Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Off-Topic Discussions > Other Vehicles & General Automotive Discussions
Old 11-13-2019, 11:52 AM   #15
serialk11r
Drives: 2000 MR2 Spyder
Originally Posted by dhuang View Post
As far as the tub being CF or CFRP
Same thing -_-
Carbon filaments don't stick together. That's what the epoxy matrix is for.
Old 11-13-2019, 01:21 PM   #16
strat61caster
Thread Killer
strat61caster's Avatar
Drives: '13 FRS
Originally Posted by Takumi788 View Post
I don't know about ownership but I would defiantly rent one for a day.
I can just imagine you shouting at whoever is renting you the car "You can't stop me, I'm renting this damn car" and the person just sighing "I'm not trying to stop you sir please just take the keys and go". "I'm not having any of that give me my damn car!"
ineedyourdiddly
Old 11-13-2019, 01:50 PM   #17
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Originally Posted by Goingnowherefast View Post
I'll just leave this right here: https://shopeurocompulsion.net/colle...u-clone-system
They pick up SOOOOOO much power with a tune.
I'm running the Alfaworks Race ECU... so I'm going to guess 300+ HP / 320+ Torque @ the wheels.
I'm guessing I'm below 4sec 0-60 if the tires can hook.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
The Following 2 Users Say Thank You to dhuang For This Useful Post:
Irace86.2.0 (11-13-2019), korhun (11-13-2019)
Old 11-13-2019, 02:09 PM   #18
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by serialk11r View Post
Same thing -_-
I believe it is common knowledge that carbon fiber parts all have an epoxy/plastic matrix. The question is whether the carbon fiber is just loose filaments in a matrix like MDF or particleboard, or is it layered fabric injected or painted with resin which is possibly a strong shell over a weaker core of plastic, or is it pre-impregnated carbon fiber fabric like exotics. For a given volume or weight, some techniques will create a stronger product, and conversely, some techniques will allow for a lighter or smaller product for a given strength. Some techniques listed already, or other properties like the quality and size of the woven fabric, produce will produce different strengths and/or finishes.
https://www.extremetech.com/extreme/...bon-fiber-cars
After doing some research, it seems that the BMW i3 uses cloth with injected resin, so not a particleboard style like some manufacturers, but not pre-impregnated style like the Alpha Romeo 4C, which is more like exotic cars.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
dhuang (11-13-2019), korhun (11-13-2019)
Old 11-13-2019, 09:10 PM   #19
serialk11r
So which one is "CF" and which one is "CFRP"? They're all "CFRP" and they're all "CF". That's what the post I quoted said, "CF or CFRP".
As far as the difference between prepreg and wet, I believe when OEMs do wet layup they would have a process to ensure no voids and similar strength to prepreg. Forged composite parts are also quite strong despite chopped fibers. It's about getting the fibers closer together, whatever process used doesn't matter.
Old 11-13-2019, 10:47 PM   #20
Irace86.2.0
Yes, I understand your comment, and I am conceding that they are the same thing. It is just a common usage to use CFRP when referring to something that is a low or medium density fiber composite versus classically woven carbon fiber.
The article mentions that BMW injects resin into a mold under high heat and pressures. I have no clue if they can achieve a similar quality, evenness, finish and performance that comes from using pre-impregnated pieces; I have seen the 4C in person, and the exposed carbon is really nice.
Some of the forged composites look nice too, but there is no way they would be as strong as traditional carbon fiber just like how plywood, MDF, etc doesn't stand up to the strength of wood or layered wood.
Old 11-25-2019, 01:18 PM   #21
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Congrats man. Been on the Alfa 4C forum yet? It's not as "entertaining" as this forum, but plenty of good info.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
The Following User Says Thank You to Braces For This Useful Post:
dhuang (11-25-2019)
Old 11-25-2019, 01:48 PM   #22
dhuang
dhuang's Avatar
Yep I'm on 4C-forums -- more DIY'ers than I expected for this type of car.
2017 Series.Yellow
2013 Whiteout
Old 11-26-2019, 12:43 AM   #23
jflogerzi
jflogerzi's Avatar
God damn that's fantastic. I love the 4c but wayyyy out of my budget.
2013 Series 10 FRS #553
JDL 4-2-1 EL, Stock FP with Vibrant LN RES, MXP SP CB
Koing Hypergram 17x8 ET40 SX2 GTs 245/40/17
Sprintek 210+69mm+FF+Tuned by Zach@CSG
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
korhun (11-27-2019), why? (11-26-2019)
Old 11-26-2019, 08:09 AM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I hope they miraculously found some good reliability and stuck it in there so that when the value gets to normal car prices they can still be driven hard and not break.
why? is offline   Reply With Quote
Old 11-27-2019, 05:54 PM   #25
jflogerzi
jflogerzi's Avatar
Alfa Romeo 4C
"WHAT A CAR!!!"
Those were the words I screamed after I hit peak boost with both hands clutching the odd shaped steering wheel for dear life.
I understand why members like @Braces and @MarkR171 chose a 4C over say a //M-car or P-car.
Just like the BRZ / 86, a car cannot simply be measured by numbers. Smiles per gallon is the only metric I go by, and this little Alfa gives you plenty to overdose on.
One car is incredibly balanced, predictable, communicative, an amazing daily driver, and rewards good driving habits.
The other is a vice, criminally unique, abusive at slow speeds, constantly tries to kill you, and rewards bad behavior.
I'm lucky to have both sharing the same garage space.
Please post some Video's of that car when you get a chance
The Following User Says Thank You to jflogerzi For This Useful Post:
korhun (11-27-2019)
Old 12-01-2019, 03:52 AM   #26
dhuang
dhuang's Avatar
Here are some ricer flyby's with my immature popping ECU.
2017 Series.Yellow
2013 Whiteout
jflogerzi (12-01-2019), korhun (12-02-2019)
Old 12-01-2019, 11:04 AM   #27
jflogerzi
jflogerzi's Avatar
https://www.youtube.com/watch?v=6vjwL1YmJRI
I am not sure I like the pops and bangs. But love the car. Congrats again.
korhun (12-02-2019)
Old 12-12-2019, 12:18 PM   #28
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: 2017 WRX (sold), 2009 Lexus LS460
Originally Posted by korhun View Post
Glad they engineered it to take on more fuel.
ROFL it's Waffle is online now   Reply With Quote
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
korhun (12-12-2019)
I bought and totaled a BRZ. Then I bought another. unhappymeal Subaru BRZ General Forum 51 06-07-2017 07:54 AM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 04:57 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 09:32 PM
Perfect Run? yomchi1989 AUSTRALIA 4 01-13-2013 11:38 PM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 03:22 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
