Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 08-28-2013, 05:50 PM   #1
gt8613
I dream of BRZ
Drives: Prospective BRZ owner.
Arrow What have been your 0-60 times?
HAHAHAHHAHAHAHAHAHAHHAHAHHAHAHAHAHAHHAHAHHAHAHAHAH AHAH
is my reaction when I see in articles or even our holy Clarkson read off the pamphlet that the twins do 0-60 in an astonishing 7.7 seconds...
My dads E60 525i (215hp/185tq) & probably 3500+ ibs does it in 7.6 secs. And that is in Auto without the "sport" mode on.
So what are the actual 0-60 times of the twins? I can't imagine a nearly 1000 ibs less car with 200 hp (maybe the torques the issue) does it in 7.7 secs.
gt8613 is offline   Reply With Quote
Old 08-28-2013, 05:53 PM   #2
Chauntalei
Drives: Non-BRZ
Motor Trend says the Limited AT took 7.7, which was 1.3 slower than the 6MT, putting it at about 6.4, which is in line with most other 6MT 0-60 times I've heard. 6.2-6.5 is pretty 'standard'.
2013 SSM BRZ Limited 6MT - 5/28/2012-10/28/2014
Chauntalei is offline   Reply With Quote
Old 08-28-2013, 06:02 PM   #3
s0sl0w
Proud of Boxer
The best time I've seen quoted for a manual was 6.1
I think with good rims/tires and aggressive launches you could see consistent low ~6.x times.
s0sl0w is offline   Reply With Quote
Old 08-28-2013, 06:12 PM   #4
gt8613
I dream of BRZ
Those times make a lot more sense. What about if we switch out the un-grippy stock tires...Any data on how much the performance summer tires help the brz do it in?
The Motor Trend babe (lady) visiting tire-rack says she shaved more than a second on her best lap around the track with a BRZ and that the tires were the most cost-effective upgrade for the vehicle.
LINK: [ame="http://www.youtube.com/watch?v=QQwWdZ00HYQ"]Modifying the 2013 Subaru BRZ! The First Change a Driver Should Make - Wide Open Throttle Episode 39 - YouTube[/ame]
Old 08-28-2013, 06:12 PM   #5
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
With the FR-S power to weight ratio, 0-60 should be in the low 6's!
meadowz06 is offline   Reply With Quote
Old 08-29-2013, 12:10 AM   #6
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Would an automatic on manual mode have the same 0-60 times as a manual (assuming driver in manual does not build RPMs & drop that clutch)?
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 08-29-2013, 12:20 AM   #7
thill
0-60 in 6.5 is what Edmunds clocked it at and they are conservative (6.2 seconds with 1 ft rolloff). I would say 6.2-6.5 with the manual should be consistent.
With some minor mods, you should be able to get the car in the high 5's I would think.
Old 08-29-2013, 12:24 AM   #8
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
By look alone, the twins should be able to do 0-60 in 4.2 seconds.
MY13FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to MY13FRS For This Useful Post:
gt8613 (08-29-2013), mwjcyber (02-02-2014)
Old 08-29-2013, 12:30 AM   #9
StickThatClutch
Unsprung Weight.
StickThatClutch's Avatar
Drives: GBS BRZ, S70 T5, 2002 tii
Hard to say.
Well getting away from a stand still with the manual still requires applying some throttle, unless you let the clutch out real slowly without throttle then mash the gas when it catches. If you did that the auto would probably be a car or two ahead of you before you could apply 100% throttle.
If you held the revs at say 1500 or so just so the car didn't bog when you dumped the clutch might be pretty close, if the auto just mashed the gas from a dig.
I don't think being in manual mode will help the 0-60 time in the auto. It should shift at redline just as fast under full throttle as it does in manual mode.
Drive safe.
Stephen.
StickThatClutch is offline   Reply With Quote
Old 08-29-2013, 08:14 AM   #10
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
i think the topgear 0-60 time was actually the 0-62 time because here in belgium they are advertised as 0-100kmph in 7.6sec(0-62mhp) but yeah they should be faster
GT86meMR2 is offline   Reply With Quote
Old 08-29-2013, 09:04 AM   #11
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
This may sound dumb, but which traction mode gives the best take off and best 0-60 time?
Full traction ON stops power to the wheels so I'd think either sport mode or Holding the trac button for 5 seconds.
I drive a 6MT.
ericmpena is offline   Reply With Quote
Old 08-29-2013, 09:13 AM   #12
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I've registered a few 5.9 with light wheels, sticky tires, muffler delete and drop in filter.
I drive a 6MT.
Full off. Sport mode turns TCS off, supposedly, but the stability cuts in if you have any angle at all, which always happens in a hard launch.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
ericmpena (08-29-2013)
Old 08-29-2013, 09:46 AM   #13
Frstorm
Drives: 2013 Firestorm
6.7 stock at
Frstorm is offline   Reply With Quote
Old 08-29-2013, 10:29 AM   #14
tacoss23
Drives: '08 328i, '13 Accord Sport, '13 BRZ
What I would really like to know is what are the 0-60 times for Vortech SC BRZs....
nobody seems to post their data outside of whp and dyno sheets.
tacoss23 is offline   Reply With Quote
The Following 2 Users Say Thank You to tacoss23 For This Useful Post:
gt8613 (08-30-2013), PStaff716 (09-02-2013)
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Fun times John.Hong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 07-24-2013 03:46 AM
0-60mph Times boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 81 03-03-2013 02:43 PM
How many times have you been pulled over? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 71 11-28-2012 11:28 AM
Visconti 0-60 times cuddefred Engine, Exhaust, Transmission 0 09-26-2012 08:06 PM
