03-20-2016, 12:32 PM | #1037 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
The Following User Says Thank You to BigFatFlip For This Useful Post: | Luftwaffel (03-20-2016) |
03-20-2016, 01:53 PM | #1038 | |
Boost Creep
Drives: 2016 HyperBlue BRZ
I think that chart is wrong. It shouldn't max out at 4.85V @ 102kPa, it should max out at something like 250 kPa. Thanks, definitely looks like a bad sensor to me. My MAF looks good at least. |
03-20-2016, 01:56 PM | #1039 | |
For what it's worth, I also threw a p0451 code on my JRSC set up when my MAP sensor reading did not correspond with my barometric sensor. At my altitude, my baro reading is 0.94 bar but my Omni 2.5 bar sensor was reading 0.85 bar with engine off. In my case, I believe it was a tune issue. My tuner had to change the offset of my new 2.5 MAP sensor. I don't know if he had to change any scaling though. That got rid of my p0451 code! Your baro and MAP readings are way different so I don't know if this applies. |
The Following 2 Users Say Thank You to dj2020 For This Useful Post: | CSG Mike (03-20-2016), Luftwaffel (03-20-2016) |
03-20-2016, 03:37 PM | #1040 |
Boost Creep
Just took a peek online to try and find the sensor, and it's impossible to find from a legit looking source. Hopefully Edelbrock has extra stock. Why would they go with a difficult to source euro part? I am confused.
Tried to steal the sensor from my Golf R. Sensor fitting is perfect, connector is wrong. |
03-20-2016, 04:58 PM | #1041 | |
03-21-2016, 12:32 AM | #1042 |
Boost Creep
I figured it out. The MAP offset isn't correct.
This is taken with the stock sensor in open atmosphere. |
03-21-2016, 01:37 AM | #1043 |
03-21-2016, 01:43 AM | #1044 |
Boost Creep
03-21-2016, 01:49 AM | #1045 |
Drives: 2013 FRS
03-21-2016, 01:42 PM | #1048 |
Drives: 14 BSP Edelbrock BRZ
So the Edelbrock tune has a bad value in it? Why do all the other cars with their tune work? Shouldn't everyone see the same issue as you?
03-21-2016, 02:16 PM | #1050 |
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post: |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
