Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-16-2015, 02:58 PM | #1 |
Drives: Scion FR-S Whiteout
Faint, high-pitched whistling sound
Anyone else having this issue?
2013 Scion FR-S
04-16-2015, 03:01 PM | #2 |
You nailed everything I thought of at first.
Vacuum leak someplace?
The Following User Says Thank You to Tcoat For This Useful Post: | SteveGrillo (09-15-2015) |
04-16-2015, 03:39 PM | #3 |
If there is one, it would affect my MPG somewhat, and I'm still in the 23-26 range. Exhaust still sounds normal.
2013 Scion FR-S
04-16-2015, 03:43 PM | #4 | |
Have had that sort of sound you described from collapsed vacuum lines or very small holes that didn't impact the actual system before in other cars. They are an absolute bitch to track down!
04-16-2015, 04:27 PM | #5 |
http://www.ft86club.com/forums/showt...light=vac+leak
This hose is still attached properly, as far as I can see.
2013 Scion FR-S
04-16-2015, 04:39 PM | #6 |
I'm assuming that this occurs while driving?
04-16-2015, 04:45 PM | #7 |
Yes.
> Cannot reproduce if the car is parked and I rev
2013 Scion FR-S
04-16-2015, 04:51 PM | #8 |
Chance that is a wind noise through the grill or from around a headlight or turn signal?
04-16-2015, 04:52 PM | #9 |
That matches the RPM?
2013 Scion FR-S
04-16-2015, 04:56 PM | #10 |
So you're only hearing it at a specific RPM range in each gear and not once you reach a certain speed?
04-16-2015, 04:59 PM | #11 |
Nope, across all range regardless of speed, but the car has to be moving, which is so weird. It gets subtly louder with increasing RPM.
2013 Scion FR-S
04-16-2015, 05:05 PM | #12 |
Drives: 2013 Firestorm FRS
get up to speed and throw the car in neutral? Just to make sure its not a wind noise from airflow
determines if its from the engine, or car |
The Following User Says Thank You to continuecrushing For This Useful Post: | retrosmiths (04-16-2015) |
04-16-2015, 05:07 PM | #13 |
That would tend to eliminate the throw-out bearing (if it's a manual trans.) Since you only hear it while moving my next thought would be a dust shield rubbing on a brake rotor.
What Shutter said ........... |
The Following User Says Thank You to White64Goat For This Useful Post: | retrosmiths (04-16-2015) |
04-16-2015, 05:17 PM | #14 |
Alright, let me try this later on the way home. Good call.
2013 Scion FR-S
Similar Threads | ||||
Faint Honking sound | Raven604 | Issues | Warranty | Recalls / TSB | 117 | 07-14-2023 05:04 AM |
Whistling sound..? | tintumz22 | Issues | Warranty | Recalls / TSB | 34 | 11-21-2015 08:54 PM |
not very loud, but high pitched sound at 70+mph | fiveoneoh | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 10-16-2013 10:30 PM |
High pitched whine from sound tube and idle jumping | Nourdmrolnmt1 | Issues | Warranty | Recalls / TSB | 0 | 04-17-2013 11:00 PM |
TSB - FRS (re: High pitched chirping...) | PNW FRS | Issues | Warranty | Recalls / TSB | 1 | 01-19-2013 01:05 AM |
