Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Tracking / Autocross / HPDE / Drifting
Old 05-03-2019, 02:29 PM   #57
justint5387
Drives: 4 wheels
Originally Posted by oinojo View Post
They bought the car with the diff and never ran stock. They're too cheap to buy an OS outright
Hey I bought 2 from you. Mazdaspeed 3 and 370z!
justint5387 is offline   Reply With Quote
The Following User Says Thank You to justint5387 For This Useful Post:
strat61caster (05-03-2019)
Old 05-06-2019, 07:46 AM   #58
M0nk3y
Originally Posted by justint5387 View Post
I think Kyle is trolling me. lol
I would never do such a thing
See, I lost at NJ Pro. That should tell you enough that clearly the header is not optimal
Kyle H. - #89 STX
Old 05-07-2019, 01:22 PM   #59
justinco
btr.life
justinco's Avatar
Drives: e36 BMW
Below was my latest setup before I sold the car. After testing many setups and different things, it worked amazingly well with this configuration and was finally predictable and responsive to adjustments. Now I'm gonna go cry because I miss the car so much...
2017 BRZ Limited
Suspension:
MCS 2-way remotes
Front spring rate: 280 (5k)
Rear spring rate: 504 (9k)
Raceseng Camber Plates
Vorshlag rear shock mounts
Camber: -4.2* front, 0 toe / -2.8* rear, little bit of toe in
Perrin 22m front bar on stiff
Mann Eng rear bar on stiff
RaxerX end-links all around
DIF rear LCA
DIF steering rack bushings
Whiteline rear subframe, shifter, and diff bushing inserts
Engine:
Stock intake with Blitz filter
Perrin inlet tube
ACE A-350 EL header
JDL ultra quiet front pipe
Dezod dual exit exhaust
Delicious tuned ECUtek 91 and 93 octane tunes
Wheels, Tires, Other:
AP Racing Sprint BBK / Ferodo DS2500 pads
Weds TC105N 17x9 +35 with 255/40 RE71R
OS Giken STX tuned diff
Shorai lightweight battery
Sparco EVO seats with Buddy club mounts
1994 BMW 325is - Project 325 HPDE/TT | 2013 Scion FRS - Project FRS STX | 2017 Subaru BRZ - Project BRZ STX
justinco is offline   Reply With Quote
The Following 3 Users Say Thank You to justinco For This Useful Post:
Clutch Dog (07-31-2019), fika84 (05-07-2019), smg1138 (05-07-2019)
Old 05-07-2019, 03:11 PM   #60
steverife
2017 BRZ Limited
Suspension:
MCS 2-way remotes
DIF rear LCA
Engine:
Perrin inlet tube
ACE A-350 EL header
Did you ever run your car without the Giken?
steverife is online now   Reply With Quote
Old 05-07-2019, 03:43 PM   #61
justinco
btr.life
justinco's Avatar
Drives: e36 BMW
Yes, 2016 season in my FRS and 2017 season in my BRZ was OEM diff.
Old 05-07-2019, 10:31 PM   #62
M0nk3y
Just IMO - Lugodís setup (basically what Justin had) is heavily influenced around running an OSG Diff.
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
justinco (05-07-2019), steverife (05-08-2019)
Old 05-07-2019, 10:57 PM   #63
justinco
btr.life
justinco's Avatar
Drives: e36 BMW
Yep. When I didn't have the diff I ran 400 or 450 rates square, same front bar on soft and 14mm rear.
Sent from my SM-G973U1 using Tapatalk
The Following User Says Thank You to justinco For This Useful Post:
Old 05-08-2019, 08:23 PM   #64
oinojo
STAC Member
oinojo's Avatar
Drives: 2015 Ford Focus ST
The setup is made to make better use of the front bar to add overall stability and transition like a surgeon. Diff type DGAF as long as its open on entry.
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
The Following 2 Users Say Thank You to oinojo For This Useful Post:
justinco (05-08-2019), justint5387 (05-09-2019)
Old 05-13-2019, 11:34 AM   #65
snoxracer183
Drives: 2014 FR-S SSC
I run 7k square rates with an OEM diff on a fairly bumpy lot now and have noted a bunch of inside wheel spin due to the rough surface. Trying to band-aid that problem with shock tuning made for a car that didnt handle as well. If we continue to only have bumpy surfaces I think i'm going to have to look into a clutch type LSD to help get any sort of drive out of corners.
Just another variable for people the think about when deciding on OEM/Aftermarket LSD
-Eric K - Milwaukee Region SCCA - 2014 FR-S
snoxracer183 is offline   Reply With Quote
Old 07-19-2019, 12:05 AM   #66
408brz
408brz's Avatar
Drives: 2013 SWP Subaru BRZ Limited
I just finished first pass upgrade from DS to STX on 2013 BRZ with
ProParts Megans - 400/400
22mm Perrin on soft
Verus LCA with STX hardware (FT86SF)
JDL 4-2-1 EL, ACE overpipe (CSG)
Stock front pipe, milltek resonated catback
HPS Tube, Cosworth filter
Delicious custom tune on Mann dyno
245/40/17 REs
17x9 Enkei +35 (Oakos)
Stock pads
The engine work just finished and last on board, it felt great on a stock header so now I'm looking forward to upcoming events with the tuned JDL.
408brz is offline   Reply With Quote
The Following User Says Thank You to 408brz For This Useful Post:
strat61caster (07-19-2019)
Old 07-31-2019, 07:52 AM   #67
steverife
I already asked Kyle this, but where has everyone set their limiter?
Old 07-31-2019, 01:04 PM   #68
justinco
btr.life
justinco's Avatar
Drives: e36 BMW
I ran 7800 on my 2017 BRZ, needed that, and 255's, for the extra MPH (62-63mph in 2nd gear).
My FRS was on OFT with 7550 limiter and 245's, it would do 61mph in 2nd gear.
Old 07-31-2019, 01:52 PM   #69
CoolHandMoss
Drives: 2013 FRS
I ran 7800 on my 2017 BRZ, needed it (and 255's) for the extra MPH. It was unchanged on my FRS as it still did 62-63mph with stock limiter and 245's.
what did you get to at 7800 on 255s?
CoolHandMoss is offline   Reply With Quote
Old 07-31-2019, 02:28 PM   #70
justinco
btr.life
justinco's Avatar
Drives: e36 BMW
62-63mph
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 09:58 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 01:05 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 311 05-18-2018 02:01 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
