Old 05-05-2015, 10:52 AM   #141
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Kosmos View Post
Any tutorials or maybe someone from here can tell me how to remove the rear hubs
This thread somewhere earlier it was described with pics...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-05-2015, 10:55 AM   #142
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by qoncept View Post
Who has ever had a bearing fail because they hammered out wheel studs?
I'm not a fan of hammering them just because it's not that hard to pull them and do it "right" but I'd be surprised at any noticeable lifespan change from hammering them honestly.
Heat from track use will kill them far more quickly and I still get 10s of thousands of miles out of wheel bearings on the race car and dedicated track car. Granted they aren't a BRZ/FRS but still.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-05-2015, 05:08 PM   #143
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Already took care of it thanks
Kosmos is offline   Reply With Quote
Old 05-10-2015, 10:53 PM   #144
Hyper4mance2k
Shadetree Project Ratchet
Hyper4mance2k's Avatar
Drives: series.Blue
Just thought I'd add my experiences from my install this weekend. I used washers and an impact and everthig went well. I hammered the fronts out aftet removing the brakes. For the rears, I hammered the studs out then removed the hub and pulled the studs in. I used some Ichibas in the front and ARPs in the rear. The ARPs are light years ahead of the Ichibas. The ARPs made my impact work to get set, while the Ichibas could almost be pushed in by hand. One of them wouldn't even seat, it just spun in the hub. Fortunately I put a nut on my stock studs when I hammered them out & they were still usable. I've already ordered ARPs for the front and this Ichiba crap will soon find solace in the trash bin.
I guess now I know why they were for sale. :/
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-01-2015, 10:57 PM   #145
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Hyper4mance2k View Post
Just thought I'd add my experiences from my install this weekend. I used washers and an impact and everthig went well. I hammered the fronts out aftet removing the brakes. For the rears, I hammered the studs out then removed the hub and pulled the studs in. I used some Ichibas in the front and ARPs in the rear. The ARPs are light years ahead of the Ichibas. The ARPs made my impact work to get set, while the Ichibas could almost be pushed in by hand. One of them wouldn't even seat, it just spun in the hub. Fortunately I put a nut on my studs when I hammered them out & they were still usable. I've already ordered ARPs for the front and this Ichiba crap will soon fine solace in the trash bin.
Ha yeah man for this purpose I wouldn't touch anything but an OEM stud or the ARP studs.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-26-2015, 04:57 PM   #146
Valentino
Drives: GT86 2014
Anyone tried this? http://arp-bolts.com/kits/ARPkit-det...?RecordID=5105
Good? not good?
Valentino is offline   Reply With Quote
Old 06-26-2015, 05:05 PM   #147
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by Valentino View Post
Yep, i have them. They are great. Hold up way better than stock studs.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-26-2015, 05:17 PM   #148
Valentino
Drives: GT86 2014
I found the ARP online catalog. and the 100-7727 is the stander OEM replacement size.
Old 07-25-2015, 12:20 PM   #149
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Originally Posted by CenCali86 View Post
I am running the ARP extended studs with a 20mm spacer up front and 25mm in the rear. Since they only sold 25mm as a bolt on option I pressed out the other set of studs and just used them as slip on spacers.
I have been running this setup for about 5-6 months now with no problems.
Still running strong? I'm considering your identical setup after spinning a stud on my 20mm spacers and the shearing a stud on my read hub.
Do you do any tracking on them?
What kind of wheels you running? I want to use OEM wheel and lug nuts, but I'm worried the nubs at the end of the APR studs make that impossible.
YouShallKnow is offline   Reply With Quote
Old 07-25-2015, 09:19 PM   #150
CenCali86
CenCali86's Avatar
Drives: FRS 10 Series
Well they were running amazing up till I recently sold the car. I am sure they are still doing well for the new owner. I had no problems with the extended studs and they were a great upgrade considering I snapped one of the stock studs.
I was running OEM wheels with Muteki open ended extended lug nuts. I also had 20mm spacer up front as well as 25mm spacer in the rear that I had to press out the offset pair of studs since no one makes a 25mm+ slip on spacer.
I had traced the car once on that setup as well as daily driving and a fair share of spirited driving, so I think they did the job very well. I recommend it.
The install is also very simple and straight forward.
CenCali86 is offline   Reply With Quote
The Following User Says Thank You to CenCali86 For This Useful Post:
YouShallKnow (07-25-2015)
Old 07-25-2015, 11:26 PM   #151
YouShallKnow
Drives: Man
Damn, I guess you can't help with my little favor.
I know it's been said here numerous times that the closed OEM lug nuts don't work with the APR extended studs due to the nose cap on the APR studs.
But what happens when you put an OEM lug nut on? Does it just simply not fit and no thread catch? Or does the 5 mm nose go into the semicircle cap, and 6-7mm of threading catch, but it's just useless because it's so far out on the stud?
I ask because APR has released a new range of sizes for their extended studs stock, 1.950 UHL", and 2.545" UHL.
I haven't done the math yet because I have some measurements to take and I don't know the answer to my question posed here, but I hope to use the new sizes to create a setup where my spacers will push everything out far enough that the stock lug nuts will be able to torque down the wheel even with APR's weird extended noses.
Can anyone with APRs and OEM lugs thread one on and see how much of the APR stud disappears inside?
The OEM lugs take about 20 mm of stock stud and I wonder if it's about the same with the APR (albeit with 5mm less threading).
Thanks in advance for anyone that can help!
Any help would be appreciated! Thanks.
Old 07-26-2015, 12:45 AM   #152
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
im having the worst effing problem removing the rear hub. that puppy is siezed. the fronts are cake but man those rears! and its a little past midnight... any idea what might help??? btw ive already looked through this whole thread and youtube and i got nothing...
chris912 is offline   Reply With Quote
Old 07-26-2015, 06:39 PM   #153
Rosticles
Drives: 1966 Mustang, 2013 FR-S
I'm pretty proud of my ghetto setup for removing/inserting studs into the rear hubs. That's a t-slot clamp fixture with a grade 8 bolt. I didn't even end up bleeding!
Rosticles is offline   Reply With Quote
Old 07-26-2015, 07:16 PM   #154
CenCali86
CenCali86's Avatar
Yea sorry I can't really help you out there. haha
Best of luck though in your search.
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
