Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-15-2019, 08:03 PM | #43 |
There is no aruguing that an ace 350 setup and custom ecutek tune is the best NA combo but not everyone wants to spend 2100$ when there are combos that can net you 80-85% gains for 50% off the cost.. lots of good options. Let's leave at that..
2013 Series 10 FRS #553
01-15-2019, 08:37 PM | #44 | |
Drives: 2017 toyota 86
But as myself and others already mentioned. The actual peak dyno number or numerical increase is irrelevant for comparisons as all dynos read differently. But the percentage difference should be relatively static from one dyno to another and that is why you should only ever compare the percentage increases of one before and after dyno to another. |
01-15-2019, 08:58 PM | #45 |
Drives: 2013 frs red
Bullshit. These cars make 200ish wheel horsepower when tuned. Will an ace header show a 20 percent increase from 178 whp?
01-15-2019, 08:59 PM | #46 | |
01-15-2019, 09:03 PM | #47 |
No argument with quality of ace but I've yet to see a 214whp dyno especially on 10 percent ethanol
01-15-2019, 09:06 PM | #48 |
Ve is 200 even with the "restrictive" intake manifold. Percentage gains look better with low baselines
01-15-2019, 09:33 PM | #49 |
You guys need to see through the bullshit
01-15-2019, 09:50 PM | #51 |
178 is a fluke baseline. Probably before the ecu turned the fun off and started dumping fuel. He should've pulled it a couple more times. It probably would drop to 170 imo. Then the gains would look better.
Similar Threads | ||||
UEL HEADER W/o tune | turtlefeeder | Engine, Exhaust, Transmission | 10 | 11-29-2016 03:46 AM |
Header without a tune | eddiev116 | Engine, Exhaust, Transmission | 73 | 02-07-2015 06:01 PM |
Header and tune Decision | Toyota GT 86 | Engine, Exhaust, Transmission | 24 | 09-09-2014 05:47 PM |
Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
FI or Tune and Header? | RSH | Engine, Exhaust, Transmission | 30 | 10-23-2013 05:09 PM |
