Old 04-22-2014, 08:42 PM   #71
vh_supra26
Site Moderator
Drives: Supra
I already made a thread on SupraForums asking this question. Below is propbaly one of the best answers I got.
I've got a '91 LS400, a '92 SC300 w/Aristo 2JZ-GTE swap, and a JZA80 hardtop at my house right now.
That is 100% bullshit. The SC and MK4 are very closely related, but the LS400 is a completely different animal. It has a vastly different suspension, control arm, knuckle pattern, different steering parts, vastly different subframes, different differential patterns (in the UCF10, anyway, the later LS's used the same pumpkins that GS's/SC's used, but that's after the SC and MK4 were made) the LS is front sump vs the SC/MK4's mid-rear sump, etc. The only thing that bolts on to an SC or MK4 that comes from an LS that I'm aware of are the 95+ 4 piston front brake calipers, and the rear differentials found in 97-03ish LS400/LS430's, depending on the rear end ratio you want.
Otherwise they're different cars.
http://www.supraforums.com/forum/sho...LS400-platform
vh_supra26 is offline   Reply With Quote
Old 04-23-2014, 02:15 AM   #72
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
I have a JZZ30 and I have pulled apart a JZA80 and UCF10. Typical arrogant SF response. My facts come from experience and magazine publications (1990s).
Engine
Transmission
Rear diff
Steer wheel
Steering mechanism
Braking systems
All will bolt into sc/mkiv with minimal modification. LS400 ecus will work with SC400s (albeit with some errors). Dashes are almost the same between LS400/SC400. Other minor things electrical things.
Look at it in a logical / business way. There is no way in hell Toyota, who spent close to $1 Billion on LS400 development, is about go developing an entirely new platform (GS/SC/MKIV). The LS400 got shortened for the GS, which further got shortened for the SC. The MKIV was the smallest of all of them.
Dont know why people are so butthurt over sharing a platform?
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 04-23-2014, 08:23 AM   #73
gymratter
Drives: BMW
Engine
Transmission
Rear diff
Steer wheel
Steering mechanism
Braking systems
are you sure about that? Toyota spent way more than that on the very limited production LFA.
the SC400 and LS400 maybe related but what does that have to do with the MK4 Supra? almost nothing from those two cars will work in the MK4.
people are getting butt hurt because no one wants a MK5 to weight and drive like a LS.
gymratter is offline   Reply With Quote
Old 04-23-2014, 02:13 PM   #74
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
JZA80/SC are the same basis, and LS is different, end of story.
mkivalex is offline   Reply With Quote
Old 04-23-2014, 05:36 PM   #75
czar07
czar07's Avatar
Rofl. the Z30 and A80 chassis are purdy much identical.
Also MKIV weighed well over 1500kg...hardly a light car. Dont expect a new rendition to be much lighter.
Old 04-23-2014, 05:38 PM   #76
czar07
czar07's Avatar
It may be different, but my point has always been that the SC is a heavily modified LS chassis. People are just butthurt because they think MKIV is some unique awesome thing. Wake up it uses an engine from an Aristo and a chassis from a Soarer.
Old 04-23-2014, 07:32 PM   #77
gymratter
Drives: BMW
3,200-3,400lbs was much lighter than the LS400 at 3,800-3,900lbs.
MK4 weight about the same as the competition (Subaru SVX, 300ZX, R33, 3000GT/GTO).
the current LS is 4,200-4,300lbs. it make much more sense to under FT1 with the much lighter Lexus RC at only 3,500lbs.
chassis refers to body or frame. the MK4 doesn't use the SC's body...
you have an interesting definition of platform and chassis.
Old 04-23-2014, 09:03 PM   #78
czar07
czar07's Avatar
Everyone has their own definition of what chassis is. I think we are now very offtopic.
The question was what the 86 chassis could be used for, and in my opinion itt wont be used on the FT-1. FT-1 will either be RC-F (as stated above) or LF-LC.
I believe it may be the LF-LC. Lexus confirmed that the LF-LC will be made. Where the underpinnings for the LF-LC come from, I dont know, but an article suggested the existing LS platform may be modified for it. Another one suggest a brand new platform..no one will know till official facts and figures are announced anyway.
I assume the LF-LC will end up being the new SC and it would not be illogical to assume that the FT-1 MAY be based of that (looking at the history of the two cars). All of this is speculation till more information is revealed by Toyota/Lexus.
Also RC-F is 3700lb. Check ClubLexus
Old 04-24-2014, 12:15 AM   #79
gymratter
Drives: BMW
I was talking about the RC350 and not the RCF.
underpinning the LF-LC would make the price tag for FT1 to high. the LF-LC is not a new SC, its a new model. hint the new name "LC".
the new "SC" could be the BMW/Toyota joint sports car. a BMW official has confirmed they are talking with Toyota about a midsize roadster (check Carscoops for interview).
Old 04-24-2014, 10:31 AM   #80
vh_supra26
Site Moderator
Drives: Supra
Here is what ClubLexus has to say on the matter.
http://www.clublexus.com/forums/ls40...kiv-supra.html
From my understanding; the differences between chassis and platform.
Platform
Chassis
Old 04-24-2014, 05:49 PM   #81
czar07
czar07's Avatar
The bottom picture you posted is what I would consider to be the unibody/body. The top picture would be platform/chassis (suspension, hubs, engine, etc.).
It seems both your Supraforums and ClubLexus posts were quick to bashing, but no one produced any actual proof to back their arguments up. Then again neither did I. I guess its just my opinion / speculation then.
You could be right about the LF-LC being too expensive, but lets see what happens.
BMW and Toyota are supposed to be doing an MR-2 sized car from my understanding..again speculation as there have been no other details revealed
Old 04-24-2014, 06:13 PM   #82
vh_supra26
Site Moderator
Drives: Supra
There has been lots of debuts on the meaning of platform and chassis and will sometime even variety from automaker to automaker as well. Some definition of chassis includes the body/frame as well, so I guess everyone's definition will be a bit different.
Actually, it has been confirmed in a press release the BMW/Toyota car will be a midsize sports car. Just speculation, but I'm thinking maybe something like a Mercedes SL fighter.
Old 04-24-2014, 06:32 PM   #83
czar07
czar07's Avatar
Interesting, because I thought the Lexus LF-LC was going to be an SL fighter??
Old 04-24-2014, 06:41 PM   #84
vh_supra26
Site Moderator
Drives: Supra
The LF-LC is a 2+2 luxury coupe (LC), like the Mercedes S-Class Coupe (CL), (rumored) BMW 8-Series, and Cadillac Elmiraj. All of those cars are based on a flagship sedan.
Render
Takanobu Ito confirms he was responsible for V8 RWD Platform & V10 NSX cancellation! vh_supra26 Other Vehicles & General Automotive Discussions 21 04-29-2014 09:28 AM
EcuTek continues their commitment to the BRZ/FRS/GT86 platform! Visconti Software Tuning 46 09-09-2013 06:00 PM
Anyone have experience with Nitron coilovers on this platform? wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-29-2013 08:32 AM
86 platform so good that new Supra and Z4 may use it 7shades Scion FR-S / Toyota 86 GT86 General Forum 20 02-12-2013 12:10 PM
