Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-11-2012, 12:16 PM | #15 | |
Drives: Hydra EMS Powered FRS Raven Black
If the fuel evaporates before it reaches the combustion chamber you will not have as much cooling effect. Therefore if you spray the E85 directly into the combustion chamber you have a greater cooling effect along with the extra cooling effect you get from the evaporation of ethanol vs. gasoline. |
07-11-2012, 01:41 PM | #16 | ||
Drives: N/A
Arghx7, was that the "E85 boost" engine that was showcased several years ago? It had a separate but smaller fuel tank for E85 that was designed to last multiple fill ups due to it only used E85 under heavy loads. |
07-11-2012, 03:03 PM | #17 | |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
07-11-2012, 03:45 PM | #18 |
Oh Phil - are you guys just running on 100% port injection with the Hydra?
07-11-2012, 04:23 PM | #19 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Possibly a noob question, but I'm curious; how many port injectors does the FR-S/BRZ have?
07-11-2012, 04:41 PM | #20 | |
Drives: N/A
4 just like any other 4 cylinder multi port fuel injected engine. The difference is there are 4 more direct injectors, one inside each cylinder. |
07-11-2012, 04:53 PM | #21 |
Tall guys fit, too.
I thought so, but wasn't sure. Thanks!
07-11-2012, 04:54 PM | #22 |
Drives: 2009 135i
curious to see the spray pattern of the oem injectors vs your aftermarket ones.
The Following User Says Thank You to bimmerboy For This Useful Post: | Toma (07-17-2013) |
07-11-2012, 09:20 PM | #23 |
Yes until we finish the direct injection strategy which i migh have befoe UTCC. For now I'm 100% port injection and E85. I've been tweaking cam maps for now and as of today the car finally has that intake roar and pull I've been after! Its audibly obvious when you have the overlap right.
07-11-2012, 10:05 PM | #24 |
Drives: car
That was a Ford program, using direct injected E85 as a knock suppressant for a twin turbo 5.0 engine (or something built off that architecture). It was intended as a possible replacement for a diesel, because of the expensive emissions equipment required for diesels. I know a few guys who worked on some of the testing of the prototypes. I'm not sure if the program is still around or not. That was in-house stuff done in Ford's Michigan labs to explore a specific commercial application. This information I'm referring to is an MIT study released in April with funding from a group of companies including GM. It's more about basic R&D and was not part of developing a specific engine.
07-11-2012, 11:26 PM | #25 | |
Drives: N/A
I think it's this one: http://www.ethanolboost.com/ |
07-16-2012, 11:28 AM | #26 |
Hydra EMS has started working on the direct injection code for me after analyzing the OEM scopes of the DI system. It's very interesting and enlightening and we'll have no problems adapting this version of D4S system into the current Hydra EMS hardware.
We will be adopting the OEM direct injection and port injection strategy mostly but we are going to leave DI timing tunable so should I find benefit as we boost this engine we'll have that option to change timing based on load. Based on the direct injector pulse width at idle I'm going to estimate the OEM direct injector flow is around 400-450cc. As RPM gets towards redline and both the port and DI injectors are firing the total pulse width would suggest less flow however than the sum of both injection systems. Regardless there seems to be plenty of injector pulse width left to play with between the two systems. The torque drop off in the 4k rpm range can be seen in the injector pulse width scopes also. Clearly a VE drop off there but that will tune out nicely with a turbocharger system As it sits I think we can get away with some low boost turbocharger systems on the OEM fuel setup but at higher boost levels at least a rising rate fuel pressure regulator is going to be needed for the port injector system. Thanks, Phil Grabow |
08-27-2012, 02:33 PM | #27 |
Drives: 2003 Bugeye STi
Hey Phil, I'm happy to see the work you're doing here and that you're sharing it with everyone, thank you for that. I've followed your race program for a long time as a Subaru owner and its great to see you with a new project here with the FR-S.
I wanted to let you know that we do have some great injector upgrades available for the FR-S and BR-Z. If your development takes you this way I'd love to help you out with an injector solution to fit your setup. We have the following sizes available: 660cc 770cc 1100cc 2150cc We also have a 900cc option available IF it is possible to space the fuel rail up slightly to accomodate the extra height of this injector. This is a perfectly normal solution and something commonly done on other applications, but it will come down to whether or not you have the physical height to move the rail up slightly without any obstructions. The 1100cc injector listed above has the same extended tip as the stock injector, whereas the others I listed have a normal short tip. Either setup will be fine for this car as we have not found any discernible differences in real world results for fuel economy or performance going between the two tip styles. Also arghx7... thanks for posting the info about port and direct injected E85 octane and temperature differences... it is really interesting to see the data comparison there. I'm going to subscribe to this thread to follow along with the progress here and of course if anyone has any questions just let me know and I'll try to help out. |
The Following User Says Thank You to Fuel Injector Clinic For This Useful Post: | DAN_BRZ (03-22-2015) |
11-14-2012, 12:19 PM | #28 |
Thank you for your input on injector options. I didn't subscribe to my own thread and didn't notice you posted. I've been a little quiet lately as I shipped my FRS after the Ultimate Track Car Challenge to Hydra EMS in California so they could accelerate the direct injection/port injection strategies in the Hydra EMS along with all the sophisticated CAN bus based systems.
In any event the Hydra EMS is finished and it's going to be amazing and will solve many issues people currently have with forced induction and reflashing. I still have my work cut out for me as I'm responsible for all the performance tuning and maps. There is room to move the rail up as I did this so as we progress with supercharging and or turbocharging we'll be in touch about an injector solution. Thanks, Phil Grabow |
Similar Threads | ||||
Interesting factoid... | Opie | BRZ First-Gen (2012+) -- General Topics | 13 | 07-04-2012 09:23 AM |
Interesting graphics on a 86 | ESBjiujitsu | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-11-2012 11:16 PM |
Interesting news about BBS | Esoteric | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 02-17-2012 06:10 PM |
Why ft-86 is interesting? | NewCarInQ42011 | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 11-26-2010 04:05 PM |
