01-30-2020, 02:08 PM | #4201 |
Drives: 2015 BRZ
And i would add Firehawk Indy 500 to the mix too. I have those right now and they are a great tire for the price especially if you're just using them for DD.
The Following User Says Thank You to Vital For This Useful Post: | Leonardo (01-30-2020) |
02-14-2020, 09:15 PM | #4202 |
Drives: 2016 Subaru BRZ
Does 18x8.5 +45 fit on stock suspension? Wheel it fit says I have 1mm of suspension clearance and I feel like that might not be enough lol
02-18-2020, 10:39 AM | #4204 |
Drives: jrsc_brz
Is a 275/35 on a 18x11 par for the course? looking for rubber for a new set coming in.
The Following User Says Thank You to HaXx For This Useful Post: | Leonardo (02-18-2020) |
02-18-2020, 11:29 AM | #4205 | |
Country Boy 4 Life
here is a 275 rear tire... (post #2465) http://www.ft86club.com/forums/showt...41083&page=177 18x10.5 +47 will fit stock rear fenders (post# 18370) He ends up adding a 3mm spacer to the 18x10.5 +50 https://www.ft86club.com/forums/show...1036&page=1313 18x11, IMO, will need wide body or lots of camber. This is a 17x11 rear, so comparable. http://www.ft86club.com/forums/showthread.php?p=3153084
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Vital (02-19-2020) |
02-18-2020, 12:17 PM | #4206 | |
Drives: jrsc_brz
02-18-2020, 12:31 PM | #4207 |
Drives: jrsc_brz
im on 18x8+45 and it was fine on eo susp. Your wheel is a touch taller and you will have a shorter tire, but not any closer to the suspension, so i think ull be good. i use wheel-it-fit a ton, but real world is always different than it is on paper.
02-18-2020, 12:43 PM | #4208 |
Country Boy 4 Life
Nope. A 18x8.5 +45 is 6.3mm closer to the spring perch than a 18x8 +45. Offset is measured from the middle of the wheel.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | HaXx (02-18-2020) |
02-18-2020, 01:32 PM | #4209 | |
Country Boy 4 Life
I LIKE TIRES! |
02-18-2020, 02:20 PM | #4211 | |
Country Boy 4 Life
Most guys run a 18x9.5 or 18x10 in the front. Because of the geometry of the center of the wheel compared to the width. Anyway, I think it will steer really weird if you do an 11" wheel in the front with a -6 offset. I don't have experience with this though... Just the math. So, maybe a 18x9.5 -25 wheel. This guy suggests 18x9.5 -15 front and 18x11 -20 rear with -3 camber front and rear. I added 10mm to his calculations for fenders that are 10mm less. (makes sense to me!) http://www.ft86club.com/forums/showthread.php?t=102357 My aggressive calculations are only about 10mm more of poke from what he suggests. I think that if you want less aggressive camber, you should go with less poke.
I LIKE TIRES! |
02-18-2020, 03:42 PM | #4212 | |
Drives: jrsc_brz
02-18-2020, 09:00 PM | #4213 |
Drives: Subaru Brz - WRB
Does 18x9.5 +35 with 255/35/18 fit on stock suspension? or would it be safer to go with 245/35/18 or 245/40/18.
02-19-2020, 09:40 AM | #4214 |
Drives: 2015 BRZ
Yes it will fit stock suspension and it will poke a bit in the front the rears shouldn't be an issue. It will be close fit up front the tire sizes that will work are 245/35 or 235/40. I suggest getting coilovers otherwise it will look like a 4x4. Also, you can definitely add a 3mm spacer up front if its too close to the stock spring perches.
The Following User Says Thank You to Vital For This Useful Post: | Leonardo (02-19-2020) |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
