Old 07-14-2017, 08:51 AM   #701
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Originally Posted by DustinS View Post
Forgot I followed another V8 swap FRS on facebook. Today they posted about traction control and ABS all of a sudden working again. Trying to figure out of the lights just turned off as it has canbus system back up and running, or if they actually are working again. I am assuming they just took the fact the lights are off and the traction light flashes at them that it works again, but doesn't actually control anything.
Getting both of these systems working isn't impossible by any means with a factory calibrated PCM. The systems existed in the vehicle they came from, they can be implemented again in another chassis. Fully understanding both vehicle's systems, value scaling, and implementation methods is the trick
Heck if someone wanted their ABS and Trac lights off, I can do that too with some code. Not saying this is what AGT has done though. I honestly don't know.
To be honest, implementing traction control in a standard product like mine would be pointless as everyone has wildly different cars with wildly different setups. I don't know what tables modern PCM's have unlocked from HPT and other tuning suites, but it would be a lot of "tuning" to get a good traction control strategy out of a completely different car.
ABS is probably a lot easier to do.
More power to more people getting things like this done. I don't want to be the only one out here making products so people don't have to buy massive standalone systems. Last I checked the AGT approach was to remove the factory ECU from the system. I'm not sure if this has changed.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 07-14-2017, 09:44 AM   #702
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yeah it was Mad Panda. They finally replied, As I Suspected the lights turned off and traction/ABS don't actually work. They are still working on it.
Colin - My lights aren't on. Traction Light just Flashes telling my I am spinning. Which I don't mind. Lets me know I need better tires. Spinning through 4th isn't the best thing in the world. Especially not when trying to have some fun haha.
On another note. I keep blowing exhaust gaskets. This last time I went with good vibrant gaskets and it still ended up leaking. I am going to cover it in some high temp copper sealant and hope it seals correctly.
Edit: The Oil Pressure issue has been driving me nuts. I was going to just wait to grab the AIM early Next year, but I am not sure I can wait that long. Went ahead and grabbed a set of the VLS Oil Pressure and Oil Temp Gauges. Always getting asked for rides, which I am more than willing to fulfill. Last night after one lap of the ride. Idle Oil Pressure was showing about 12-15 PSI. WOT pulls oil pressure gauge wouldn't move until pull was over. So I HIGHLY suspect oil pressure gauge is dead. Either sensor is broken, or gauge itself. That or engine is holding together extremely well and is about to blow up haha. Should be here early next week.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (07-14-2017)
Old 07-14-2017, 04:46 PM   #703
cf6mech
Drives: FRS Silver LS1 swapped.
That sucks on oil presure, you absolutely sure you got a good oil pump?....as far as exhaust gaskets....have you thought of putting two gaskets on instead of one in case the reason you are blowing them is they are not fitting perfectly flat against the mating surface?.....as a reference my oil pressure in Texas heat 90+ to 100 degree with a mocal oil cooler never goes below 20 psi at idle and fully heated is at 40 psi plus at 2k cruise....start up its at 60 cold then comes down....moble 1 5w30.
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
Scrappydoo (07-14-2017)
Old 07-14-2017, 08:44 PM   #704
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I'm a big fan of copper header gaskets. I've never had them blow and they work well with imperfect surfaces. I have one header bolt that is snapped and it seems to be sealing well despite missing that.
wutsaiu is offline   Reply With Quote
Old 07-15-2017, 10:15 AM   #705
all4spl
UGH This is making me want to get my swap done asap! If only the A/c worked.. This week has been brutal with the heat and I would NOT be able to daily my frs without A/c
all4spl is offline   Reply With Quote
Old 07-15-2017, 07:11 PM   #706
wooly35
Drives: 2014 Scion FR-S LS3
Do it! Windows down and enjoy. This car is too much fun to worry about a/c. lol
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following 3 Users Say Thank You to wooly35 For This Useful Post:
cf6mech (07-16-2017), DustinS (07-17-2017), wutsaiu (07-15-2017)
Old 07-17-2017, 10:12 AM   #707
all4spl
When you have to wear a suit every day with multiple layers, you kind of need the AC haha
Old 07-17-2017, 10:15 AM   #708
DustinS
DustinS's Avatar
No A/C has been miserable. Traveling 10 hours for the Honeymoon. Planning on filling a container full of Ice or Dry Ice and putting a fan on side, and dryer vent tubes on the other side going to the front of the car haha
Had a friend of mine do a fly by so I could get a video of the car/exhaust. He said the car was way different from when it was turbo, and he never did go WOT (I think it kind of scared him). So the exhaust video didn't really come out how I wanted. Though there was a lot of traffic for some reason, so don't really blame him. I will have to get a better one on an empty street.
[ame="http://youtu.be/pD6GUEMC6eo"]http://youtu.be/pD6GUEMC6eo[/ame]
The Following 2 Users Say Thank You to DustinS For This Useful Post:
andy0323 (02-10-2018), Sportsguy83 (07-17-2017)
Old 07-17-2017, 02:04 PM   #709
all4spl
what axles are you running?
Old 07-17-2017, 02:05 PM   #710
DustinS
DustinS's Avatar
DSS 600hp Axles. Hopefully I don't have to upgrade too soon.
Old 07-17-2017, 02:33 PM   #711
all4spl
Do you think they are truly rated to 600? how much power are you looking to make?
Old 07-17-2017, 02:36 PM   #712
DustinS
DustinS's Avatar
Absolutely not haha. They are surprisingly weak from everything I have seen. As much as I can N/A. Soon tuned on E85.
Then eventually slap a couple GT35s and see what kind of wild street car I can make while still hopefully being able to handle well.
Old 07-17-2017, 02:55 PM   #713
all4spl
I'm wondering if it's worth it to pick up a set of the 600's then. I'm still on stock axles.
Old 07-17-2017, 04:13 PM   #714
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The DSS axles are not that weak (At least from what I've seen from people who are on mild drops). People start snapping them because they're too low and the axle angle gets on the extreme side quickly on this cars. Anything below 1.5-2" drop is already putting a big strain on the axles.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) -- General Topics 8 06-12-2012 07:32 PM
