05-16-2019, 10:34 PM | #85 |
Drives: FT86
05-16-2019, 11:13 PM | #86 |
Drives: 2014 Toyota FRS
05-17-2019, 08:42 AM | #87 |
Drives: WRB BRZ
Yes, the traction control toggle that you see in the app now actually simulates the pedal dance. Traction control, VSC, ABS, and EBD are all off when toggled. The in-car traction control button only turns off the first two.
The Following User Says Thank You to Fred E For This Useful Post: | Celigts (05-17-2019) |
05-17-2019, 08:48 AM | #88 |
Drives: brz 2017 hksv2
i do not understand why it toggles also a abs light in the dash, normally pedal dance only disable e-diff and not abs
05-17-2019, 10:49 PM | #89 | |
Widebody ... big ass tires ... or some unknown speed sensor issue. The world may never know. |
06-08-2019, 01:59 PM | #90 |
Drives: 13 White MT FR-S
Do you need a license to use the pedal dance feature with this?
The Following User Says Thank You to ML For This Useful Post: | Celigts (06-09-2019) |
06-09-2019, 10:16 PM | #91 |
06-10-2019, 11:25 AM | #92 |
Drives: 14 BSP Edelbrock BRZ
There are 2 different bluetooth modules available online that I see. One is bluetooth+proECU for ~$375 and one that is just bluetooth for ~$210. If I have the old cable/dongle setup for programming I can get the cheaper one and still have access to everything but flashing, correct?
06-10-2019, 11:36 AM | #93 |
you can also flash
just neee the old dongle that you have with the old. cable |
06-13-2019, 11:47 AM | #94 |
So I got the bluetooth module. First thing it did was install updates. The button I see for Traction Control only seems to turn of the regular traction control, not the pedal dance (only traction light is lit, not vsc). Other people see something different?
06-13-2019, 12:36 PM | #95 |
vsc should not light, trc light is good
06-14-2019, 03:57 PM | #96 |
Could someone create a blank dashboard template and attach it on here? I have a Pixel 3 XL and the default dashboard adds two buttons at the bottom that are half off the screen and I can't grab them to move or delete them because they are behind the shaded area for adding or removing widgets.
07-24-2019, 08:27 PM | #97 |
Drives: BRZ Turbo
Does anybody know if it's possible to add or show peak values? Eg peak boost?
07-25-2019, 03:38 AM | #98 |
Drives: 2017 Toyota 86
Mine turned everything off including ABS.
Similar Threads | ||||
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM | DeliciousTuning | Software Tuning | 329 | 12-31-2023 03:47 AM |
My Bluetooth in my 2014 FRS so stay connect | Case1010 | Electronics | Audio | NAV | Infotainment | 3 | 02-24-2016 06:57 PM |
Header/overpipe interface | misooscar | Engine, Exhaust, Transmission | 4 | 11-22-2014 11:21 PM |
Garmin GPS Bluetooth Won't Connect | frssfo | Electronics | Audio | NAV | Infotainment | 0 | 08-20-2014 10:55 PM |
Bluetooth connect mutes android NAV | Rob_g | Electronics | Audio | NAV | Infotainment | 6 | 07-04-2012 04:38 PM |
