Tracking / Autocross / HPDE / Drifting What these cars were built for! |
02-13-2018, 09:31 PM | #43 |
Drives: Car
Were they possibly cutting corners at the expense of safety? Skipping a proper harness/cage for a lower weight. I don't think there would be tech. Seems like with a budget like TRD they would rent out the track for their own private use and just run.
02-13-2018, 10:13 PM | #44 |
Site Moderator
Drives: ichi 86 Project
Haha you sir have a good point... but at least TRD “should” worry bout the driver’s safety
02-13-2018, 10:51 PM | #45 | |
Drives: 2015 Raven FRS
The Following 2 Users Say Thank You to Lunatic For This Useful Post: | Racecomp Engineering (02-13-2018), Tristor (09-19-2018) |
02-13-2018, 10:58 PM | #46 |
This isn't a US vs Japan thing....Takata themselves say not to mount a harness that way. Looks like it doesn't fit the JAF rules from the pdf you posted either.
This is exactly what pisses me off about that car (and other's like it). Yes it's got some really interesting engineering and looks really cool. But it is clearly unsafe (regardless of rules) and doesn't follow any recommended safety guidelines anyway (US or Japan). But...it's TRD/Toyota so most just assume that it's okay. People will defend it because they think such a big name couldn't possibly do something wrong. And they'll copy it because they saw it on Speedhunters and put themselves in danger. So much of what you see at the track is people copying other people that look like they know what they're doing. That's usually fine, but in this case it's very bad. Anyway, build a light car but budget a few pounds in for reasonable safety equipment. Sorry for threadjack and rant. - Andrew |
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | FirstWinter (02-14-2018), Icecreamtruk (02-13-2018), jmimac351 (02-15-2018), new2subaru (02-14-2018), nikitopo (02-14-2018), Tristor (09-19-2018) |
02-13-2018, 11:56 PM | #48 | |
Site Moderator
Thanks |
02-14-2018, 12:27 AM | #49 | |
Drives: 2015 FRS Time Attack Monster
I just weighed my factory doors yesterday. They are heavy AF at just a few ounces under 50 lbs without regulators or glass. Shooting for around 5 lbs each with the carbon pair I'll be making. I have factory front and rear glass out, as well as the trunk and hood off. I'll throw those on the scale tomorrow and report back. The roof will be off in a couple of weeks, so I'll let you guys know on that as well. Also of note, I stripped out all of the unnecessary brackets and other sheet metal from the inside of the chassis, and there isn't much to be gained there in weight loss. I took 8 lbs 9 oz out. Spare tire well seems pretty beefy, so maybe that will be a good chunk out once it gets chopped. Does anyone have an accurate weight on the rear subframe? |
The Following 4 Users Say Thank You to LeVeL For This Useful Post: |
02-14-2018, 10:15 AM | #50 | |
Drives: Track preped NA FRS
02-14-2018, 10:41 AM | #51 |
02-14-2018, 11:41 AM | #52 |
I remember my Minibusa days, 242hp at the wheels, 1140 lbs with me in it, 0 to 60 in 2.5. I wish I was rich I would love to build a super light track only FRS just for the fun of it.
02-14-2018, 04:00 PM | #53 |
Here is my list so far. I've been weighing everything asI take it out, so hopefully this info is useful to someone.
Headliner 3lb. 5oz Trunk w/hinges 20lb 7.5oz Rear glass 14lb 7oz Windshield 25 lb 11.5oz Front Door (each) 49 lb. 8.5 oz. Door Glass (each) 7 lb. 13 oz. Window regulator (each) 3 lb. 2.5 oz Rear seat upper 14 lb 6.5 oz Rear seat lower (each) 4lb 10oz Steering linkage (rack-eps) 4 lb. 10 oz. Eps unit with key tumbler and tilt 29 lb. 14 oz. That's it for now. I'll continue to document as I keep pulling the chassis apart, especially when I get to individual suspension components. |
The Following 3 Users Say Thank You to LeVeL For This Useful Post: |
02-14-2018, 05:05 PM | #54 | |
Site Moderator
Official Component Weights & Weight Reduction Thread |
02-14-2018, 05:14 PM | #55 | |
02-14-2018, 07:23 PM | #56 | |
Similar Threads | ||||
Track car weight reduction | Irace86 | BRZ First-Gen (2012+) -- General Topics | 17 | 06-11-2016 05:21 PM |
► APEX | FR-S/BRZ Light-Weight Track Wheels | APEX Race Parts | Wheels and Tires | 7 | 05-27-2016 03:18 AM |
Oil Weight Poll For Track Usage | brillo | Tracking / Autocross / HPDE / Drifting | 49 | 07-01-2015 05:34 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
