Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-16-2019, 02:57 PM | #15 | |
Drives: FRS, 13 A/T
http://www.ft86club.com/forums/showp...postcount=2481 Ive checked the definitioms between A01 and A00 and they tend to be different, however using HxD it seems the desired tables are the same. Im not sure should I just add randomly this lines of code to my A00D file? where to add them or it doesnt really matter? UPD: I`ve actually managed to add those tabs, however at the example its Wayno`s v65-v66 and mentioned its not propertly tested. Currently he sells v143 something, so I doubt there is something changed significantly. Last edited by LLW; 10-16-2019 at 06:05 PM. Reason: UPD |
10-16-2019, 03:19 PM | #16 |
Drives: 2014 Scion FRS (Asphalt)
All your issues would be fixed if you just drove it in manual.
Are you sure you're wot? The car has a slight kick down at the top of the throttle. Lastly, oft tunes don't do much in terms of power. I can pull up a dyno sheet of a oft car with bolt ons vs a stock car if you'd like to compare. Peak gains of 3-4hp and about 5 lbs-ft torque.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
10-16-2019, 06:03 PM | #17 | |
Drives: FRS, 13 A/T
If I would love to drive manual I would pick manual car That sound weird regarding OFT coz there was a tonns of dynos which showed it gained up to 20-30 whp with boltons n OFT. |
11-06-2019, 01:50 PM | #18 |
Drives: FRS, 13 A/T
Ok so I got Wayno Rom, absoulutely brilliant it feels, I will do the test pulls after learning period will be completed.
11-13-2019, 11:47 AM | #19 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
any updates?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
12-13-2019, 07:20 AM | #20 |
Drives: FRS, 13 A/T
12-13-2019, 10:48 AM | #21 | |
Log throttle position while you're trying to make sure it's actually seeing WOT and not a problem with the sensor in the throttle pedal.
The Following User Says Thank You to wparsons For This Useful Post: | Tristor (12-14-2019) |
12-17-2019, 11:46 PM | #22 |
Drives: FRS, 13 A/T
Thanks, while I was making a pull to adjust MAF map from Wayno, I did logged it already, was 100% at some of the points of RPMs.
Similar Threads | ||||
Need advices on parking sensors | Grace | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 06-13-2013 09:29 PM |
Looking for DMG BRZ Limited 6 Speed | Jon H | Northern California | 3 | 04-21-2013 12:05 AM |
Looking for DMG BRZ Limited 6 Speed | Jon H | Southern California | 8 | 04-18-2013 12:39 PM |
FR-S newbie to Mod needs advices!! | newkid185 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-09-2012 06:39 AM |
