Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-01-2017, 09:36 AM | #127 | |
Drives: 2014 Scion FR-S Monogram Series
When did this happen?
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit Future Planned Mods - Ace 350 Header & Tune. Oil cooler. Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg |
11-01-2017, 10:47 AM | #128 |
Not sure exactly. I think in July. I also saw someone on this forum saying they picked up a bunch of it for $1/bottle or something crazy. Probably because it was discontinued. I have to do my throwout and the manual says to drain the fluid although I think I can plug it so it doesn't leak when I drop the prop. But I figured I would at least get some fluid in case. So I've been reading around about fluids and while doing that I saw discussion on a several bimmer forums about this product being dropped and to substitute with FFL-4. FFL-4 is made for double clutch trannies so I don't see how that could be a good substitute. You can still buy MTF2 on Amazon but I suspect it will not last long.
On past cars I've always run Honda MTF which is close to 75w-80 and GL-4. It has an additive to promote syncro grip. Some say it's hard on the syncros but I have about 300k with this fluid between two cars with no syncro problems. Both of these cars had brass syncros. Honda MTF is only $11/qt. |
11-01-2017, 11:17 AM | #129 |
Drives: Evo IX
got it. i personally run red line everything in the car, but wasn't sure if the trans was particular in any way, which it sounds like it is. 75w85 was basically created by red line for the Z cars and the evo 8/9's 6 speed trans, i imagine it will work fine here.
11-02-2017, 08:02 AM | #130 |
Drives: '13 Ultramarine
I never got to try the actual Redline MT-85, but I suspect it would be good. I was not quite happy with either the MT-90 (75W90) or MTL (at the time it was 70W80, but has since been changed to 75W80). I did run a blend of MTL and MT-90 for a season, and that was the closest I came to how Pentosin felt. That blend would have been very close in weight/viscosity to MT-85.
I don't have the car any more, but if I did, and couldn't get Pentosin, MT-85 would be the next thing I would try.
11-02-2017, 10:44 AM | #131 | |
Thanks for tipping me off on the discontinuation; I immediately ran over to O'Reilly's last and had them locate several liters to give me a back-up stash for a few trans oil change cycles.
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) | Neurytic | Cars for Sale/Trade | 3 | 05-22-2013 11:54 PM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA | ysagisan | Cars for Sale/Trade | 0 | 09-19-2012 11:24 AM |
Got a line on two unclaimed BRZs (manual trans) | Tainen | BRZ First-Gen (2012+) -- General Topics | 0 | 07-05-2012 10:40 PM |
