FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
View Poll Results: Should equivalent type of tire be used when comparing lap times of cars? | |||
YES: To accurately compare the cars, equivalent tires should be used. | 75 | 82.42% | |
NO: The tire that came with the car is part "of the car" and should remain unchanged for comparison. | 16 | 17.58% | |
Voters: 91. You may not vote on this poll |
09-13-2012, 04:57 PM | #29 |
As an AE86 successor, this car carries an expectation to be able to drift, and with 200hp and super-sticky tires, would have left a lot of people disappointed. Also, those tires were chosen to give beginner drivers more feedback than your high-grip performance tire which gives less warning when it's at the limits of adhesion.
To say that the car's outright performance is held back by it's tires is an understatement. If the S2000, MX-5, or any other car were built with similar principles in mind, it would likely have mediocre touring tires as OE, too. Put the FR-S on RE050A's and stack it up against the S2000 and MX-5 (with the same driver, same track conditions) to get a sense of it's true performance against its competitors.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
09-13-2012, 05:17 PM | #30 | |
the miata is the successor to the miata. mazda made a deliberate decision to not give it any more grip than it had in the 80s. also the miata was built to appeal to a wide audience and because of it, they suck in stock form. to get a sense of the miatas "true" performance youre probably going to need at least a set of rx8 sways. |
09-13-2012, 09:50 PM | #31 |
Drives: Nevermorange FRS
09-14-2012, 12:45 AM | #32 | |
Drives: 2011 Subaru STI
2: I don't even know what we're arguing about here. Tires make a profound difference in performance of a car, are chosen because of a specific price-point the automaker is trying to hit and at the same time maximize traction and control that wouldn't otherwise be possible with the chassis, and are easily the fastest wear-items on any car (besides oils and filters, I suppose). DarkSunrise said it best - if you're the general public that doesn't care about lap times, then keep everything stock. If you're an autoXer, you would appreciate the comparison of cars on similar rubber. I'm fine if you're in the former group, but it doesn't mean those of that would like better comparisons are wrong in any way. |
09-14-2012, 02:47 AM | #33 |
Drives: 2001 Mr2 Spyder
Cut a couple of tenths 0-60.
A few more tenths 1/4 mile. Braking distance. Skidpad rating. If anything, I was surprised how well the Fr-S did with the summer Prius tires.
Member of Heya Project for Fr-S/BrZ.
Tire choice, Dash, Options list, Engine, Chassis, Suggestions; My fault Owned N/A '93 Mr2, N/A '91 Mr2, '98 Corolla, Mazdaspeed Mx-5, '07 Legacy Wagon, E90 328i well maintained and lit up on fire while driving on the freeway in traffic. |
09-14-2012, 04:55 AM | #34 | |
its impossible to equate those things to a chassis alone. if you change the tires on any chassis those numbers will change. quarter mile times, braking distance and skidpads have next to nothing to do with the chassis. if by implying that improving those statistics via tires is hiding chassis issues, then every single car ever has chassis deficiencies. Last edited by fatoni; 09-14-2012 at 05:25 AM. |
09-14-2012, 08:08 AM | #35 |
Drives: Toyota Auris
fatoni, you're not only claiming that using the same tires isn't "fair", which is debatable; but you're also claiming it's not informative.
(e.g.) Skidpad figures close to an Elise are very informative. But you know what isn't? Changing many things at once, because you don't know what's doing what. I can't agree that purposely changing one specific thing, that's not a constant during the lifetime of the stock car, is the same as changing many other things at once. |
09-14-2012, 01:02 PM | #36 |
Drives: '12 C63 P31, '23 GRC
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
09-14-2012, 02:51 PM | #37 | |
skidpad tests are not only next to worthless as far as handling goes but they should only be compared on the same surface with the same radius. close to the elise skidpad numbers? was that the .95g or the 1.03g. the zr1 posts higher numbers than the elise ever did. is the corvette a better handling car than the elise? you dont have to agree with anything im saying but being able to identify what is making a difference has nothing to do with saying changing tires and only tires alone can be changed in comparisons |
09-14-2012, 03:29 PM | #38 | |
Tires have little to do with the chassis, pending setup, suspension geometry, etc. It's not that every car has a chassis deficiency. That's too extreme a point. The modern chassis of cars nowadays are tremendously better than cars of yesterdecade. The point is, great tires inflate great results on track tests. Those numbers are what most car buyers actually look at. The more informed enthusiast will want to see lap times of different chassis with the same tires. Why? They're more likely to use the car for that given application. My point is this. All sports cars for sale in 2012 have a great set of grippy tires except one car. The FR-S. So, when that "average tire" still puts up huge numbers for typical testing, it says a lot about the chassis, since the tires aren't inflating results. Rather, using narrow 215 tires that belong to a Prius show how much potential the chassis actually has.
09-14-2012, 03:36 PM | #39 | |
09-14-2012, 03:48 PM | #40 |
@fatoni:
Taking your words exactly, "it isnt any more informative than keeping the factory tires" - that's not true. It is very informative, if that's the piece of information you're looking for. Guess what: that's the piece of information we're looking for. Skidpad is one test, no it can't actually measure "handling" but is there even a metric for handling? It's a good example, though, since it's so tire dependent; no car can compensate for low-ish grip tires in this test. You're saying the same radius and same surface must be used; yet you want to test cars with different grip levels (tires). Strange. What are the Edmunds numbers for the ZR1? 1.02g was all I found. Being able to identify what is making a difference has everything to do with changing one single item (at a time). Are you saying magazines should make e.g. suspension changes? About your response to midenginebias: you just told us why it is so important to test all cars with "great tires" (i.e. to avoid comparing "inflated" results with "non-inflated" ones). |
09-14-2012, 04:20 PM | #41 | |
if you google "skidpad test zr1" literally the first number you see is 1.06. im not saying magazines should make suspension changes, im just saying that its just as fair as canging tires or anything else. you keep missing my point and i dont really feel like running around in circles with you |
The Following User Says Thank You to fatoni For This Useful Post: | midenginebias (09-14-2012) |
09-14-2012, 04:22 PM | #42 |
Road & Track tested the ZR1 in 2010 and recorded 1.04g
They tested it again in this month's issue and recorded 1.08g. Not sure why you're looking for Edmunds numbers?
Similar Threads | ||||
Nameless Performance Equal Length Stepped Header | Jason@Nameless | Engine, Exhaust, Transmission | 4525 | 11-21-2022 05:38 PM |
Interested in comparing the FT86 to the Silvia? | regal | FR-S / BRZ vs.... | 36 | 11-06-2012 05:59 AM |
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 02:54 AM |
To those who keep comparing the FRS to another car on specs... | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 06-06-2012 08:39 AM |
Comparing front end of the FR-S/FT-86 to BRZ | DIG1992 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 66 | 11-21-2011 05:26 PM |
