Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
03-22-2016, 08:24 PM | #15 | |
Drives: Full race 4cyl boxer
Many cars on the street & race cars intentionally reduce rear wheel braking under panic situations for exactly that reason. You NEVER want the rears to lock before the fronts. Therefore it is 'safer' to have the better tires in the rear to minimize the possibility of it happening. |
03-22-2016, 08:26 PM | #16 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
I agree with mistersheep (sell the old rears) but,
I run Michelin Pilot Supersports in the front, and Dunlop Direzza DZ102's in the back. The DZ102's have moderately less grip than the Super sports: but they're not bad by any measure. They also have a much higher treadwear (460 vs 340) and last noticeably longer without sacrificing much grip. Best part is that the handling characteristics are perfect. Granted I'm also fairly modified suspension wise... I'd DEFINITELY run a better tire up front if you're at all comfortbale correcting oversteer in that super unlikely scenario that it occurs. I'd say it's also much more important to be able to steer, if you're going to run a lower performance tire somewhere, don't put it on the wheels that are the difference between hitting that deer or weaving around it. All IMHO
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
The Following User Says Thank You to Keenercarguy For This Useful Post: | nickmerronesucks (03-22-2016) |
03-22-2016, 08:41 PM | #17 | |
Drives: 370z
http://www.tirerack.com/tires/tirete...jsp?techid=52& I like how all the boy racers try to optimize for lap times... while you drive on the street. If you care enough about driving dynamics, then buy new tires. If you don't care enough, then don't risk your life and the lives of others around you. |
03-22-2016, 08:48 PM | #18 | |
Drives: 370z
When you are on the street there are so many things you can't control. If there's rain, someone doesn't see you and cuts you off, debris is in the road, there's an accident, there's a puddle, oil, leaves, so many things. It doesn't matter what you do, it is a lot safer to have better tires in the rear. Swap them when you get to the track. |
The Following User Says Thank You to totopo For This Useful Post: | strat61caster (03-23-2016) |
03-22-2016, 08:50 PM | #19 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I am not worried about over steer:
I can correct it. I was simply asking if there was any benefit to have a STICKIER tire not more or less tread. In the front VS the Rear..On the drift car I was running a very sticky front tire and junk in the back. thanks for the input but this has gone in the wrong direction. with the putting peoples lives in danger non sense. FWIW the brz is a weekend toy that i just take to car meets and drive the twistys near me and sometimes to work.
797Performance.com
03-22-2016, 08:56 PM | #20 | |
Ned flanders
Thanks this was the answer I was looking for. This is how I thought of it as well.
797Performance.com
03-23-2016, 12:46 AM | #21 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I ran Kumho Ecsta XS on 17x8 +36mm offset up front with stock Primacy on 17x7.5 +40mm rear for a little bit (because of worn rears on the XS) and had a more of a blast daily driving than on the stock tires all around. Definitely had to be on top of it more but was nothing dangerous. Would definitely put sticker tires up front...stickier tires in the rear makes no sense at all except for drag racing...
Front end understeering and not being able to turn in as well as a stock FR-S because the rear doesn't want to rotate as easily does not inspire confidence - compared to the rear behaving just like stock but with better front end turn-in and grip. And at a minimum hold button to keep TCS and VCS off...will go a little nuts and stupid on you if left on.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
03-23-2016, 01:08 AM | #22 | |
03-23-2016, 02:49 AM | #23 |
Drives: '13 FRS - STX
Relevant fun:
http://www.ft86club.com/forums/showthread.php?t=98681 |
03-23-2016, 12:38 PM | #24 | |
I believed the opposite at first, but I was convinced eventually. And as I stated above: BOTH my sons work at tire stores and they are both taught - better tires on the rear, or we wont put them on. |
03-24-2016, 10:27 AM | #25 |
I like to eat!
Better tires (ones with the most tread) are always installed on the rear at tire shops simply because a rear flat is considerably more dangerous at speed than a front flat.
03-24-2016, 10:37 AM | #26 |
Ned flanders
Again has nothing to do with the original question but great opinion.
797Performance.com
The Following User Says Thank You to nickmerronesucks For This Useful Post: | SlammedSilly (03-25-2016) |
03-24-2016, 11:25 AM | #27 |
Drives: 2015 Ultramarine FR-S
NICK MERRONE SUCKS!
that is all |
03-24-2016, 11:31 AM | #28 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I would get tires squared away before worrying about dyno time. What good is power if the thing that keeps it to the ground isnt squared away |
The Following User Says Thank You to finch1750 For This Useful Post: | Leonardo (03-24-2016) |
Similar Threads | ||||
FS: Raybestos ST-43 front and rear pads. Front for Stoptech BBK, rear for stock | rever5e | Brakes, Suspension, Chassis | 1 | 03-16-2015 12:02 PM |
Does anyone regret putting stickier tires on? | unsurety | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 05-14-2014 03:50 PM |
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear | Amalgamo | Brakes, Suspension, Chassis | 3 | 04-24-2014 07:22 AM |
Full Report: Road & Track tests stickier FR-S/BRZ tires | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 74 | 08-15-2013 01:10 AM |
Rear Parking Brake Guard Rub (Meaty Rear Tires) | console_cowboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-13-2013 02:39 PM |
