01-23-2014, 05:53 PM | #477 | |
Drives: FRS :D
Not sure why the washer bottle issue still exists tho as I thought he told avo about that as well
Out of the FRS game
01-23-2014, 05:59 PM | #478 |
Drives: Pegasus GTS86
Cheers. Just to be clear. It's not the washer bottle that is the problem. Rather it's the washer jets for the HID headlamps.
I've done the mod to lower the washer bottle down, so that is sorted. :-) |
01-23-2014, 06:53 PM | #479 |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
I had the same problem as well, but i did manage to fith the bumper back on with the headlight washer. It wasn't a perfect fit and there are a small gaps as well, but they still work after testing them out. Going to get back and post some pics later.
The Following User Says Thank You to liquidsky44 For This Useful Post: | Bigmaxy (01-23-2014) |
01-23-2014, 10:33 PM | #481 | |
Fiebru
Drives: Scion FR-S and Integra Type R
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
01-23-2014, 10:35 PM | #482 |
Awesome. Do you know if some trimming was also required of the pipes or any other techniques such as sliding the silicone hose a long way up the pipe to the throttle body?
Just went down and bought some long cable ties so will give that a go but feels like a lot of force will be required to hold them back. Thanks heaps. Also thanks @Draco_PR23 and @Mr.Jay The pictures above may show what it is I am referring to. It's the headlight washers rather than the washer fluid bottle that is creating the grief. Only cars with the HID washers would have this problem. I spoke to Lee @ Avo and he suggested trimming the intercooler silicone hoses down to provide more clearance. I've already taken off 30mm from the right hand side (drivers in my country) and it has helped. I'm thinking cable tie for the rest. Could possibly take more that 30mm off but I don't want to get cocky. I took 15mm off the side with the washer fluid bottle. |
The Following User Says Thank You to Bigmaxy For This Useful Post: | Draco_PR23 (01-23-2014) |
01-23-2014, 10:45 PM | #483 | |
Fiebru
To help you slide the hose to the pipe some ppl use hair spray or some kind of oil lubricant. Edit: Got it! Here we don't have those, didn't know it was an issue.
Current Cars:
01-23-2014, 10:45 PM | #484 |
The Following 2 Users Say Thank You to liquidsky44 For This Useful Post: | Bigmaxy (01-24-2014), Draco_PR23 (01-23-2014) |
01-24-2014, 07:38 AM | #485 |
Drives: AVO BRZ
Yeah we used the biggest (widest) fuck off cable tie we can find and because the FMIC pipe was actually over length we were able to pull it back out of the way.
Then with the oil cooler install the way it mounted had to remove the washer assemblies, and crimp the lines, disconnect the pump etc. Have since removed that oil cooler kit and gone back to washers for the time being. @Pitman what shroud do you have for your oil cooler or where can I see more pics of it in action? I really should get on here more and read up on peoples threads ... Edit ... I don't know if AVO ever addressed this. They generally said 'oh that's interesting, we never had that problem' whenever I reported any issues, but to their credit they seem to have made a lot of changes to the kit. They liked what I did with my car and were helpful and sent free replacement parts on anything that didn't fit properly or broke on me. I also had a nice long chat with Ross Wilson about the platform, my car, his car, and where ft86 is going.
01-24-2014, 07:45 AM | #486 |
Living the dream
Drives: Fensport AVO Turbo GT86
@nix
I made the shroud myself: Mould: Vacuum bagging: Off the mould: Fitted: Air in through a modified FR-S bumper moulding (I have removed the front fog lights) Air out through louvers fitted into the plastic wheel arch liner: |
The Following 16 Users Say Thank You to Pitman For This Useful Post: | blackfireball5 (03-24-2014), DAMotorsports (01-24-2014), DeliciousTuning (01-27-2014), DesertFrs (01-25-2014), Draco_PR23 (01-24-2014), jamesm (01-27-2014), lightdir (10-04-2015), Mr.Jay (01-29-2014), nix (01-24-2014), OmarGC (01-25-2014), protpibe (01-27-2014), RallySport Direct (01-28-2014), rixter145 (05-09-2020), shaunsweeney (01-24-2014), Sportsguy83 (01-24-2014), turbocat (06-29-2018) |
01-24-2014, 08:39 AM | #487 |
Drives: AVO BRZ
That is a brilliant job and what I had considered doing many times, but with far less skill. Have you monitored your IATs with that setup and if so what peaks have you seen when the car is stationary and fully heat soaked (hopefully with a hot ambient)?
The Following User Says Thank You to nix For This Useful Post: | Pitman (01-24-2014) |
01-24-2014, 08:44 AM | #488 | |
Living the dream
Hot ambient in the UK? |
01-24-2014, 08:53 AM | #489 |
Drives: AVO BRZ
Yeah wishful thinking. It's hitting 45c here for the second summer in a row since I put my kit on.
The Following 2 Users Say Thank You to nix For This Useful Post: | DAMotorsports (01-25-2014), DesertFrs (01-25-2014) |
01-25-2014, 01:58 AM | #490 |
Drives: 2013 Scion FRS "Raven"
lol we see temps of 125F and the track temps tend to be higher
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
