Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-24-2024, 03:58 PM | #1 |
Drives: 2013 Scion Frs
2nd gen GR86/BRZ struts on 1st gen?
As the title suggests, I am inquiring on if it is possible to upgrade the first gen suspension with 2nd gen struts/dampers? I hear that the 2nd gen rides a lot smoother than the first gen. I currently have a 2013 FRS.
04-25-2024, 11:21 AM | #2 |
If you're swapping in complete 2nd gen assemblies (dampers + springs + top mounts) then everything goes in nice and easy. The 2nd gen parts do ride better than a 2013 for sure. I would recommend swapping in the complete assemblies to make install easier (no spring compressor needed) and also because your 11 year old rubber top mounts are likely worn by now anyway.
The rear shock is slightly different on the 2nd gen, so you can't easily use 1st gen springs on 2nd gen rear shocks. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | kevaughan (04-25-2024) |
04-25-2024, 04:10 PM | #3 | |
Do you know if the 2nd gen assemblies have a smaller diameter than the 1st gen assemblies? Mainly curious to see if there is additional strut to wheel clearance by going with the 2nd gen set up vs something like a PP Sach damper for those that don't want to go to a coilover just to fit a wider wheel and tire combo. |
04-26-2024, 10:00 AM | #4 | |
https://www.ft86club.com/forums/showthread.php?t=147964 - Andrew |
Similar Threads | ||||
FS: Noble Steel Hood Struts for Gen.2 BRZ and GR86 | toeout | Engine, Exhaust, Bolt-Ons | 0 | 06-07-2023 10:09 AM |
San Diego: 2022 GR86 OEM Premium GR86 Rims | GRime86 | Wheels and Tires | 3 | 12-10-2022 04:52 PM |
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
Airlift performance air struts (only struts) | RavenFR-Sowner | Brakes, Suspension, Chassis | 1 | 11-01-2015 04:51 PM |
JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 10:21 AM |
