04-10-2019, 05:51 PM | #533 | |
Custom User Title
All that said... for anyone just starting out who isn't ready to go all-in trying to challenge for trophies or national championships at the tour events I would still recommend DS if SSC isn't an option. Driving these cars in street spec is a great teacher for developing/improving some key skills and it translates to all platforms. If you spend 3 years running DS in a twin instead of an STI/Type-R/Fo-RS I'm confident you will develop your driving skills quicker. Every tiny mistake in these cars adds up to big losses in overall time.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
The Following 2 Users Say Thank You to Locust For This Useful Post: | strat61caster (04-10-2019), TMF (04-10-2019) |
04-10-2019, 09:37 PM | #534 | |
13 BRZ Limited 6MT Lightning Red
The Following User Says Thank You to j3rf For This Useful Post: | TMF (04-10-2019) |
04-10-2019, 09:42 PM | #535 |
Drives: '14 FRS TT5
I don't think you've driven on a set of Federal 595rsrr 's. They sound like industrial fans. Or a jet engine. I know summer tires are "loud" but you almost can't have a conversation with the Federals on.
Follow my NASA TT5 build here: JHill Motorsports
04-10-2019, 11:05 PM | #536 | |
Drives: 2017 BRZ PP , 2005 Saab 97X
and i used them on my S2000 for BSP in scca, and finally used them as practice tires on the communal San diego region CS ND1 miata and will be running them again on practice wheels with the FRS if you are concerned with noise then might I suggest Ironman G2 All seasons. of which I have for sale with only 2 autox events on them |
04-11-2019, 08:17 AM | #537 | |
Drives: '14 FRS TT5
I currently have a set on my race wheels but they are getting burned off tomorrow during the practice day and replaced with Hoosier's
The Following User Says Thank You to TMF For This Useful Post: | Clutch Dog (04-11-2019) |
05-09-2019, 07:57 PM | #538 |
Drives: 15BRZ
DS autocross ?
Anybody ever run their twin with the stock front sway bar and no alignment? and if so what did u experience? and when u added an aftermarket front sway what did u notice on the course? The reason for asking was i ran my BRZ at an autocross and felt like at any time the wheel was even slightly turned i was unable to hit the go pedal any more than about 25% due to oversteer and even trying to accelerate out of the end of a slalom the rear end was fishy as hell, and on a small crest with a turn i couldn't even think about stepping on the gas.... right now i just have old dunlop z2 tires which are better than the stockers at least. i wonder if alignment would help with the above issues also. i felt like i should have been able to give it more gas than i was able, i sure was with sport mode on. With all off it was really difficult. Sometimes i wonder if it is related to my old FWD bad habits...lol
05-09-2019, 09:04 PM | #539 |
Scott M
Drives: '13 BRZ (DocWalt's old car)
Depending on how bad your alignment is, that alone could be some of the issue. My guess though is it's old, not-so-grippy rubber or simply lack of surface grip.
My own well aligned car was the poster child for throttle oversteer at the first event of the season in light rain but was sticking like glue on a different course in steady drizzle next event.
13 BRZ (STX prep)
14 Lotus Evora S 06 BMW Z4M Roadster, 01 740i |
The Following User Says Thank You to Molez93 For This Useful Post: | KevBRZ (05-10-2019) |
05-09-2019, 11:06 PM | #540 |
Drives: '13 FRS - STX
Z2's are pretty old but I never found the car loose totally stock, I was on Z2SS for about two years and totally wore them out. I'd expect coarse driver inputs are causing the car to feel oversteery, if the alignment is bad that could be the problem but you don't know until you measure it, video to review is good, some guys on Reddit r/autocross will put time into giving you feedback on anything.
The Following User Says Thank You to strat61caster For This Useful Post: | KevBRZ (05-10-2019) |
05-10-2019, 02:07 PM | #541 |
Drives: 15BRZ
I am really rusty, first time out in 3 years except maybe one or two codrives, honestly on my flat driveway my car looks like it has Positive camber, so that could be an issue also. having some serious issue getting stock crash bolts.... ordered 2 times and got the wrong bolts both times, ugh!
The Following User Says Thank You to KevBRZ For This Useful Post: | strat61caster (05-10-2019) |
08-13-2019, 08:46 AM | #542 |
Drives: Toyota 86 TRD/SE
I autocrossed my 86 in DS for the first time Sunday. It was a lot more fun than my WRX. Two things it definitely needs right away.
1. Front Sway bar. I was looking at the 22mm Perrin front bar. Are there better options in the $200 range? Is the Hotchkis bar to much with the stock rear bar? 2. Wheels and Tires. There are not many 17x7.5 options that clean the brembos. I have been looking at some Konigs. Are there any other light options? |
08-13-2019, 11:17 AM | #543 | |
Drives: Yes
2. Enkei RPF1? I always thought it was tough to find a lightweight and strong 17x7.5 option even without needing to clear Brembos. You should be able to run 235 or 245 on 7.5 rims though! |
08-13-2019, 11:49 AM | #544 |
Drives: FR-S - STX
I thought 17x7.5 is for TRD or performance pack which is CS?
Sent from my Pixel 2 using Tapatalk |
08-13-2019, 01:56 PM | #545 |
08-13-2019, 02:31 PM | #546 | |
Drives: BRZ 2017 Pure Red, MT
If it has the same wheels as the standard edition, those wheels are 7.0". If your car edition has 7.5" wheels, it should be in CS. Edit: Also, if you have the bigger Brembo, you probably have the performance package, which include wider wheel (7.5"), better shocks (sacks shocks, but stock spring), and should be classed in CS I think (unless this changed recently). Last edited by nico_rsx; 08-13-2019 at 10:58 PM. |
The Following 2 Users Say Thank You to nico_rsx For This Useful Post: | BigTuna (08-13-2019), strat61caster (08-13-2019) |
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
