Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-17-2012, 05:49 PM | #29 |
Drives: SSM LT MT BRZ
toast...Loaf I get it...
I'm waiting on some solid feedback that the internals are forged then I'll be developing a gt28 turbo kit for the cars, My preference is for higher rail pressure and larger DI injectors, I have experience with these parts already so that's not the part I'm worried about ATM... there is about 30-40% overhead left in most DI injectors for the power output from the factory. |
05-17-2012, 06:00 PM | #30 |
Drives: Slowly
05-17-2012, 06:25 PM | #31 | |
Drives: '06 AM V8V Coupe
05-17-2012, 06:29 PM | #32 |
yeah the increase is in increasing fuel rail pressure as most operate at 70-90 bar but the components are all rated at 150-200 bar,
once you max that out you start looking at bigger DI Injector flow rates,,,but by the time you need em I'll have it sorted out, no worries... |
05-17-2012, 07:52 PM | #33 |
Kuruma Otaku
Question is, swap with what? The D4-S looks like it has a very specific fan spray pattern, and there are only the two motors that use it. Both are making ~ the same hp/cyl too.
Because titanium. |
05-17-2012, 07:53 PM | #34 |
Right, that's the question that needs to be answered. Homemade WRX seems to be working on it
05-18-2012, 09:31 AM | #35 |
Drives: 2006 Subaru LGT
05-18-2012, 09:44 AM | #36 |
Drives: RX8 S1
pretty sure its DI only at full load, a mixture in mid and port at low.
but why assume this engine wont take boost from stock? even ~10psi i mean the 2zz in the exige is 11.5:1 and the exige s is also 11.5:1, no? when i had a chance to talk to Tada-san, he said that everything that toyota(trd) makes (and i assume subaru as well) later will be directly bolted on to even the 1st car produced. so going by what he said then, if they EVER plan on producing a s/c or t/c kit, i would assume it will be a direct bolt on.
05-18-2012, 10:14 AM | #37 |
Only thing I can add to this whole thread is that Subaru is not known to use high-strength materials or designs in their NA engines. Just enough to get the job done in stock form.
05-18-2012, 11:01 AM | #38 | |
Kuruma Otaku
All official statements have been vague enough to leave future FI possibilities open.
Because titanium. |
05-18-2012, 12:00 PM | #39 | |
05-18-2012, 01:14 PM | #40 | |
Kuruma Otaku
2) He is a marketing director. Those guys also told us no WRX STI was coming to America. 3) The WRX with specifically the STI mentionef is clearly not the only turbo platform from Subaru. Impreza, Legacy and Forester have all been turboed.
Because titanium. |
05-18-2012, 07:58 PM | #41 | |
Drives: RX8 S1
Marketing does what company says to make company look good at that point in time
05-18-2012, 08:08 PM | #42 | |
On a side note, with a supercharger I hope there's a way to remap the accelerator pedal so that the bypass is open but the engine is putting out maximum NA torque earlier, and then pushing the pedal past that gives you boost. That would give better efficiency and truly linear response. |
Similar Threads | ||||
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 118 | 11-16-2017 02:19 PM |
Report: Subaru Coupe STI Model Possible, But Without Turbo | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 168 | 07-28-2011 10:03 PM |
Assumption: Subaru=Turbo / Scion=NA | ftw-86 | Scion FR-S / Toyota 86 GT86 General Forum | 159 | 06-20-2011 03:28 PM |
Subaru BRZ Coupe STI turbo charged pictures (renders) | brandon | BRZ Photos, Videos, Wallpapers, Gallery Forum | 48 | 06-13-2011 04:15 PM |
