NASA SpecE30 Racer
Nope. The only way to fix it would probably be to add a pusher fan to the A/C condenser. I had the same issue. I just accepted it.
- King Tut
08-06-2015, 09:52 PM | #2389 | |
DADA
Drives: 2013
08-06-2015, 10:02 PM | #2390 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
You are asking more of the system than it is designed for. Anything over 95deg F ambient air temp is outside the range of efficiency.
08-08-2015, 07:03 PM | #2391 |
Drives: 2014 BRZ Limited [6MT/SWP]
Did some re-running of vacuum lines and hoses last night, as well as installed a vacuum distribution block, an ATP Turbo-Tap, and ran the top vent of my AOS to another silicone coupling. Anyone have any negative feedback on any of these? Not sure how well the Turbo-Tap will hold up (for now it works great), or if venting my AOS into the air intake will draw up oil into the turbo.
The Following User Says Thank You to Jhood For This Useful Post: | BRZtoni (08-12-2015) |
08-12-2015, 03:52 AM | #2392 | |
Drives: 86 GTS
Drove the car up there and used his vacuum tester found out that it was the FBM intake pipe was leaking like a bitch where the MAF sensor mounts. Issues 1. the tapped holes to mount the MAF sensor are drilled straight into the intake pipe with leaks through both screw threads. 2. The MAF plate is far from level causing leaks past the O ring I thinking of just throwing the intake pipe away or at least cutting it up and mounting a decent MAF sensor mounting plate that isn't uneven and drilled through |
08-12-2015, 11:46 AM | #2393 |
Turbo E85
Drives: 13 wrb brz
@Jhood im using a turbo tap as well boosted 9PSI. so far so good
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post: | Jhood (08-13-2015) |
08-13-2015, 10:08 PM | #2394 |
Drives: brz
a minor question, how do you guys deal with the overwhelming EWG noise on the daily basis? Would re-routing the wastegate dump tube back into downpipe decrease the noise significantly?
Tags |
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
Similar Threads | ||||
AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
