Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-02-2017, 08:52 PM | #1 |
Drives: sc00ter
Borla frontpipe / overpipe install help!
anyone has one of these installed and would like to give tips?
I was ecstatic to be able to remove the stock overpipe without cursing or breaking anything. But I now have a problem of installing the Borla pipe..no matter how I tried, going through from the front or going through from the back, I can't get through that POS tiny gap... Do I need to drop my stock header? |
02-03-2017, 09:05 AM | #2 | |
Drives: 2013 Scion FR-S-white out
I'm sure you're gonna have to loosen the engine mounts and jack the motor up just a little to give you some room to slide it in I had to do the same when I had the nameless op/fp combo |
The Following User Says Thank You to Plxdjake89 For This Useful Post: | Khánh (02-03-2017) |
02-03-2017, 09:32 AM | #3 |
StreetKart
Drives: 2014 Scion FR-S Monogram
you should be able to slide it in thru the front. I had zero issues installing a JDL by installing thru the front.
Option two is to loosen the passenger side motor mount and to find a place to lift the engine up from a bit. Tho, being Borla I wouldnt even bother as I believe its nearly the same size as the oem overpipe. It's not worth the hassle.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
The Following User Says Thank You to Roadcone For This Useful Post: | Khánh (02-03-2017) |
02-03-2017, 09:48 AM | #4 |
Drives: 2013 satin white brz limited
It all depends on the bends of the over pipe. A well designed one will have just enough bend to clear once install to limit the restriction. To install my ACE over pipe I had to undo the 2 motor mount bolts and lift the motor slightly. Very easy to do.
The Following User Says Thank You to jasonojordan For This Useful Post: | Khánh (02-03-2017) |
02-03-2017, 12:05 PM | #5 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
It goes through the front. You just have to angle it right. If you need to lift the motor (not sure if needed since I had my header off when I did mine) leave the nuts on so you don't pull the motor all the way out and have issues lineing it back up.
The Following 2 Users Say Thank You to finch1750 For This Useful Post: | jasonojordan (02-03-2017), Khánh (02-03-2017) |
02-03-2017, 12:24 PM | #6 |
Good thought. When I lifted mine I almost made this mistake lol.
02-03-2017, 08:05 PM | #7 | |||
Drives: sc00ter
thanks for the tips everyone Last edited by Khánh; 02-03-2017 at 08:31 PM. |
02-03-2017, 08:10 PM | #8 |
Yup. Had a buddy learn the hard way. Took us forever to get it back in straight
02-04-2017, 06:45 AM | #9 |
Drives: 13 mt fr-s
The diameter might be less on the stock overripe, but the overripe isn't holding anything back.
Cats are your resistance and back pressure. Save a headache and sell the new overripe :p |
02-04-2017, 01:24 PM | #10 | |
It would be easier in my opinion, I can help I'm in 818 myself |
The Following User Says Thank You to Plxdjake89 For This Useful Post: | Khánh (02-05-2017) |
02-04-2017, 01:33 PM | #11 | |
I unbolted both sides and just lifted the whole motor.
The Following User Says Thank You to jasonojordan For This Useful Post: | Khánh (02-05-2017) |
02-05-2017, 12:37 AM | #12 |
StreetKart
the overpipe, from what ive found, is one of the lease restrictive parts of the exhaust. next to the axleback. the header and front pipe are far more restrictive. the overpipe has temps high enough that velocity is far higher that needed. i'm considering replacing my over pipe purely because i need to pull it when i gut my cat.
The Following User Says Thank You to Roadcone For This Useful Post: | Khánh (02-05-2017) |
02-05-2017, 03:48 AM | #13 | |||
Drives: sc00ter
i got it in. thanks! Quote:
the front pipe is rounded in already, do i still need to reuse the stock donut gasket? seeing not many has this OP/Fp, i guess, I'll have to test and see |
09-09-2019, 12:22 AM | #14 |
Drives: Whiteout track car; lava donor
I’m reviving this old thread. Can you post sound clips of the Borla overpipe and front pile? Looking to buy one locally to make the front pipe a straight through, but am worried it might be raspy.
Similar Threads | ||||
WTB: 3" overpipe and frontpipe | supahotfya_86 | Want-To-Buy Requests | 1 | 02-09-2016 02:03 PM |
WTB: Overpipe and FrontPipe | P5yk0t1c | Canada Classifieds | 2 | 04-27-2015 02:00 PM |
Borla UEL Header & Overpipe/Frontpipe | jjkerr626 | Engine, Exhaust, Transmission | 42 | 07-28-2014 06:20 AM |
Overpipe and Frontpipe (CA Questions) | FUN BRZ | Northern California | 17 | 03-21-2014 02:36 AM |
Overpipe or frontpipe? | feldy | Engine, Exhaust, Transmission | 8 | 09-10-2013 01:01 PM |
