Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-22-2018, 11:58 PM | #1 |
Drives: WRB 2017 BRZ Limited w/ PP
Boneheaded move. Installed RCE rear yellows upside down
So I just finished installing RCE yellows tonight. Test drive went great. However just on a hunch I looked at the rear springs and noticed the text on the springs is upside down. Does the rear spring direction matter?
06-23-2018, 12:32 AM | #2 |
Drives: 2015 FR-S
06-23-2018, 02:01 AM | #3 | |
humfrz |
06-23-2018, 02:42 AM | #4 |
Yes there’s writing on the spring that should be right side up. RCE has “dead springs” at the bottom of the spring itself.
06-23-2018, 03:34 AM | #5 |
Think about it like the old Jeep meme only in reverse
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | churchx (06-24-2018), lantsalot (06-25-2018), Shark_Bait88 (06-25-2018), Spuds (06-23-2018), TachyonBomb (06-24-2018) |
06-23-2018, 09:25 AM | #6 | |
My last question is this springs are a symmetrical, meaning the left one when looking from above us exactly like the right one - they’re not mirror images so which way do I rotate the assembly? Do I keep them both pointed the same direction so the lower pigtails point the same way or do I turn one 180 grease out. Or does it even matter. |
06-23-2018, 02:53 PM | #7 | |
That’s weird your springs don’t say L or R on them, if they both look identical I don’t think it matters which side they go on. |
06-23-2018, 04:05 PM | #8 |
5mm? I guess that makes sense, allows them to move I guess and not bind. It didn’t say that in the instructions; and I’ve never done that on any other set of springs I have installed before; oh well I guess I’ll have to see if there are any issues in my the future since it’s all installed and online now.
06-23-2018, 06:36 PM | #9 | |
https://www.ft86club.com/forums/showthread.php?t=116218 |
06-23-2018, 11:59 PM | #10 |
Drives: Legacy GT
As long as they fit into the spring perches properly it doesn't matter. But I feel like it might not be in the lower perch on the strut quite right?
06-25-2018, 10:58 AM | #12 |
Drives: 2014 GT86
I guess for ones not reading instructions it simpler is to lessen misinstallation cases with something clear to see, like stickers on springs with arrows pointing up, for installation direction
06-25-2018, 01:48 PM | #13 |
Post installation:
No noises. Sharper transients in steering. Ride just a tad stiffer than stock. Alignment shop could get everything to spec but rear camber. Only 1/2 a degree more camber than stock, so no biggie. Drop doesn’t “look” dropped, but like it should have come from the factory. Just what I wanted. |
The Following 2 Users Say Thank You to Last Lemming Alive For This Useful Post: | norcalpb (06-25-2018), Racecomp Engineering (06-27-2018) |
Similar Threads | ||||
Move stock front calipers to rear? | canyons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-11-2016 02:50 PM |
RCE yellows, stock dampers - springs move | Qadthane | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 04-20-2016 02:04 PM |
RCE Yellows, WRX Rear Sway bar, trunk jack | Keenercarguy | Want-To-Buy Requests | 2 | 10-31-2015 04:14 PM |
Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* | raul | Brakes, Suspension, Chassis | 0 | 08-09-2013 03:22 PM |
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings | raul | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 05-24-2013 08:33 AM |
