Software Tuning Discuss all software tuning topics. |
02-25-2021, 02:30 AM | #1 |
Drives:
Help M150 Plug In
anyone else using this plug in M150 on their car ?
I need to confirm one or two things 1. My car AT with Start Stop Button car wont cranking unless the ignition and cluster are on state brake switch is present what should i do to make it like stock ecu.. i can crank the engine whenever i pressed the brake pedal and push the start button 2. Late shifting on the Auto trans i triple check every data transmitted from motec and tcu, they are identical just for slight speed diff (5kmh) problem is my car wont shift up untill i reach 3500 rpm on light throttle so feel so rough in shifting and also when Full throttle, the shift up feels so late going into next gear this wont happen with stock ecu also the blip throttle is gone with motec with stock ecu, blip throttle present when we gear down with paddle shift apreciate some help |
Similar Threads | ||||
Motec M150 FRS/GT86/BRZ FA20 Plug and Play Package with LTC & Level 2 logging | Hudzoyne | Audio/Visual, Electronics, Infotainment, NAV | 4 | 12-02-2020 06:18 AM |
Motec M150 | smudge | Want-To-Buy Requests | 0 | 02-07-2018 08:55 AM |
MoTeC M150 + 86 Nanny + AiM Solo DL in BRZ | mkivsoopra | Engine Swaps | 24 | 09-28-2017 08:58 PM |
Motec M150 - Traction Control and VSC | bem75 | Software Tuning | 4 | 06-29-2017 06:45 AM |
Motec M150 Reviews | diss7 | Software Tuning | 2 | 03-04-2014 07:05 PM |
