Old 10-11-2020, 03:07 PM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86, Volvo 996
Burnt seat heater bulb?
Hello again everyone,
One of the bulbs on the seat-heater switch panel burnt out on my 86.. Anyone knows whether these can be changed?
Best regards,
Alex
alex87f is offline   Reply With Quote
Old 10-11-2020, 03:51 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Integral to the switch. Easier to just replace the switch
alex87f (10-11-2020)
Old 10-11-2020, 04:13 PM   #3
alex87f
Meow
alex87f's Avatar
Thanks -
If anyone finds this later, part numbers are:
LH: 83075FA011
RH: 83075FA001
50USD a pop on ebay.
The Following 3 Users Say Thank You to alex87f For This Useful Post:
callisto (01-22-2024), JesseG (11-05-2020), Tokay444 (10-31-2020)
Old 10-12-2020, 12:48 AM   #4
zoeymiler45
Drives: honda civic
Yeah you can replace it very easily.
zoeymiler45 is offline   Reply With Quote
Old 10-12-2020, 02:36 PM   #5
alex87f
Meow
alex87f's Avatar
Since paying 50 bucks to replace a bulb isn't my cup of tea, I looked at a couple of bulb replacement how-to's on Subaru forums (apparently these switches have been around since the late 90's ).
https://forums.nasioc.com/forums/sho....php?t=2705743
https://www.subaruforester.org/threa...5/#post-946522
https://www.subaruoutback.org/thread...cement.195026/ (more detailed, but not exactly the right switch)
These are decently comprehensive, but none of them indicates what bulb to purchase. They're 12V "grain of wheat" type bulbs, but I don't know what their intensity is, or whether several sizes exist. Anyone here knows ?
Old 10-12-2020, 05:33 PM   #6
Kaotic Lazagna
Drives: GR Corolla
Hard to tell from those pictures, but if the whole base twists off, then I would assume it could be one of these: https://www.vleds.com/shop-bulb-numb...t4-t5-led.html
But if the bulb comes off the base, then it might be this: https://www.vleds.com/shop-bulb-numb...ed/74-6-c.html
Old 10-13-2020, 01:50 PM   #7
alex87f
Meow
alex87f's Avatar
I've ordered a set of bulbs similar to radioshack 7219 / 2721092 (there are no radioshacks here).
They're 3mm diameter grain of wheat bulbs, 6mm long, rated at 12v / 60ma. Let's hope this works.
Old 10-24-2020, 12:28 PM   #8
alex87f
Meow
alex87f's Avatar
I finally got around to taking care of this issue this afternoon.
Turns out it's super easy. Both seat heater switches can be taken out by removing the gear lever trim, and unclipping them through the opening.
Then you just take them apart (you can do it from the upper or lower part of the switch, I found the latter easy), remove the blue rubber with the bulb, swap the bulb for a new one, and voila!
Also, it's better to change both bulbs at the same time, as the standard grain of wheat bulbs found online or at retailers are a bit brighter than the stock ones.
Here are the bulbs you'll need. This is literally a $2 job for both switches:
https://www.radioshack.com/products/...rolamps-2-pack
The Following 6 Users Say Thank You to alex87f For This Useful Post:
bcj (10-25-2020), JesseG (11-05-2020), soundman98 (10-24-2020), spike021 (11-05-2020), sunami88 (10-24-2020), Ultramaroon (10-26-2020)
Old 10-31-2020, 12:46 PM   #9
dnieves
Drives: FR-S 10 Series
just curious, can those incandescent grain of wheat bulbs with a LED that'll last years longer?
dnieves is offline   Reply With Quote
Old 10-31-2020, 04:59 PM   #10
soundman98
soundman98's Avatar
yes you could, but it involves soldering, and SMD resistors.
Old 11-02-2020, 05:17 AM   #11
alex87f
Meow
alex87f's Avatar
Also, FWIW, these are white bulbs, there's a small orange screen on the switch's "window". You'll need to remove it if you want to put a coloured bulb.
The Following User Says Thank You to alex87f For This Useful Post:
JesseG (11-05-2020)
Old 11-05-2020, 07:03 PM   #12
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Alex I was going to be sarcastic and say “Wow look at me I’m fancy I have seat heaters!” But then you opted to replace the bulbs for $2 and totally redeemed yourself.
And I also think it’s awesome that Subaru has been using the same switches for so long. That’s why our cars feel like brand new 1990’s vehicles.
JesseG is offline   Reply With Quote
The Following 2 Users Say Thank You to JesseG For This Useful Post:
alex87f (11-10-2020), bcj (11-25-2021)
What's under the seat heater switch area?? gtpvette Cosmetic Modification (Interior/Exterior/Lighting) 12 04-11-2019 07:33 AM
Dimensions for Indent w/ Seat Heater buttons jfg5067 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-14-2015 05:19 AM
Center Console Seat Heater Buttons larryt1026 Electronics | Audio | NAV | Infotainment 15 07-31-2013 12:21 AM
BRZ Seat Heater Switch Trim Rings Availabe zetaproducts.net Interior Parts (Incl. Lighting) 75 05-23-2013 11:21 AM
Seat heater temperature? milenko11 BRZ First-Gen (2012+) -- General Topics 29 09-20-2012 01:19 PM
