Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-05-2017, 10:38 AM | #1 |
Drives: WRB Brz / SR S14
TopHat Issue St Coilovers
Hey guys, i am currently confused on the tophat situation regarding the ST coilovers. A lot of the images are broken on the forums (thanks photobucket..) and i am having a hard time finding this information. Now, does one completely reuse the oem top hat for the STs? I have heard that people remove the lower half of it, but I am having a hard time seeing how they do so since its one piece. I have it currently installed, and the front sits a bit higher than desired. Now, i think that might just be the added height from not removing the lower perch. Does anyone have insight or images on this? thank you!
08-05-2017, 03:30 PM | #2 |
How low are you trying to get it? You might be as low as they can go already?
08-05-2017, 03:36 PM | #3 |
08-05-2017, 04:45 PM | #4 |
Drives: '13 FRS - STX
I thought the front spring perch on the OE top hat was supposed to be removed and replaced with the provided spring perch that comes with the ST's, I believe that's common with KW or any other spring/damper combo that uses a differently sized spring from OE.
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (08-07-2017) |
08-05-2017, 04:50 PM | #5 | |
Sent from my Pixel using Tapatalk |
08-05-2017, 08:27 PM | #6 | |
About 2:50 into this video they describe the top hat swap, looks like there's some awkward hardware going on, idk. http://www.ft86club.com/forums/showthread.php?t=30968 http://www.ft86club.com/forums/showp...&postcount=183 |
08-06-2017, 10:03 AM | #7 | |
08-07-2017, 10:42 AM | #8 |
If you're not going to use the OEM upper spring perch (and we do not as you can see in strat61caster's picture of our RCE coilovers), then I would highly recommend using the OEM conical washer.
Details in our instructions here: http://racecompengineering.com/instr...structions.pdf Our RCE coilovers are made by KW so instructions are similar for your STs. - Andrew Last edited by Racecomp Engineering; 08-07-2017 at 12:38 PM. |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | drew_kar (08-07-2017) |
08-07-2017, 12:19 PM | #9 | |
It looks like you meant the upper spring seat that's attached to the OEM upper mount? If that's the case, you definitely want to remove it.
The Following User Says Thank You to wparsons For This Useful Post: | drew_kar (08-07-2017) |
08-07-2017, 12:23 PM | #10 | |
08-07-2017, 02:04 PM | #11 | |
(this is all about the front top hats, the rear top hats absolutely have the spring perch integrated into the top hat and is unchangeable) |
08-07-2017, 09:21 PM | #12 | |
Similar Threads | ||||
FS MA: RCE Tarmac 2 with OEM tophat, $1650 | dreamwonder | Brakes, Suspension, Chassis | 8 | 08-09-2016 07:43 AM |
FS SOCAL - OEM STRUTS SPRINGS TOPHAT | JGalp | Brakes, Suspension, Chassis | 11 | 04-10-2016 11:27 AM |
Front camber from LCA, hub and tophat | Manji | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-24-2015 05:10 PM |
Issue with BC BR extreme low coilovers | 86TruenoFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 08-17-2013 09:27 AM |
Stance coilovers lowering issue | Dispect | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-06-2013 11:05 PM |
