03-14-2018, 09:44 PM | #2731 |
Drives: '22 WRB
The Following User Says Thank You to trippinbillies40 For This Useful Post: | whataboutbob (03-15-2018) |
03-14-2018, 09:56 PM | #2732 |
Drives: FRS hot lava
03-15-2018, 04:29 PM | #2733 |
AutoX-10/10ths every run
Bring extra motors, because SM+Subaru lol.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
03-18-2018, 01:55 PM | #2734 |
Drives: 2015 Subaru BRZ
Is anyone here running a Verus AOS system with their Edelbrock setup?
It looks like it should fit, but I'm looking to order my supercharger in the next week or so, and wanted to double-check. |
03-20-2018, 05:23 PM | #2735 |
Drives: Supercharged 2016 CBS BRZ
03-20-2018, 07:00 PM | #2736 |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Proseph (03-20-2018), ThatAsianBradah (03-20-2018) |
03-20-2018, 07:36 PM | #2737 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
At one point, this was true, but I believe you would end up with a CEL when running the d-box with a non DT tune. I would get P0451, EVAPORATIVE EMISION CONTROL SYSTEM PRESSURE SENSOR RANGE/PERFORMANCE when I had mine flashed with the CARB tune. You might be able to get your tuner to turn off that code?
The Following User Says Thank You to BigFatFlip For This Useful Post: | Proseph (03-21-2018) |
03-20-2018, 08:33 PM | #2738 |
Drives: UK GT86
I'd be surprised if James can't get it to work on his tunes.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Proseph (03-21-2018) |
03-21-2018, 08:18 AM | #2739 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
The Following User Says Thank You to BirdTRD For This Useful Post: | Proseph (03-21-2018) |
03-21-2018, 09:30 AM | #2740 |
03-24-2018, 04:48 PM | #2741 |
Drives: 2013 Black BRZ Limited
more error codes.
I have a feeling my issues are stemming for a single issue I just can't find.
Today with ambient temps in the 60s, the engine was revving up to 2500 RPM while coasting in neutral. Then when I started the car next, it threw P2109 (Throttle / Pedal Position Sensor A Minimum Stop Performance) and P0123 (Throttle / Pedal Position Sensor / Switch A Circuit High). It went into limp mode and I found a place to pull over. Turning the car off and then back on, the starter was cranking but the engine wouldn't fire up. After letting it sit for a bit it finally started up again and I was able to make it home. Searching for those error codes online, there isn't a lot of information available. Anyone have thoughts on where to start? |
03-24-2018, 09:17 PM | #2742 | |
Drives: 2014 Porsche Cayman S
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
03-25-2018, 03:28 AM | #2743 | |
Drives: UK GT86
.: Stealth 86 :.
03-25-2018, 01:57 PM | #2744 | |
The Following User Says Thank You to taiguy For This Useful Post: | paiceyfan (03-25-2018) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
