DIY (Do-It-Yourself) Guides For all DIYs. |
11-23-2014, 08:07 AM | #29 |
Drives: '15 red FR-S SSC
It's a bit off topic but i do my driving in New York and Pennsylvania. In both states the police rely heavily on radar. I've encountered laser in New York only once and never in Pennsylvania. New York uses a lot of moving radar. Pennsylvania state police are restricted by law to stationary raday. I saw significant laser use in Massachusetts. Police prefer using radar as doing laser speed measurement is too much like work.
12-28-2014, 08:51 PM | #30 | |
Drives: 2013 FR-S Asphault
OK so after reading this DIY and ordering this: [ame="http://www.amazon.com/gp/product/B00JG5ZMVC/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1#"]http://www.amazon.com/gp/product/B00JG5ZMVC[/ame] I found the wiring harness so accurately described above, and found the same three wires. I decided to snip off the OEM connector at the end and I will be using some single line connectors to make this easy to un-install should I need to in the future. To test the circuit, I temporarily used some wire nuts. The gray wire on the car goes to the Red in the detector harness, and the black ground on the car goes to the black ground on the detector harness. From there, the circuit goes to an in-line fuse (see Amazon page) then out to a phone jack plug into the detector. This setup is not working for me at all. I don't see any power to the detector, and none of the combinations of wires reads any Volts on a multi-meter, whether the car is running or not. Did I screw something up in the circuit by snipping off the connector? Any other ideas as to what is going on here?? I'm starting to feel dumb! All your help is greatly appreciated
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
12-30-2014, 11:11 AM | #31 |
So I figured it out!!!
It turns out people above were discussing the same problem, but since I didn't know what was going on, I didn't realize I was having the same issue. I'll document it here in case anyone else runs into the issue. If you are not getting power to the connector / wires for the harness, try the following. Turn the key to the ON position so your radio turns on. Try to move your side mirrors with the little knob on the driver's side door. If those work, you have some other problem and should stop reading this. If the mirrors won't move, I have your fix! It turns out the side mirrors and the rear view mirror harness are on the same fuse. If you're like me, you accidentally blew the fuse by messing with the connector / wires. It is 10Amp in the corner of the interior fuse box (not the one under the hood). Specifically, it is the fuse furthest towards the front of the car, and furthest to the passenger side. Pop that out and replace it with a fresh one AFTER you've got all the wiring completed per the OP. Make sure nothing is touching each other or loose so you don't blow the fuse again. You can use the spare 10Amp from under the hood if you don't have one.
03-03-2015, 01:23 PM | #32 | |
Drives: 2013 FR-S Whiteout MT
what suction cup mount is that?
When in doubt, throttle out!
03-03-2015, 04:53 PM | #33 |
Drives: 2015 Subaru BRZ Limited 6MT WRB
I am planning on getting a BRZ very soon, and just wanted to confirm, if I get a BRZ with just the basic mirror, this should also be available right?
Has anyone used it to hook up a dashcam? That would be really convenient if I didn't have to run wiring. |
03-03-2015, 04:54 PM | #34 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Did this the other day. Much cleaner.
03-03-2015, 05:58 PM | #35 | ||
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ Last edited by codesplice; 03-03-2015 at 07:06 PM. |
03-03-2015, 09:52 PM | #36 | |
05-27-2015, 03:19 AM | #37 |
Drives: 2015 FR-S
To make it cheaper and not have to buy a detector power cord:
*This worked for a Passport 8500 X50 Take a regular telephone cord and cut it to about a foot in length. Strip the red and green wire ends on the telephone cord. Green cord wire to gray car wire and red cord wire to black car wire. |
The Following User Says Thank You to Impureclient For This Useful Post: | xxBrun0xx (05-27-2015) |
05-27-2015, 01:18 PM | #38 |
Drives: FR-S 10 series
Easiest way I found was this:
>Original power cable for passport x500i plugged in to AC power outlet in glove box > plugged into RJ11 coupler (purchased at radioshack) https://encrypted-tbn2.gstatic.com/s...bykQs&usqp=CAY >Extended phone cable plugged into RJ11 coupler and routed along pillar to radar. This allowed me to "have hidden cables/power w/o cutting or splicing any wires". All necessary items (extended phone cable, RJ11 coupler) can be purchased for cheap. You're simply extending the power cable to the radar using a homemade extension cable.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
Similar Threads | ||||
DIY-Replacing Rear View Mirror/Hardwire Radar Detector | Lil Abner | DIY (Do-It-Yourself) Guides | 40 | 06-11-2020 02:48 PM |
DIY: Hardwiring your radar detector | speedracer38 | DIY (Do-It-Yourself) Guides | 108 | 09-08-2019 10:06 PM |
BRZ hardwire radar. | Jive Turkey | DIY (Do-It-Yourself) Guides | 12 | 03-20-2015 12:11 AM |
Win a Laser/Radar detector! | raul | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 10-10-2012 01:57 PM |
Radar Detector? | Longhorn248 | Other Vehicles & General Automotive Discussions | 68 | 07-14-2012 04:31 PM |
