FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
02-04-2014, 02:36 PM | #15 | ||
This is more comprehensive than most reviews actually, especially the h2h track impressions and data which you typically don't get. A lot of reviews these days seem content just testing the cars on the street and backroads. I will say, one thing they didn't comment on -- that I think they should have -- is braking. The data indicates the BRZ had a sizeable braking advantage (0.92 g max for the BRZ vs. 0.71 g for the Fiesta). I would think that would have been as much of a factor in the BRZ making up time as its "neutral" balance in turns, which they cited as the reason the BRZ was faster. Quote:
As the Twins started racking up awards, Evo went further out of their way to downplay the BRZ and GT86. At times it's nonsensical what they say (e.g., the BRZ is awful because it understeers; the GT86 is awful because it oversteers). At the same time, they've backtracked quite a bit from that initial BRZ bashing, even at times calling them good "drivers cars". Frankly it all come across as incoherent and illogical, especially if you read their reviews in the context of their earlier reviews. My guess is there's some twisting and contorting of words going on there to fit editorial decisions.
2022 BRZ Build 2013 FR-S Build |
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post: |
02-04-2014, 04:14 PM | #16 | |
Drives: Nevermorange FRS
It wasn't that bad, I'm just doing my taxes on my second monitor and I'm bitter and angry right now.
Example: "We're here today with professional racing driver ______ to show you how Meguirs car polish will make you more appealing to the opposite sex!"
SCCA T4 - FRS
02-04-2014, 07:25 PM | #17 | |
And yeah don't even remind me, my taxes are going to be a nightmare this year (moved to a different state, got married). I've been putting it off...
02-05-2014, 12:14 PM | #18 | |
I'm faster at Streets of Willow in a stock Fiesta ST than a stock BRZ/FRS; Motor Trend uses SoWS as their default track for testing. @DarkSunrise: my stance on the BRZ's balance has evolved... (pun intended) at about the same pace as EVO's. Strange. The car still pushes liek a big... if you don't drive it the way it wants to be driven. It's still faster in that understeering state. |
02-05-2014, 01:12 PM | #19 | |
I don't know your thoughts on this, but the BRZ doesn't seem that different to me from a stock FR-S, which understeers a little on entry, but can be prodded into power oversteer on exit. The FR-S might a hair more neutral from what I can tell, but hardly the axe murderer type that Evo makes it out to be. I know Randy Pobst commented on the BRZ/FR-S divide a while back and preferred the BRZ because it had that slight bit of additional understeer. He was also faster with it at SOWS if I remember correctly, so I think you're right about the car being faster with understeer.
02-05-2014, 01:17 PM | #20 | |
Get some seat time in EVOs/STis/GTRs if you can, and you'll discover how fast understeer can be... even when you're understeering, you can push the car to go faster, with more understeer, until you finally hit terminal. |
02-05-2014, 01:34 PM | #21 | |
With my FR-S, I understeer into most corners, overcooking my front tires. It's probably faster as you say for the first few laps, but inevitably my front tires get greasy. The bold part of your post is interesting though. What's the relation between being able to power oversteer and carrying more speed on entry? Are you talking about using the throttle to rotate/balance the car?
02-05-2014, 01:48 PM | #22 |
Slip angle, tangent to the turn you're making. If you're at a positive slip angle (understeering), at some point, ANY additional force will make the slip angle larger, rather than rotating the rear.
02-05-2014, 01:59 PM | #23 |
So pushing an understeering RWD car hard enough past a certain point, you can overcook a corner and generate enough understeer to negate a fair amount of power oversteer? I think that's what you're saying haha.
The Following User Says Thank You to DarkSunrise For This Useful Post: | CSG Mike (02-05-2014) |
02-05-2014, 02:14 PM | #24 | |
Yes :p Draw a free body diagram :p |
02-05-2014, 02:53 PM | #25 | |
And I take it, eventually you reach some balance between positive slip angle in the front and slight power oversteer in the rear, and that is the way to maximize your grip at all 4 corners in a turn?
02-05-2014, 03:02 PM | #26 | |
02-05-2014, 03:17 PM | #27 | |
It all makes sense in theory. Implementing it might be a different story though lol. Sounds difficult, need more driving skillz.
02-06-2014, 02:36 AM | #28 | |
Drives: TBD
Don't recall Randy complaining about understeer in the BRZ. Here are his comments when asked to compare the twins in MT's "$28K 2 Door High Performance Comparison":
Similar Threads | ||||
Ford Fiesta ST Beats Toyota GT86 on the Track in EVO Test | vh_supra26 | FR-S / BRZ vs.... | 353 | 01-22-2014 09:02 PM |
Great car/tire review for the BRZ/FRS by Randy | 2013GTRNate | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 10-02-2013 06:31 PM |
MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 01:39 PM |
Ford Fiesta ST vs Toyota GT86 | evo TRACK BATTLE | Sargy | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 06-26-2013 08:20 AM |
Great review of FR-S in winter driving | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 03-10-2013 10:10 AM |
