Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-18-2019, 06:08 PM | #1 |
Drives: Take a guess...
PN for Swift Springs on KW Coilover Body
What's the correct part number and length for a pair of Swift 8k rear springs to go with a KW/Racecomp coil over?
Z60-203-080 seemed to be in the ball park if I ditch the helper spring. Has anyone used this shock/spring combination? |
08-18-2019, 10:06 PM | #2 |
8" is too long imho, I had an 8" 500# spring on my Bilstein and struggled to set height where I wanted in the rear, 7" 425# spring without helper was near perfect iirc and should be extremely similar to what you are looking for. 6" might need a helper spring which I think is their preferred setup.
I'd expect RCE would be able to respond to the question tomorrow if someone who has a set doesn't chime in first. |
08-19-2019, 09:15 AM | #3 |
You want 60mm ID. 6 or 7 inch length should be okay depending on where you want to set the ride height. May use helper either way with the 8 kg/mm spring rate, but definitely with a 6 inch spring.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | wparsons (12-09-2019) |
12-08-2019, 02:52 PM | #4 |
Travel with 6" w/helper v. 7"
Is there any difference in travel between a 6 inch spring with a helper and a 7 inch spring alone?
Thanks! |
12-08-2019, 03:31 PM | #5 | |
Check out the Eibach Motorsports catalog, they list a lot of information about block height and travel and you can compare spring stiffness and heights. You will see a general trend with small hiccups where the spring wire diameter increases but iirc is not listed. https://eibach.com/us/rt-2-catalog-downloads.html |
12-09-2019, 09:39 AM | #6 | |
You can get more travel out of a longer spring before getting coil bind, but that assumes the damper has enough travel for that to be an issue with the shorter spring. On the KW/RCE bodies a 6" spring won't be binding, so you're fine either way.
Similar Threads | ||||
Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks | EGOBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-15-2018 08:21 PM |
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs | leunglambs | NY / NJ / CT / PA | 3 | 06-09-2017 02:49 PM |
FS: MCS 1 way coilover with swift springs in Socal | mtsui | Brakes, Suspension, Chassis | 8 | 08-15-2014 09:18 PM |
Swift coilover springs 7" 8k and 7k | Proof | Brakes, Suspension, Chassis | 2 | 12-02-2013 12:59 PM |
swift coilover replacement springs 8k | pitstops | Brakes, Suspension, Chassis | 0 | 06-14-2013 03:36 PM |
