01-21-2015, 03:49 AM | #295 | |
Drives: UK GT86
- License for the ECU - Cable and Dongle (come as one) You can then add on the Racerom upgrade for access to custom maps and modes 2-4. The 2nd car will just require them to purchase a license for their ECU which can be added to your dongle through the master tuner. It depends on how much you're into your tuning, I doubt many would think there are tables worth using that are missing and TBH if you're just trying to do a basic tune then it's all there. If you want a bit more then the way around this is to use Romraider on a base stock ROM, which can be easily found on here or romraider forums, and then transfer the file into ECUtek and then utilise it's advance features. It's long winded if you need to keep going back and forth but gives us end users the extra access you may want.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | dave- (01-21-2015) |
01-23-2015, 11:53 AM | #296 |
Hooner in training... eh?
Drives: 2013 Scion FRS
Wow just got through this entire thread and what a wealth of information. Honestly I'm back on the fence between OFT and ECUTek since I plan on FI next year (maybe even later this year) and honestly need map switching since it's a DD. Gotta save fuel where ever I can but be able to switch to POWAR map when I go to a track or want to have fun. Just the price point is keeping me away, especially for us Canadians with 1.23 exchange rate...
**Dunno what to put here yet... Imagine something witty...** |
The Following User Says Thank You to The_Understated For This Useful Post: | Triumphrider (01-26-2015) |
01-26-2015, 05:28 PM | #297 |
Drives: 86 GTS White
Anyone know if ZA1JE00I is compatible with 2012 Toyota 86 AT before I update?
01-26-2015, 06:38 PM | #298 |
Drives: UK GT86
Probably not, best to check the compatibility display when programming the ECU
.: Stealth 86 :.
01-26-2015, 08:54 PM | #299 | |
I tried D00G on my manual 2013 and it threw 2 CEL çodes P0155 re dash communiçations and another re alternator control, car ran fine though. Suspect changes to dash and altenator, probably same for auto. |
The Following User Says Thank You to steve99 For This Useful Post: | Skorov (01-26-2015) |
01-27-2015, 06:06 PM | #300 |
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Anyone know how to get access to custom map levels in EcuTek?
I can log and view the table data but can't access the actual map. Is there a RaceRom add on needed that can be downloaded? Last edited by Jetbill; 01-27-2015 at 07:01 PM. |
01-28-2015, 02:28 AM | #301 |
Drives: UK GT86
You need to purchase it. If you have already then chase up whoever you bought it off to update your dongle.
.: Stealth 86 :.
01-30-2015, 01:01 AM | #302 |
Drives: 2014 SWP BRZ, MT
Did D00C ROM's lose the ability to be flashed to older C versions? I could have sworn on the last ProECU build ZA1JD00C was on the list of flashable roms. So since the latest update provided D00C RaceROM files I recreated my map on D00C hoping it'd fix some of the issues from B01C RaceRom which incidentally hasn't been updated since February of 2014 (or at least not released to us). Except after spending all the time pasting over my new map, I found it was deemed incompatible.
I wish there was a way for retail customers to get access to beta tables. It's tough needing to repaste every single table manually (as we don't have compare ROM either) when I need to edit a table that I can get to in RomRaider but not EcuTek. Currently tuning 1000cc injectors, and not being able to edit low-pulse-width injector comp is rather annoying.
The answer is racecar. Always.
01-30-2015, 02:44 AM | #303 |
Drives: UK GT86
I think there have been issues with compatibility with the newer ROMs on older cars. I also noticed the same with the G series recently.
.: Stealth 86 :.
03-01-2015, 03:08 AM | #304 |
Drives: UK GT86
Looking at ECUteks Twitter feed I noticed that they have managed to get the cylinder knock parameters for the new WRX (FA20 DIT):
I've emailed them about this but is anyone else able to locate these parameters on our ECU? Would be a nice addition to have.
.: Stealth 86 :.
03-03-2015, 11:18 PM | #305 |
Drives: Ae86
getting my ecutek dyno tune next week, pretty excited to see the gains.
03-07-2015, 03:12 PM | #306 |
Those looking for an easy , convenient solution to view, log and make changes quickly...windows tablet from HP Stream ($99) works well. Only thing you need is a USB on the go cable and a USB hub.
Increase text size in EcuTek and view critical parameters real time..oil and coolant temp, PI duty, ethanol percentages, AM, ign correction.. Etc (Oil pressure is Hardwired so that's a separate gauge me) Make quick changes at the track without that bulky laptop! |
The Following 2 Users Say Thank You to Jetbill For This Useful Post: | Sportsguy83 (05-15-2015), Xero-Limit (03-08-2015) |
03-08-2015, 10:12 AM | #307 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
03-14-2015, 03:30 AM | #308 | |
Drives: Strangely.
I can't find my calibration ID, my Dongle ID, or my tune (is that what a ROM is?). Can't seem to find any guides that tell you where to find this stuff. There's like eight indistinguishible ROMs to choose from, and you may gather I'm not the sort of person that knows how to choose. I just want my cruise control to start working again. How do I do this?
My FR-S has a build thread!
(It's mostly full of Nissans) |
Tags |
ecutek, edit, proecu, racerom, tuning |
Similar Threads | ||||
EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 09:17 AM |
So what ECUtek software do you need to make changes to the ECU yourself? | seven | Engine, Exhaust, Transmission | 30 | 01-04-2013 11:58 AM |
EcuTek's BRZ / FT86 / FR-S ProECU Software available for Pre-Order now | Visconti | Engine, Exhaust, Bolt-Ons | 7 | 07-27-2012 01:00 PM |
Toyota will announce the FT86 in Tokyo 2011 motor show? | ossme | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 12-05-2010 02:36 PM |
