Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-25-2017, 04:54 PM | #15 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I got the spark plugs for $80 (which was the cheapest I found) and had a tech (who is a friend) install it for $258 (2 hour of book time @ $129/hrs, though it took more than 2 hours).
05-25-2017, 06:45 PM | #16 |
Drives: 13 SWP BRZ Prem
Spark plugs aren't terrible. Book time is probably pretty high with the "proper" way. Many things have to be disassembled.
Myself and a tech did the plugs on my brz, took a little over an hour. Must have tools if you do it yourself: Many bendy joints, flexable magnet, skinny hands. Process is basically: drop the skid plate unbolt the two motor mounts jack up the engine about 2 inches Pull the HPFP shield Undo the coil packs Remove the coil use many bendy joins to get the socket into the hole use flexible magnet to pull the spark plug Reverse order
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
The Following 4 Users Say Thank You to Imrac For This Useful Post: |
05-25-2017, 06:50 PM | #17 |
Drives: Grrrr
On a four stroke () I never change the plugs if the car is running the same as it always was.
05-25-2017, 07:11 PM | #18 | |
I have traded in cars with 400K kms (250K mikes) with the original fluids and plugs in it and never had an issue with the cars.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | gravitylover (06-14-2017), Scrappydoo (05-25-2017) |
05-26-2017, 12:49 AM | #19 |
Drives: iso white BRZ
As a mechanic, this is very impressive. As a car lover, this is very disturbing lol.
05-26-2017, 02:25 AM | #21 | |
humfrz |
05-26-2017, 02:33 PM | #22 |
Drives: Scion Frs
come to think of it, when I had my corolla I never got spark plugs changed or any kind of 60k service done to it. And I drove that thing for over 120k miles with no real problems. But im thinking better to be safe than sorry with the FRS, this is my baby after all and I plan to drive this thing until the wheels fall off.
The Following User Says Thank You to timmydatooth For This Useful Post: | Koa (06-04-2017) |
06-04-2017, 10:29 PM | #23 | |
Sweeper
budget $1000 or so for maintenance items? are you crazy? that would get in the way of my elaborate five year, twelve stage tier 1 to 5.3 turbo hellaflush drifter mode plan. I even have overnight shipping from japan factored in at realtime post pricing. how do you expect me to know that I have to spend some money every 5 years or so for needed maintenance? wtf? People won't even SEE the spark plugs so why change them if people won't notice? fuck this car too much money. selling it. I give up. |
The Following User Says Thank You to Koa For This Useful Post: | strat61caster (06-14-2017) |
06-10-2017, 10:01 AM | #24 |
Drives: Scion Frs
Ok so just got back from getting my oil change and asked for a quote for the 60k service and the advisor just thought it was just a regular oil change and tire rotation and what not. Told him that according to the car manual a few things had to be done like replacing spark plugs and some fluids checked. He said ok I'll get you a quote. Oil change got done and came back with a quote from a different advisor this time and he said the estimate for the 60k would be 220 which sounded kinda low to me considering all the stuff the 60k service recommends getting done. I said whatever didn't feel like trying to explain to another advisor again after waiting 2 hours for oil change plus they were pretty busy. Anyway is there some kind of paper I can print out that lists everything that needs to be done for the 60k that I can just show them so they actually know what I'm talking about? I assumed that since I'm at a Toyota scion dealership they would just pull up the Frs and see what is recommended for the 60k but I guess they just go by a certain set guideline for every vehicle. Dealerships...sigh
06-10-2017, 03:37 PM | #25 |
Drives: car
@timmydatooth the dealership should have given you an itemized receipt for your car maintenance.
06-10-2017, 04:51 PM | #26 |
Drives: Grrrr
It's a diesel isn't it?
06-14-2017, 10:06 AM | #27 |
Drives: Scion Frs
what did you guys ask for when you went to get your 60k service done?
06-14-2017, 11:02 AM | #28 | |
TRACKBREAD
approaching 60,000 miles
"I'd like to schedule my car for the 60,000 mile service please." In all seriousness: plugs, brake fluid, oil, oil filter, air filter. Cabin filter and coolant if you feel like it. My dealer had a well priced package for all the above plus tire rotation. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | humfrz (06-14-2017) |
Similar Threads | ||||
135k Miles on Engine. 110k boosted miles; still going strong | Cal3000 | Forced Induction | 29 | 05-06-2017 01:15 PM |
My first winter approaching, need some winter tires. | Jfheisenberg | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 01-05-2016 08:56 PM |
Issues while approaching 10k - need help | slyphen | Issues | Warranty | Recalls / TSB | 8 | 09-02-2015 08:09 PM |
Pentosin mtf2 and approaching hot climate | bdanisi | Engine, Exhaust, Transmission | 1 | 04-20-2013 10:48 AM |
SEMA 2012 Las Vegas is Fast Approaching.. What is Coming Our Way? | AJ@ECSMotorsports | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 09-13-2012 01:52 AM |
