Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-02-2019, 08:16 AM | #16 |
Drives: 2017 Subaru BRZ
12-02-2019, 08:43 AM | #17 |
Has anybody said it is normal?
12-02-2019, 08:48 AM | #18 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
12-02-2019, 01:21 PM | #19 |
Software Hobbiest
Drives: 2015 FRS
Millers 75w-90NT is best
From my experience good cold shifting low sheer resistance. i.e. putting in gear Motul gear300 is second best good cold shifting. med sheer resistance. a little harder to get into gear but still good I wouldnt use any other fluid in the trans if you want cold shifting. |
12-02-2019, 02:27 PM | #20 |
12-02-2019, 02:31 PM | #21 |
Wes
I sort of had this problem and I just kept switching out trans fluid. First I tried Motul, then Redline, then Motul again. Gradually it went away and I never ever find it difficult to put it into gear anymore, no matter the weather
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | j_ros94 (12-02-2019) |
12-02-2019, 09:47 PM | #22 |
ProCrastinationConsultant
or post #2...
12-03-2019, 09:17 PM | #23 |
¯\_(ツ)_/¯
12-03-2019, 10:55 PM | #24 |
it's technically rev-matching, but i'm not revving above 1500rpm at the most.
i noticed a while back that if i held the stick against the syncro while everything was cold and it didn't want to go into 1st, it would go as soon as the revs matched. so i just barely blip the throttle to get the motor falling in revs the same time the car is coming to a stop to widen the 'sweet spot', and not push so hard on cold syncro's.
The Following User Says Thank You to soundman98 For This Useful Post: | Tcoat (12-04-2019) |
12-04-2019, 08:20 AM | #25 |
Drives: 2013 Rally Blue w/Bronze wheels MT
If you upgraded the clutch and pressure plate you may have a bad fork
Vyse | How fast can you afford to go | Etc...
12-04-2019, 07:07 PM | #26 |
12-04-2019, 08:23 PM | #27 | |
therefore, our cars must have a engin-otor!
The Following User Says Thank You to soundman98 For This Useful Post: | solidsnake11 (12-04-2019) |
12-04-2019, 11:33 PM | #28 | |
"Motor and engine are interchangeable in standard English. In some engineering jargons, the two words have different meanings, in which engine is a device that burns or otherwise consumes fuel, changing its chemical composition, and a motor is a device driven by electricity, air, or hydraulic pressure, which does not change the chemical composition of its energy source". Therefore: All motors are engines but not all engines are motors. Got it? Now, I got to get on with paying my bills. Yes, I pay them by check, not auto deduction. Why? It's a throwback to the times when I couldn't pay them all at the same time. Started by paying the ones that said "final notice". humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | BlueLine (12-06-2019), soundman98 (12-04-2019) |
Similar Threads | ||||
Even Gears | rns294 | Engine, Exhaust, Transmission | 1 | 04-12-2017 09:52 AM |
Any one have 5.29 gears yet ? | ogie Oglethorpe | Engine, Exhaust, Transmission | 13 | 09-17-2016 11:17 AM |
Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 12:48 AM |
2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 05:09 PM |
