07-29-2014, 02:01 PM | #1513 |
Off Topic
07-29-2014, 02:15 PM | #1514 |
[ame="https://www.youtube.com/watch?v=dQlQt5_N1yk"]Bicycle On Mustang Dyno - YouTube[/ame]
Ultramarine 2013 Scion FR-S 6MT
The Following 3 Users Say Thank You to CaptainSlow For This Useful Post: |
07-29-2014, 02:39 PM | #1515 |
Off Topic
07-29-2014, 06:11 PM | #1516 | |
Drives: FR-S 10 #103 AT
If I bring it up to the rev limit, it slowly drops down to 7000 then starts coming back up. Is that the intention?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
07-29-2014, 06:49 PM | #1517 | |
Drives: 2014 BRZ Limited, 2013 Focus ST
07-29-2014, 07:04 PM | #1518 |
Drives: 13 FR-S: Raven
Noob question
So I know by default OFT comes with A01C. Last night my OFM was showing A00C so I downloaded a couple 2.01 maps. Specifically, just flashed to EL 85 as I still have E85 in tank. For $2.55 a gallon over $3.88 with more power is a no brainer!
Prior to the flash my tablet was showing calibration code ZA1JB01C (not same as OFM). Decided to go ahead and flash the A00C maps anyway as that is the only file OFM would let me download last night. Upon completing the flash my calibration is now reading ZA1JA00C. As I sit here at idle about to go through relearn all my channels appear normal. Just don't quite understand the different cal figure readings between OFT and OFM. Sorry if this had been discussed, but there are way to many OFT posts to read through. Last edited by driftu; 07-29-2014 at 07:06 PM. Reason: listed wrong file code |
07-29-2014, 07:38 PM | #1519 | |
Drives: FT86
As long as the last letter is a C its all good. The last letter is the overall rom type C is usa/canada G Europe/Australia and their are several others. The previous 3 leters/numbers are the revision numbers 700,900,A00,A01,B00,B01 , your car may have come with any one of these as stock. The latest OFT maps are based on B01C roms but the internal calid is changed to match your original calid so the oft will load it as it wants to match calid,s, the 1.5x tunes were based on A01C maps. So depending where you look the revision changes but not the overall rom type ie C in your case |
07-29-2014, 07:55 PM | #1520 | |
thanks
The Following User Says Thank You to driftu For This Useful Post: | Triumphrider (07-29-2014) |
07-29-2014, 07:59 PM | #1521 |
Drives: 2013 Scion FRS in white out
@driftu you'll love the uel header, alot more grunt down low.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
The Following User Says Thank You to Triumphrider For This Useful Post: | driftu (07-29-2014) |
07-29-2014, 08:02 PM | #1522 | |
07-29-2014, 09:00 PM | #1523 | |
07-29-2014, 10:46 PM | #1524 | |
Drives: FT86
It appears its set up for around 75%E so if you fuel mix is close to that and your maf scaling is fairly good (stock intake) their is not much to learn so its quick. just keep an eye on the ltft throughout the rpm range there are about 4 bands from low to high (it actually maf flow rates) so you may see a change in ltft between idle and mid and high rpm, as long as its less than about 10% in all ranges you good to go. |
The Following User Says Thank You to steve99 For This Useful Post: | driftu (07-29-2014) |
07-29-2014, 11:18 PM | #1525 | |
Stupid ? For NA, what data channels should I be focusing on in terms of logging. Also, if I enable the wideband AFR channel is itaccurate? The numbers appear to be within the desired ranges I've read about. Assuming the readings are legit...or do I need aftermarket O2? Keep in mind I'm going UEL soon too. Gracias |
07-29-2014, 11:49 PM | #1526 | |
Drives: FT86
The wideband should be more acurate than stock sensor but you need to buy the required sensor and it probably best if headers are catless for most acurate readings as its the sensor after the header cat that you replace. If your just logging your tune wideband probably not needed but if you want to tune to the limits its probably a good idea, the stock one get a bit inaccurate at higher rpm according to shiv |
The Following User Says Thank You to steve99 For This Useful Post: | driftu (07-30-2014) |
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Similar Threads | ||||
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
