07-23-2016, 01:11 PM | #3543 | |
Drives: 2013 WRB BRZ
I know I can do it I've done everything on my car including the air suspension. Just never messed with taking apart an actual camber plate before. |
07-23-2016, 08:51 PM | #3544 |
Drives: 86 GTS
I never thought I'd actually be able to post here
IMG_0346 by Sebastien Peek, on Flickr IMG_0349 by Sebastien Peek, on Flickr IMG_0351 by Sebastien Peek, on Flickr Unfortunately no full car shots |
The Following 3 Users Say Thank You to Tranz For This Useful Post: |
07-24-2016, 05:42 AM | #3545 | |
I think it looks good. Ever consider a 215/40? Not sure how much bag clearance you have for more camber. |
07-24-2016, 09:35 PM | #3546 |
Aloha Served Daily
Drives: 2015 BRZ World Rally Blue
Hopefully this is good enough. Still rebuilding my SSR Vienna Courages, however currently running on these Work Kiwamis. 17x9 +23 (effective, +38 w/out 15mm conversion spacer).
WORK CR KIWAMI by Jessie Alex Gabbuat Jr, on Flickr Last edited by RSKYBZ; 07-25-2016 at 02:16 AM. |
The Following User Says Thank You to RSKYBZ For This Useful Post: | Lococholo84 (08-06-2016) |
07-31-2016, 03:39 PM | #3548 |
Drives: 2015 Raven Black FRS
Anybody ever ran an 18x10 -1 in the rear? Or anything similar ? 5 inch lips.
08-01-2016, 01:17 PM | #3549 |
Work CR-Kai Kiwami
18 x 9.5 +38 all around 10mm spacer in front 5mm in rear
-Flickr-
IG @illmattic86 |
The Following 3 Users Say Thank You to illmattic For This Useful Post: |
08-02-2016, 08:36 PM | #3550 |
__(X)__
Drives: '11 Legacy, '89 190E, '78 GS1000
IG: @dustin_faulkner
The Following User Says Thank You to Kuzuri For This Useful Post: | 8R6 (08-23-2016) |
08-03-2016, 01:25 PM | #3551 |
Drives: HONDA, TOYOTA
Sent from my SM-G935V using Tapatalk
New build threadhttp://<a href="http://www.ft86club....p?t=100921</a> Kini will be deleted
#KINI86 build thread @HAWAIICALIVEGAZ |
08-03-2016, 10:06 PM | #3552 |
Drives: 2015 dgm brz
made some minor adjustments fitment wise and im content with it for now.
18x9.5 +5 on airlift bags. around -5 camber all around. ordered some spacers to play around with fitment, hopefully try and get -8 all around when they come in. @wutangbrz if you would like to see what more stupid things i do to my car Last edited by wutangbrz; 08-03-2016 at 10:31 PM. |
The Following User Says Thank You to wutangbrz For This Useful Post: | Lococholo84 (08-06-2016) |
08-06-2016, 04:28 AM | #3553 | |
Drives: 86 GTS
08-08-2016, 01:10 PM | #3554 |
08-08-2016, 01:46 PM | #3555 |
Drives: 13 FRS
The Following 4 Users Say Thank You to JDLAutoDesign For This Useful Post: |
08-11-2016, 12:59 AM | #3556 |
Drives: 86 GTS
Possibly grabbing some really rare wheels but I believe they are flat backed, and I want to run some spacers to get the fitment right.
Anybody know how big of a spacer you need for the stock studs not to poke through? -I'd rather not be cutting studs but so be it if its required, hence why I'm asking- |
Tags |
dontlike?dontlookmoveon |
Similar Threads | ||||
Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1742 | 10-11-2017 04:29 PM |
RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 02:30 PM |
post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 10:11 PM |
Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 10:03 PM |
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
