Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 06-03-2014, 01:14 PM   #1
Fred E
Drives: WRB BRZ
6MT Transmission Grind -> Warranty Replacement (Subaru)
Has anyone in central/south NJ or eastern PA experienced a repeating transmission grind when shifting from 3rd to 4th gear at an RPM greater than 5500 as described in these threads? (I'm sure there are more)
http://www.ft86club.com/forums/showthread.php?t=64281
http://www.ft86club.com/forums/showthread.php?t=37129
http://www.ft86club.com/forums/showthread.php?t=47531
http://www.ft86club.com/forums/showthread.php?t=57813
There are also many cases of a 4th to 5th gear grind, and thankfully, I haven't had that issue arise (yet).
If so, which Subaru dealership have you gone to? My experience at Subaru of Cherry Hill has been a joke. The service advisor I spoke to last night when dropping my car off said that I shouldn't be shifting that high, that it's not meant to go that high, and that just because the redline is at 7400, doesn't mean it should get that high. This morning, the advisor calls back and says they had two different technicians take my car out and collectively put on about 30 miles trying to reproduce the issue and were unable to. He said they were shifting "normal" despite my mentioning the night before that it happens during quick shifts (not even overly aggressive shifts). It's like it never occurred to them that one might drive a rear-wheel drive sports car in a...sporty manner. You'd think the dealership in the same city as Subaru of America's headquarters would be better than this.
If you haven't had this issue or your transmission replaced, what Subaru dealership did you have a good experience with when getting warranty work done? Did the service advisors understand the actual point of the car and not look at you like you're crazy for driving your car as it was meant to?
Thanks for any feedback!
Fred E is offline   Reply With Quote
Old 06-03-2014, 01:18 PM   #2
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Even if you do get your transmission replaced under warranty which many have. The problem always comes back as it was never fixed. I would just wait it out until they recall these transmissions. I have an issue with 5th gear at the moment.
Rocket.BRZ is offline   Reply With Quote
Old 06-03-2014, 06:52 PM   #3
Fred E
Drives: WRB BRZ
Yeah I think that's what I'm going to have to do. Question still stands though, for when that day does come: anyone have any recommended dealerships?
Old 06-04-2014, 06:17 PM   #4
shehan1212
shehan1212's Avatar
Drives: stock
And I heard that people have issues with going from 1st to 2nd gear too.
I have an AT. I shift at 7k all day long with no issues.
shehan1212 is offline   Reply With Quote
Old 06-05-2014, 07:41 PM   #5
dori.
Seņor Member
dori.'s Avatar
Drives: white BRZ 6MT
Hmmm, never really noticed problems like that. I have the typical difficulty putting the car into 2nd when the car's really cold
dori. is offline   Reply With Quote
Old 06-05-2014, 07:48 PM   #6
Rocket.BRZ
Don't worry in time the horrors will come. I promise
Old 06-05-2014, 08:14 PM   #7
dori.
Seņor Member
dori.'s Avatar
Really? My car has 20k on it, and the trans has been fine between daily driving, touge runs and drift events
Old 11-06-2015, 11:18 PM   #8
kroper
Drives: 2014 BRZ Limited
This is where I am at. Transmission replaced and the issue isn't resolved still super notchy and grinds into second
kroper is offline   Reply With Quote
6th Gear Grind & Replaced Transmission Bonburner Issues | Warranty | Recalls / TSB 45 07-30-2016 11:08 PM
transmission grind in 5th gear Rocket.BRZ Issues | Warranty | Recalls / TSB 7 06-30-2014 10:38 PM
transmission grind jbailey8748 Engine, Exhaust, Transmission 26 05-18-2014 09:32 PM
Transmission replacement Ludacrits Issues | Warranty | Recalls / TSB 1 04-30-2014 07:02 PM
"This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind DoomsdayJesus Issues | Warranty | Recalls / TSB 108 04-29-2014 01:15 AM
