GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
04-14-2024, 11:15 PM | #15 |
Drives: 2024 MT Toyota GR86
Do you still have your spare?
2024 Toyota GR86
2013 Scion FR-S |
04-16-2024, 10:51 AM | #16 |
Drives: BRZ SWP Limited -6MT
planned on salvaging my spare from gen 1 when I move to gen 2. no timeline on that tho. pickins are still slim
04-22-2024, 06:13 PM | #17 |
Drives: 2017 GT86
My 2017 '86 has no foam spacer under the tire. Toyota's owners manuals seem to bear this out; the later versions that cover TRD edition, they show the foam spacer only for cars that have a 17" spare wheel, while 16" spares do not have it. I haven't checked Subaru's equivalents, but expect they would be the same.
The parts diagrams I see for this part number seem to indicate it's a sheet metal 'volcano' that's spot-welded into the bottom of the spare tire well to provide the nut the retain bolt threads into. Presumably they wanted this nut higher to allow a shorter bolt for more accurate positioning. It's shown on the same figure as other sheet metal components forming the trunk compartment. The need for the spacer isn't so much for the respective tires being 16" and 17", but rather that the 17" rim for Brembo brakes is domed out much more to clear the brakes. So with the tire (rubber) resting on the trunk floor, the centre of the Brembo spare wheel would have to poke through the floor while the regular spare doesn't. The spacer is to bring everything up with the Brembo spare. Odd observation: between the 16" and 17" spare wheels, the 16" is a closer match to stock 17" tires' effective diameter. The 17" spare wheel is the closer match to the stock 16" (JDM, Australian, China, maybe other makets) tires. Additionally, the 17" spare from other Subaru models might not necessarily work. I'm thinking specifically of the spare for Brembo-equipped WRXes; some people assume since the WRX has Brembo calipers, the spare must work for BRZs with Brembos too. However, what they're missing is that the instructions for the WRX are to put the spare wheel on the rear, and install the fuse that puts the car into FWD mode. I imagine its the same story with other AWD Subarus. So unless somebody has a way to put their BRZ into FWD mode, I wouldn't simply conclude some other Subaru wheel works. It might anyway, it might not, but you really need to test fit to know for certain, and not just deduce that it does. Last edited by Luns; 04-22-2024 at 06:24 PM. |
The Following 2 Users Say Thank You to Luns For This Useful Post: | Ohio Enthusiast (04-22-2024), ruturaj001 (04-23-2024) |
04-23-2024, 06:02 PM | #18 | |
Drives: BRZ 2023
04-25-2024, 10:54 AM | #19 | |
Drives: X5 35d, D90, CX-5 Turbo
Not trying to be an A$$, but unless specified in the manual for some specific reason I think this is incorrect, and potentially dangerous advise from a driving dynamics standpoint. Since the front tires handle much higher loads from braking, turning and usually carry the higher percentage of a vehicle's weight (since the engine is generally in the front), it is best NOT to install a temporary spare on the front. I've always been under the impression if you get a flat on the front, that it is best to move a rear tire to the front, and install the temporary spare on the back. As long as you are not trying to accelerate swiftly, or drive aggressively, with a temporary spare on the back of a RWD car, the small temporary spare is better suited to the loads the rear wheels will encounter. And, although most seem to ignore it, it is best to remember that a temporary spare is only meant to get you off the highway and to a repair facility, not to drive around on for days (or more) till you repair or replace the damaged tire. EDIT: Gen 2 cars don't come with spare tires, so there is no mention in the manual. Owners manual for Gen 1 cars does indicate to "Install the compact spare tire on a front wheel." as OP has noted. Have to assume this is because the temporary spare is of a smaller diameter, and the concern for wheel speed difference possibly damaging the limited slip diff. When I'm wrong, I'll admit I'm wrong, but for those with other cars, know this is not a general rule of thumb for all vehicles, check your manual.
~Scott T.
'95 NAS D-90 ST '13 BMW X5 35d '22 CX-5 Turbo '?? 86 one day soon? Last edited by LRNAD90; 04-25-2024 at 11:20 AM. |
The Following 2 Users Say Thank You to LRNAD90 For This Useful Post: | Busybee (04-25-2024), Ultramaroon (04-25-2024) |
04-25-2024, 02:53 PM | #20 | ||
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
That said, it is a general rule of thumb for vehicles that have limited slip differentials to not run spacesaver wheels where the differential is. (Note that there are front wheel drive vehicles with limited slip transaxles, so sometimes you do not put them on the front...). Any difference in circumference (larger or smaller) between the wheels connected to a limited slip differential has the potential to cause damage: For clutch type differentials it will wear out the clutches. For all types of limited slip it will generate additional heat and can lead to breakdown of the oil.
04-25-2024, 06:16 PM | #21 | |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Similar Threads | ||||
2024 ts trim | Shub Deetle | BRZ Second-Gen (2022+) -- General Topics | 30 | 01-25-2024 07:38 PM |
S-FR.... or not (TAS 2024) | spike021 | Other Vehicles & General Automotive Discussions | 7 | 01-23-2024 05:30 AM |
PRICING ON 2024 BRZ | ruturaj001 | BRZ Second-Gen (2022+) -- General Topics | 12 | 11-16-2023 12:23 AM |
2024 BRZ tS Releaved | Rainy | BRZ Second-Gen (2022+) -- General Topics | 55 | 08-12-2023 04:20 AM |
Performance Package spare tire vs. regular spare | JeremyR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 67 | 09-22-2022 09:36 PM |
