07-22-2012, 09:10 PM | #43 |
OH HEY NOW!!!!
Drives: 2013 Scion Fr-s Asphalt
Hope this won't be a personal preference thing like u want a better response or balance engine?
07-22-2012, 09:38 PM | #44 | |
07-22-2012, 10:14 PM | #45 |
Drives: Acura RSX
Nice mod, great value. Whenever I get my BRZ this will be one of the first on my todo list. I've been running one on my RSX for at least 30K with no problems whatsoever.
The Following User Says Thank You to exmayol For This Useful Post: | M3MPHIS (07-28-2012) |
07-22-2012, 11:48 PM | #47 |
6/22/12-2/6/24
07-23-2012, 12:00 AM | #48 |
Drives: 2013 Premium White, 2006 TL
Why
Why is this the ONE pully that is being replaced and not the others? And how can such a small amount of weight make a noticible difference as compared to changing all of them or the fly wheel? Also. A little worried that the original one has a rubber dampener. Is there a good reason for that?
07-23-2012, 12:03 AM | #49 | |
I Love custom Turbo kits
Drives: Limited BRZ
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | DrDuquette (07-23-2012), Silver Bullet BRZ (07-23-2012) |
07-23-2012, 12:06 AM | #50 | |
6/22/12-2/6/24
If all of them have been changed to lighter ones then it'd be better than just 1 pulley. I still don't understand why it's just one pulley being changed :/ I'm sure if you replace all of them you can get a lot of weight off |
07-23-2012, 12:09 AM | #51 | |
Drives: Limited BRZ
Edit: But honestly, I am not too sure how much benefit there is from changing the other pulleys. Remember, changing the crank one equals removing weight from the crank. Removing weight of all others is just removing mass off axis and I don't see much benefit in that. (There is some benefit sure, but I don't think its a lot).
07-23-2012, 12:11 AM | #52 | |
6/22/12-2/6/24
well I plan on doing a flash one day ... I guess that's when I'll swap them all out. hopefully that takes care of that |
07-23-2012, 12:14 AM | #53 |
Sorry. I didn't read the whole thread about the rubber dampener.
But it shouldn't matter which pully is made lighter. Anything that the belt TURNS could bennifit from being lighter or removed. It all weight that has to accelerates or decelerate buy the rest of the engine. Example, remove the AC compressor. But now go deeper. So anything that is turned buy the engine can bennifit from wieght reduction. That's why we talk wheel weight and size too. |
07-23-2012, 12:16 AM | #54 | |
Drives: Limited BRZ
Edit: Let me put it this way, I'm sure there is gain and at the right price makes sense to go for it. But care needs to be taken regarding ECU accidentally believing misfires are happening.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | DrDuquette (07-23-2012) |
07-23-2012, 12:24 AM | #55 |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
The perrin unit is balanced also...
The Following User Says Thank You to jedibow For This Useful Post: | DrDuquette (07-23-2012) |
07-23-2012, 02:49 AM | #56 | |
Drives: Toyota 86 GT
One of the things I first noticed driving this car was the slow reactions of the engine due to flywheel (and pulley) weight. I find my gear changes are faster with lightened flywheels. |
Similar Threads | ||||
Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
pulley installed issue | Sall | Issues | Warranty | Recalls / TSB | 31 | 08-14-2012 11:36 PM |
Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 10:24 PM |
