Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-02-2019, 07:39 AM | #43 |
Drives: 2016 Scion FRS
I know track days are a little different, but for autox…
Even at stock power, there are huge benefits going to a 245 on a 17x9 wheel. I can't really imagine any performance scenario where you wouldn't want at least a 245 wide wheel at any power level. |
The Following User Says Thank You to steverife For This Useful Post: | strat61caster (12-02-2019) |
12-02-2019, 10:05 AM | #44 | |
Your plan for 225s now, 255s later with FI is good. Get some experience and skills as is and you'll be more ready when the time comes in the future. - Andrew |
12-02-2019, 11:50 AM | #45 | |
Drives: Crapcan
If you check out rice_classics thread on his SCCA T4 car, they came to a similar conclusion. |
12-02-2019, 12:24 PM | #46 | |
In the context of street tires and the freedom to run an appropriate wheel (say a 17x9), the 245's will pay dividends, even on stock power. |
12-02-2019, 12:52 PM | #47 | |
Drives: Crapcan
12-02-2019, 12:55 PM | #48 | |
Drives: '13 FRS - STX
The 949 car was on 255s iirc. |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (12-04-2019) |
12-03-2019, 08:49 PM | #49 | |
CSG did a ton of testing, and found that on most tracks a 225 is faster than a 245 on stockish power (not FI). Autox is very different because speeds are lower and you spend way more time (as a percentage of run time) cornering and way less time WOT in a straightaway.
The Following 2 Users Say Thank You to wparsons For This Useful Post: | Captain Snooze (12-04-2019), churchx (12-04-2019) |
12-04-2019, 12:35 PM | #50 | |
The average driver will usually find more value in a larger tire giving them more thermal capacity, rather than seeking the theoretical "fastest" setup that they may not be able to fully exploit. |
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
12-04-2019, 01:18 PM | #51 |
Weight Weenie
Drives: 15 FR-S
FWIW, I've been running 205 RS3's on track for the last couple of years. They run as wide as stock 215's and because of the narrow width have taught me a lot about car control.
Narrow tires = fun |
The Following User Says Thank You to new2subaru For This Useful Post: | NoHaveMSG (12-04-2019) |
12-04-2019, 06:27 PM | #52 |
Drives: 2013 Scion FRS white
There could be many suspension issues; I have no idea on that. I can tell you that what you are experiencing is likely a direct result of going with a much wider tire. I run 245s and noticed a difference so your will feel even worse. Its what happens when you run wide wheel/tires. Running a different tire probably wont even help you because 4s should already be pretty stiff high performance tire.
12-06-2019, 03:03 AM | #54 |
Something to read > https://mcasuspension.com/technical
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
12-24-2019, 03:08 PM | #55 |
Drives: 2013 ARGENTO A/T
I had these exact symptoms after lowering and changing to a lighter 17x7.5 wheel so I would not count on wider wheels being a factor. The hard truth that I have learned about this platform is that because it is so finely tuned from the factory, it becomes very clear that handling won't get much better once you start tweaking even the most minor things. You have so much room to screw things up and very little of not zero room for improvement.
12-24-2019, 05:27 PM | #56 |
You have clearly not experimented with camber yet.
Similar Threads | ||||
2013s less responsive than 2017s? | 370zBRZ | BRZ First-Gen (2012+) -- General Topics | 25 | 07-28-2018 05:24 PM |
Car feels a little less peppy | Riftur | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 04-15-2018 06:02 AM |
Which entry level turbo kit is the most responsive? | Keenercarguy | Forced Induction | 54 | 04-18-2017 03:40 AM |
Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 08:18 PM |
18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 06:42 PM |
