12-26-2013, 05:29 PM | #2409 | |
Grip>Slip
The Following User Says Thank You to xjohnx For This Useful Post: | whataboutbob (12-26-2013) |
12-26-2013, 07:59 PM | #2410 |
I've had the intercooler kit for couple of weeks and today the fuse for the pump blew out. Pump stopped working and the coolant fluid over heated and over flow out of the coolant reservoir. Changed the fuse and it's working, I'll contact Innovate and see what they say. I'm not sure why the pump is over loading the fuse.
12-26-2013, 08:00 PM | #2411 |
Drives: 2017 Camaro 1SS
Are they going to fix this thread/forum? I can't see replies
Sent from my SGH-M919 using Tapatalk |
12-27-2013, 02:40 AM | #2412 | |
Drives: '14 S4
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
The Following User Says Thank You to KSpider For This Useful Post: | whataboutbob (12-28-2013) |
12-27-2013, 08:25 AM | #2413 | |
Grip>Slip
@whataboutbob - I too would love the part #'s you up using. |
12-27-2013, 11:12 AM | #2414 |
That Guy
Drives: 2013 asphalt FRS MT
British pipe thread, FML.
Guys, when replacing these of course getting the proper thread is important but also be careful of galvanic action between dissimilar materials. Does anyone know what material the original fittings are made of? I know they won't corrode, I'm just wondering if it would be more prudent to keep them and seal them better. |
12-27-2013, 11:35 AM | #2415 | |
Drives: 2013 Raven FRS
The originals are plastic.
12-27-2013, 12:07 PM | #2416 |
FWIW, one of mine going to the brake booster came loose on the track. I improvised and slapped a ton of lock-tite around it. When I called tech support at Innovate, they mentioned they couldn't source metal fittings which is why they went with plastic. Not saying you can't find the correct size but seems like they are hard to get a hold of.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
12-27-2013, 12:24 PM | #2417 |
Grip>Slip
Any chance you can contact them to find out what fittings were used? Quite a few of us are having trouble finding properly threaded fittings.
12-27-2013, 02:04 PM | #2418 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Make sure the 2 connectors going into the lamina chamber are properly sealed aswell. |
12-27-2013, 02:28 PM | #2419 | |
Drives: Scion FRS, Subaru BRZ, Supercharged
12-27-2013, 02:40 PM | #2420 |
Drives: 2013 SWP BRZ
the fittings i used screwed right in. BSPT is British standard pipe taper. You are not going to find those in the states. I know there are differences between BSPT and NPT but the ones I used worked fine.
12-27-2013, 03:41 PM | #2421 |
That Guy
12-27-2013, 03:42 PM | #2422 |
Drives: Attitude
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post: |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
